Old Sat, Dec-18-2010, 12:00:12 AM   #1
Avia2
Reputation: 0 Avia2 is on a distinguished road
Default Brackets on Mid-Pipe of E46 M3 rusted and cracked. How do I...
Mount my new exhaust. I need to get a new flanges on the original mid-pipe section so that I can bolt on my new exhaust. I was so excited today but then disappointed to see the crack. Any Ideas?
Jump to top Avia2 is offline   Reply With Quote
Old Mon, Dec-20-2010, 02:53:19 PM   #2
Michalek0915
04 M3 SMGII
Michalek0915's Avatar
Reputation: 0 Michalek0915 is on a distinguished road
Default Re: Brackets on Mid-Pipe of E46 M3 rusted and cracked. How do I...
This is a common problem on the E46 M3's. Mine was rusted as well and only one of the flanges on the mid-pipe is replaceable if you are referring to Section 2, which I believe you are so in order to get a new flange you would need a new pipe. Look for one that has been slightly used or invest $400 or so for a new performance one. Hope that helps.
Mods - Highline Intake System, VMR V715 19" Wheels, Agency Power Exhaust V2 W/Titanium Tips, Powerflex RTAB's & FCAB's, StopTech Stage 2 Brake Upgrade Kit W/Axxis Ultimate Pads & Slotted Rotors, CSL Half-CF Rear Diffuser, Front CF Lip, Koni Yellow Adjustable Shocks W/ Eibach Pro Springs, Depo Smoked Corners, Blackout Grille & Kidney Set, Umnitza Orion II Angel Eyes, Stealth Bulbs, Painted Reflectors, 30% Tint All Around, Blue LED Interior, Tennis Balls, JL Audio 500/1v2 Slash & Wicked C.A.S Enclosure W/ 12" W3v3.
Jump to top Michalek0915 is offline   Reply With Quote
brackets, cracked, e46, midpipe, rusted
Discussing Brackets on Mid-Pipe of E46 M3 rusted and cracked. How do I... in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
