Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > BMW M3 Discussions > M3 Frequently Asked Questions
M3 Frequently Asked Questions First place to check if you've got a question about your BMW M3. UNDER CONSTRUCTION
Old Mon, Jul-26-2010, 07:17:21 AM   #101
MPOWERD
Mod Hound!
MPOWERD's Avatar
Reputation: 0 MPOWERD is on a distinguished road
Originally Posted by dumesday4u View Post
recently the handle to my glovebox mysterious fails to function. with the key, i can turn and open the glovebox. Everything up to that point besides the handle was broken. I had my car in the shop since i work at the stealership and had a friend and tech look at it. he told me i needed a new switch when he took it apart. i asked for the price and found it to be too expensive so i put it back together. after i put it back, i tried to mess around with it a bit and so i tried to unplug the harness and the wires from inside the glove going to the latch broke. i didnt think it affected anything so i put it back together and just felt like dealing with the problem a bit longer before investing in a new handle. when i started the car later, the trunk light came on so i went to unlock the trunk and close it. it didnt seem to latch on and lock when i closed. i just went "thump" then came back up. we pryed at it for a bit and slammed it a bit harder and it finally closed tight. we opened and closed it again to see if it closed properly and everything was normal again. when i went back in the car, the trunk light was still on. i checked the trunk, opened, closed again. went back in the car and the light was still on. tried to put down the top and now the light keeps blinking and it wont let me open the top because it thinks the trunk is open but it also wont let me hit the close button all the way so the light turns off. so now i have a broken glovebox, a trunk light warning, and a vert top light flashing. any help?
Help is easy... Replace the handle unit with the proper VERT unit from Tischer... (its a bit of a ***** though)
I have the box rom mine in the garage. I will get you the part number off that box tomorrow...
http://www.m3forum.net/m3forum/image.php?type=sigpic&userid=91859&dateline=123241  4897
2003.5 e46 ///M 3 TiAg Cabriolet SMG II...
<> CSL Carbon Fiber Intake w/MAF, Brembo Gran Turismo, Euro Headers & Cats, K&N 69, Radenergie Carbon Fiber Strutbar
<> EAS Carbon Fiber Kidney Grills, Carbon Fiber Fender Grills, SMG Carbon Fiber Paddles, Vorsteiner 2 Sided CF VCSL Boot
<> EAS Slvr Carbon Fiber Interior Trim, Blk Carbon Fiber SMG Dome, Carbon Fiber Console, & Blk/Slvr Steering Wheel Trim
<> EAS Carbon Fiber Engine Bay, Vorsteiner Carbon Fiber Valve Cover, RPI Intake Scoops, CarPC w/Nav/MP3/HD Radio/TV
<> Eisenmann Race Exhaust, Supersprint X-Pipe with Resonator, Ekarbon 1/2 Carbon Fiber Diffuser, DEPO Smoked Corners
<> 19x8.5 19x9.5 VMR V710s in HyperSilver, Painted Corner Reflectors, EAS Carbon Fiber Emblems, Carbon Fiber Hood Vent
<> Slvr CF Pedals, OEM 2-Tone Hardtop, Windscreen, & Alarm, 6K Headlights & HID Fogs, Blk Carbon Fiber Headlight Trim
Jump to top MPOWERD is offline   Reply With Quote
Old Tue, Nov-30-2010, 06:05:27 AM   #102
808hawaii
808hawaii's Avatar
Reputation: 0 808hawaii is on a distinguished road
Default Top cleaning
Originally Posted by IFX View Post
What do you guys reccomend for cleaning the top?
Good question, sometimes I take mine through the car wash but I'm not sure if if hurts the ragtop.
Jump to top 808hawaii is offline   Reply With Quote
Old Tue, Nov-30-2010, 10:28:07 PM   #103
frenchyfromFL
Allez l'OM !!!
Reputation: 0 frenchyfromFL is on a distinguished road
Would never do that
I use 303 products
2003 E46 M3 Vert JB/IR,OEM Nav, BSW subwoofer, VMR VB3 CSL rep 19" Gunmetal, Borla Muffler, Borla Midpipe, Fabspeed headers, AA Tune, K&N intake, ST coilovers
Jump to top frenchyfromFL is offline   Reply With Quote
Old Thu, Dec-09-2010, 06:52:10 PM   #104
buckeyedoc
Newbie to the M3 World :)
buckeyedoc's Avatar
Reputation: 0 buckeyedoc is on a distinguished road
I havent taken mine through the auto washes...but the manual says it shouldnt be a problem.
Im guessing it is eh?
Jump to top buckeyedoc is offline   Reply With Quote
Old Fri, Dec-17-2010, 05:08:20 AM   #105
Rmayrap
Reputation: 0 Rmayrap is on a distinguished road
Originally Posted by OiS View Post
hey guys i might need a bit of help if possible...
i have been getting a rattling/squeaky noice comming from the rear side of the vehicle while on the road. not sure if it has to do with the top or what, i believe it has since it only makes the noice when the top is up... any1 having the same issue?
same problem here, can anyone answer this? mine does it on bumps and hard turns.
Jump to top Rmayrap is offline   Reply With Quote
Old Sat, Dec-18-2010, 10:16:00 PM   #106
ac427
Reputation: 0 ac427 is on a distinguished road
United Kingdom
It it expensive to replace so i would look after by hand washing.
There are BMW products available to clean and re-waterproof the material.
Beside auto washes are going to rape your paint work
Jump to top ac427 is offline   Reply With Quote
Old Tue, Dec-28-2010, 08:41:29 AM   #107
younghno50
younghno50's Avatar
Reputation: 0 younghno50 is on a distinguished road
Default Re: Question on the Vert? Look here First.
For starters, thanks for hosting this thread!
The plastic fitting where the wind visor pops in on the inside side panels broke out. I got the replacement part from the dealer but it doesn't fit properly. The piece i got is correct but too small so should I glue it in place?
I have an 04 with LED tails. The passenger side tail light had to be removed at one time in order for PDR repair done last summer. Now there is condensation and water inside the fixture. How do I fix?
Lastly, its winter and way to cold to wash the car at home. I went to a car wash and the passenger side view mirror plate is loose. Is it broken and should I just get a replacement mirror plate? Is the install as easy as I think it is? Just pull the old piece out and pop in the new one?
TIA everyone!!
Young.
2004 silbergrau metallic convertible, squeaky UUC RTAB's, umnitza LED angel eyes, depo smoked corners, wind screen, custom performance rasp terminator, micro antenna, DICE Silverline, window tint, Rotora 4 Piston BBK, Slotted rotors, Rotora SS brake lines, Tein S Springs, CSL 1/2 CF diffuser.
Jump to top younghno50 is offline   Reply With Quote
Old Tue, Dec-28-2010, 08:16:35 PM   #108
drchuck72
Reputation: 0 drchuck72 is on a distinguished road
Okay, so I have had a number of problems with my top.
In May 09, I had the Hydraulic Motor, Relay and control module replaced when my top stopped working.
In April of this past year, I had to have the hydraulic motor replaced again.
Recently, I have had to mobilize the top a few times to remove and replace the baby seats (since they are tethered under the tonneau).
I recently removed the hardtop install kit to sell to someone who had brought their car up from the States. After we finished, I tried to raise the top again. It wouldn't even move. The tonneau had fallen down but was not locked down. Turns out, one of the wire harnesses that was left on the passenger side wasn't plugged in. I got in there and plugged it back in and the tonneau closed. Subsequently, I tried to close the top and it would not move again.
I used the instructions in the manual to disengage the top mechanism and closed it manually.
So my questions are 2 fold:
1. Why won't my top work?
2. Once closed manually, can the top mechanism be re engaged or do I have to go back to the dealer?
Admittedly, it has been cold here but not below -10C which is the temperature at which BMW recommends not operating the top.
Thanks.
DC
DR CHUCK
2009 E92 M3 Interlagos Blau on Schwartz. DCT, EDC, TECH PKG, M Drive. Volk LE37T 19 x 8.5 ET35f (with 15mm spacer) 19 x 10.5 ET22r, with Toyo T1R 245 35R19f, 275 30R19r, Ground Control Coilover Conversion, Turner Motorsport 90mm stud conversion kit.
Coming soon: OEM ZCP style Carbon Fiber splitters and rear deck spoiler and VRS type II rear diffuser.
Jump to top drchuck72 is offline   Reply With Quote
Old Wed, Dec-29-2010, 08:30:10 AM   #109
HHH
Reputation: 0 HHH is on a distinguished road
Having the same issue here.. I hear a the same rattles/squeeking from the rear of the top when its closed on bumps and hard turns..
anyone have any solutions or idea?? everyone I ask thats a BMW head or car guy says convertible tops will just naturally squeek and thats with every soft top but I dont buy it..
any ideas?? TIA
Jump to top HHH is offline   Reply With Quote
Old Sat, Nov-05-2011, 01:26:32 AM   #110
libra
Reputation: 0 libra is on a distinguished road
Default Cheap Canada Goose
This is my first time i visit here. I found so many entertaining stuff in your blog, especially its discussion. From the tons of comments on your articles, I guess I am not the only one having all the leisure here! Keep up the good work.
Cheap Canada Goose
Cheap Herve Leger
Moncler Jackets Cheap
Jump to top libra is offline   Reply With Quote
question, vert
Vert Question mimthree3 E46 M3 (2001-2006) 24 Sun, Sep-07-2008 06:34:58 PM
vert question so-nesessary E46 M3 (2001-2006) 6 Tue, Aug-14-2007 04:03:18 AM
vert question so-nesessary E46 M3 (2001-2006) 11 Thu, Aug-02-2007 11:42:18 PM
Vert owner question.. zakattak20 E46 M3 (2001-2006) 8 Tue, Feb-06-2007 06:58:51 PM
M3 Vert Question - Thanks ekuenzli E46 M3 (2001-2006) 8 Sat, Feb-04-2006 03:05:58 PM
Discussing Question on the Vert? Look here First. in the M3 Frequently Asked Questions Forum - First place to check if you've got a question about your BMW M3. UNDER CONSTRUCTION at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
