Mobile M3forum |
| E46 M3 (2001-2006) Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm Total Produced: 45,000+ - Years Produced: 2001 to 2006. |
#31 |
So looks like the big cable is actually a little melted also. I'm going to have both cables fully changed out next week and hopefully that solves the issue. thanks for all the input
| Sponsored Links |
#32 |
Ok I have this same problem too. How I notice this is that my battery will drain after seating for 24 hours. I testest the current draw and saw I have short and I was able to find the prob. It was my DVD rom. But when I was doing that I saw the fat cable that is at the battery terminal was a bit melted right at terminal and the car didn't want to start and my cap for my amp wasn't reading voltage. I was WTF cause my voltmeter showed the batt had 12.1 volts. Then by accident I touched the fat wire and the cap then turned on and showed the voltage. And almost everymorning I have to wiggle the fat wire and the car will turn on and when I get to where I have to go true wire is hot tithe touch. So this morning I disconnected and I saw where the wire connects to the terminal was lose. So on the drive home tonight I will see if it still heats up. Has anyone fixed this issue and how. Sry to ask but the op didn't say I'd he fixed the problem.
#33 | |
![]() Location: SF Bay Area
2003 Alpine White BMW M3 Coupe Modifications:Dice Ipod Interface [] Focal Utopia 6.5in components speakers(front), Focal Utopia 5.25in component speakers (rear) []JL Audio W3V3 Sub Woofer [] Eclipse Xa5000 5 ch amplifier [] Clifford 50.7 two way pager [] Custom interior trim (OEM Alcantara) [] Dinan Stage I tune. [] |
#34 |
so the problem was a lose cable to the battery terminal coupler. now my car starts fine and the cable is warm but not hot to the touch.
#35 |
I am having this problem now too. My positive battery cable is melted. I am going to remove the DICE unit and then have the cable replaced. Any other suggestions?
#36 |
M-Texture Alcantara
![]() Location: Toms River, NJ
I had this problem and it brought it to the dealer to repair, it cost me $1800. New battery, new cable, new alternator and they had to pull up the interior to get at it.
Funny story - I charged the car over night, left my house in Toms river, and drove up to Freehold to the stealership there (douche bags). I was about .2 of a mile away and the car starting acting odd, the dash board lights came on and as soon as I pulled in to the dealer lot, the car literally died right as I stopped in front garage for the service bay. My battery ran the car the entire way there!
2006 Interlagos Blue BMW ///M3 | ZCP | Xenon | Nav | Premium | M Texture Alcantara | Euro Headers & Cats | Evolve R Tune | CSL Airbox ![]() Collection of my DIY Guides here |
#37 |
M-Texture Alcantara
My cable was melted all the way through, not just the end terminal.
#38 |
Should the positive terminal be hot to the touch at all? Mine is hot but not enough to burn through anything.
#39 |
Only after driving for a while, if you cannot hold your hand on it, something is wrong, which is probably the ground circuit leading back to battery.
#40 |
I drive about an hour to work. When I get there its hot, but not enough to melt something. I can keep my hand on it. I am going to get it checked anyway next week. There is going to be a current test, is there some other test that needs to be done?
| Bookmarks |
| Tags |
| battery, helphot, insulation, melting, terminal, wire |
| Thread Tools | |
| Display Modes | |
