Old Sun, Jul-01-2012, 01:56:53 AM   #1
Charliexd
Charliexd's Avatar
Reputation: 0 Charliexd is on a distinguished road
Default tires?
so I have a question about tires. I know that I could go check actual specs and measure how much tread is left per tire.
But just as a feeler, is it common for people to go through front tires faster than rear tires? Or is it just my impression that I feel the wear bars closer on the fronts than the rears?
please don't flame, honest question.
StreetEdge Coilovers. Macht Schnell intake elbow and filter. Euro headers and cats. B&B Triflow w/dbl wall tips. CSL Diffuser. Scorza CSL 1x1 dbl sided Trunk. StormMotorwerks Shifter.
Jump to top Charliexd is online now   Reply With Quote
Old Sun, Jul-01-2012, 01:58:24 AM   #2
trifenix
2005 M3 ZCP
Reputation: 0 trifenix is on a distinguished road
Fwd fronts wear faster. M3 rears wear faster at least for me.
Jump to top trifenix is offline   Reply With Quote
Old Sun, Jul-01-2012, 03:07:07 AM   #3
M3_MANN
Reputation: 0 M3_MANN is on a distinguished road
Default Re: tires?
Rears are suppose to wear faster. When you accelerate, the rear tires get more stress/contact and therefore eats up more tire.
2003 E46 ///M SMG
1990 E30 325is
Jump to top M3_MANN is offline   Reply With Quote
Old Sun, Jul-01-2012, 03:49:02 AM   #4
emanresu
Reputation: 0 emanresu is on a distinguished road
Default Re: tires?
Agreed. My rears need to be replaced now actually. I'm sure it has a lot to do with how you drive too.
Jump to top emanresu is offline   Reply With Quote
Old Mon, Jul-02-2012, 03:40:56 AM   #5
freddyis300
Reputation: 0 freddyis300 is on a distinguished road
Default Re: tires?
Probably two rear tire replacements per one front tire replacements on the E46 M3.
Jump to top freddyis300 is offline   Reply With Quote
Old Mon, Jul-02-2012, 03:46:25 AM   #6
bmwbob
BlueHairMafia
bmwbob's Avatar
Reputation: 0 bmwbob has disabled reputation
St Vincent and the Grenadines
Default Re: tires?
agreed.
Jump to top bmwbob is online now   Reply With Quote
Old Mon, Jul-02-2012, 03:49:55 AM   #7
JerseyShoreM3
Lets just slap an ///M badge on everything....
JerseyShoreM3's Avatar
Reputation: 0 JerseyShoreM3 is on a distinguished road
Default Re: tires?
+2 That's seems to be the case for me.
Jump to top JerseyShoreM3 is offline   Reply With Quote
Old Mon, Jul-02-2012, 05:01:40 AM   #8
Foo2rama
2004 E46 M3
Foo2rama's Avatar
Reputation: 0 Foo2rama is on a distinguished road
Default Re: tires?
I go through rears about 2x as fast...
2004 Mystic Blau Imola Rot ///M3 Coupe SMG
Other Rides
73- 240z - L28 Block w e31 heads - prepping as a track toy
95- Legend Coupe - C32A5 block - totaled while parked
96- Dodge Ram 4x4 5.9 - totaled while parked in a seperate incident
Jump to top Foo2rama is offline   Reply With Quote
Old Wed, Jul-18-2012, 11:41:38 PM   #9
Charliexd
Charliexd's Avatar
Default Re: tires?
one more tidbit of requested information.... on these cars, how low on tread can one go safely? obviously before the point of slicks...
just want to know if my tires even warrant changing or if I'm just not used to running sport tires.
Old Thu, Jul-19-2012, 12:17:41 AM   #10
BeelzebubsM3
Super User on the loose
BeelzebubsM3's Avatar
Reputation: 0 BeelzebubsM3 is on a distinguished road
Norway
Default Re: tires?
The fronts will only wear faster if you do a lot of hard cornering, and even then I would think the rears should still wear out faster.
On my 335, I could see the inner construction of the tire before I swapped them. I do not recommend doing that.
Topaz | Evolve-R | Alpha-N | K&N | SGT | CPI | AutoSolutions | APEX | PSS
Jump to top BeelzebubsM3 is online now   Reply With Quote
Discussing tires? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
