Old Thu, Jul-19-2012, 05:52:45 PM   #1
SteveR
Reputation: 0 SteveR is on a distinguished road
Angry Steering column won't unlock
Last night something odd happened after taking my '97 M3 for a short ride. I parked it at the curb to switch vehicles around. When I started it up again, it started fine, but the steering column didn't unlock. The wheels are pointing straight ahead, so the steering wheel is *not* turned all the way right or left. The ignition key mount is a bit loose, but it's been that way for some time. I tried starting the car several times, with the same result each time. Car started fine, wheel remained locked.
Anyone run into this situation before or know what the problem might be?
Jump to top SteveR is offline   Reply With Quote
Old Thu, Jul-19-2012, 06:37:06 PM   #2
Kalahari
Reputation: 0 Kalahari is on a distinguished road
This happened to me last winter. I just drilled out the steering lock. Very easy with even an average drill bit. Google it to find a DIY. Should take less than 20 minutes.
Jump to top Kalahari is offline   Reply With Quote
Old Thu, Jul-19-2012, 08:32:44 PM   #3
SteveR
Default Re: Steering column won't unlock
Thanks for the reply. I'll give that a try when I get home tonight.
Old Thu, Jul-19-2012, 09:52:08 PM   #4
Kalahari
One word of advice: unless you have a portable vacuum, you may want to cover the area with trash bags or newspaper or something. Metal shavings will get everywhere when you drill.
And, obviously, you won't have a steering lock anymore.
Old Thu, Jul-19-2012, 11:21:17 PM   #5
KWorker17
Brett Favre of M3's
KWorker17's Avatar
Reputation: 0 KWorker17 is on a distinguished road
Just did a quick google search and this seems to work.
http://www.bmwfanatics.co.za/showthread.php?tid=16151
I understand that some of the track guys do it to prevent anything from happening.
Kevin
Jump to top KWorker17 is offline   Reply With Quote
Old Fri, Jul-20-2012, 02:33:37 AM   #6
Kalahari
Yup, that's the guide I used. Again, painfully easy job and worth the safety.
Old Sun, Jul-29-2012, 03:30:43 PM   #7
SteveR
Thumbs up Re: Steering column won't unlock
This worked perfectly as described. Problem resolved with simply drilling a hole. The picture in the guide of pulling out the spring gave me enough to know where to drill.
Thanks for the tip about the metal shavings going everywhere. I put down a large plastic bag on the floor and it got 99% of the shavings.
Old Sun, Jul-29-2012, 04:42:17 PM   #8
Kalahari
Glad you got this fixed!
1997 m3, locked, steering column
Discussing Steering column won't unlock in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
