Old Sun, Aug-05-2012, 02:43:36 PM   #11
p0lar
Naturally Agitated
p0lar's Avatar
Reputation: 0 p0lar is on a distinguished road
Default Re: Clunking that im not sure of CSB?
OP: you asked for opinions in another thread, and received responses for a few items to examine.
Then, you create another thread about those things to check, and ask if it could be those?
It's just my $0.02, but why bother with the forums until you have more information? If you crawl under the car, you can see the guibo clear as day. Examine it. You could probably also shake a few drivetrain items to see if they clunk or rattle. Report back when you have more a more concrete diagnostic of the problem and someone here is likely to help. As it is, guessing where a mystery clunk originates from behind a monitor under arbitrary circumstances is unlikely to yield a proper assessment of the issue.
Originally Posted by cyberlando View Post
Do I have to drain the diff fluid for this
If you've not drained it before, just do it anyway. It's not expensive.
Calculating Brake Bias || Brake Bias Cross Reference Chart || Custom SS Brake Line Build
MK60 Fault Code Descriptions || Brake Fluid Specs
DIY DME (ECU) TUNING
: 6MT shift lights, sport mode memory, max-speed delimiter, dyno rev limit delete, rear O2 sensor delete, TunerPro checksum correction for E39 M5/E46 M3; modify rev limits, throttle response (sport/comfort), oil temp lights, SMG Auto fix w/gear swaps, and much more - PDF Howto
Jump to top p0lar is offline   Reply With Quote
Old Sun, Aug-05-2012, 05:56:42 PM   #12
cyberlando
cyberlando's Avatar
Reputation: 0 cyberlando is on a distinguished road
The guibo is in great shape so its not that....I checked everything and all is good!
The only thing I find is that wen my car was on the lift I spun the wheel forward and then quickly backwards and I here a thud sound in the drive shaft area!
There are no vibrations in the cabin while driving
Engine:
[] Euro Headers [] Euro Cats [] OEM Section 2 [] B&B Exhaust [] BMC Filter
[] UUC SSK EVO 3[] Turbo Toys V3 hub
Tune:
[] Euro DME Tune [] Shift Lights 6MT[] Sport Mode Memory
Interior:
[] Led Interior [] DICE Module[] Auxilary 3.5 jack
Suspension/Handling:
[] KW V3 [] Eibach F&R Sways [] Rogue Tranny mount [] UUC RTAB
[] Vibratechnics Motor Mount [] SSBL
[] 90A Akg Subframe Bushings []Akg Differential Bushings [] Subframe Renforcement [B]
Upcoming:
[] DSSR or Autosolution shifter [] Interior refresh [] Front bumper Respray
[] Aftermarket Speakers & amp [] Evolve Tune
Jump to top cyberlando is offline   Reply With Quote
Old Sun, Aug-05-2012, 06:04:21 PM   #13
cyberlando
cyberlando's Avatar
I changed the diff fluid less than a month ago.
I'm not trying to throw good fluid if I can just Chang it lose a little then top back up
Engine:
Tune:
Interior:
Upcoming:
Old Sun, Aug-05-2012, 06:09:30 PM   #14
p0lar
Naturally Agitated
p0lar's Avatar
There you go then - if you pose a question whose answer you may not like, don't pose the question. Or, that's what I used to tell my mother...
Old Sun, Aug-05-2012, 06:15:43 PM   #15
cyberlando
cyberlando's Avatar
I'm asking do I? I'm not sure that when I take the seal out if its gonna be a slow leak or its all gonna just rush out ?
Engine:
Tune:
Interior:
Upcoming:
Discussing Clunking that im not sure of CSB? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
