Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > BMW M3 Discussions > E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convert) (2008-2013)
E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convert) (2008-2013) {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm}
Old Wed, Aug-08-2012, 05:03:41 PM   #1
eas
eas's Avatar
Reputation: 0 eas is on a distinguished road
Default ▀▄ eas | DIY: Angel iBright V4.5 for e92 3-Series & M3 [INSTALL OVERVIEW]
Below is a video overview of the new AngeliBright (AiB) v4.5 LED Angel Eye kits showing an install into a 2011 BMW M3.
Angel iBright V4.0 fits any e92 pre-LCI 3-Series Coupe/Convertible (including all e9x M3 models) with Angel Eyes from the factory ever built.
Features:
- Brightest Angel Eye kit on the market with uniform light distribution between low and high beam Angel Eye rings
- 3 year warranty, over 3x longer than other kits on the market
- Precision 6061 CNC aluminum construction
- Much brighter compared to OEM yellow bulbs, or other competing LED angel eye kits
- 6000k to match the low beam xenon headlights
- No dimming of lights when ignition is turned on, rings remain at full power at all times
- Complete microprocessor controlled ballast system specifically designed for the 3-series Coupe/Convertible and all M3 models
- Ballast controls and maintains proper electrical conditions for the AiB at all times
- Includes all US and Worldwide e92 cars including M3 Coupe/Sedan & Convertible
- Complete OEM fitment and better than OEM finish
- Easy installation in 10 minutes, you DO NOT have to remove the headlights!
- Light bending” optical system to deliver maximum light into the Angel Eye rings
- Integrated Plug & Play Connectors, no external harnesses required
- Manufactured and assembled in the USA
- No AM/FM radio reception interference
- No Flickering, Blinking or Flashing on startup
- No On-Board Computer(OBC)/dash errors
Comparison of OEM vs AIB v4.5
Direct Sunlight
AIB v4.5 components tucked away inside headlight housing - no drilling or cutting required
Models Supported:
2007-2012 e92 3-series Coupe/Convertible
2008-2013 e9x M3, including Sedan, Coupe and Convertible models
Tools Needed:
- Flat Tip ScrewDriver
- Pliers (SoftJaw preferred)
- 5/64" Allen Wrench
Enjoy, feel free to ask questions in the thread if help is needed.
Customer Service | european auto source (eas)
email: info@europeanautosource.com web: www.europeanautosource.com
tel 866.669.0705 | ca: 714.369.8524 | fax: 714.908.1796
Blog | Facebook | YouTube | Flickr
Jump to top eas is offline   Reply With Quote
Discussing ▀▄ eas | DIY: Angel iBright V4.5 for e92 3-Series & M3 [INSTALL OVERVIEW] in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convert) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
