Mobile M3forum |
| E36 M3 (1992-1999) {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm} Total Produced: 71,212 - Years Produced: 1992 to 1999 |
#1 |
Hey guys, Before you tell me to use the search function i'd like to just get it out of the way now and tell you I have. Nothing that really helps has come up. That said let me try and explain my issue.
Under acceleration I find the exhaust makes a blow/whistling noise. You can hear it a little bit on open roads, but it is very easy to hear when you are driving beside a median. Reminds me of an old beat up corolla exhaust as the car just putts along. As of right now i'm thinking this is an exhaust leak. I asked a friend to stand on the side of the road while I drove by and put my foot down, he said it sounds like it is coming from the middle. When the car is in neutral however, and I let it idle or rev it, you cannot hear it at all. That makes me question my diagnosis somewhat. In any case, does anyone have any advice as to how to test for what this is, and fix it? I thought if it was an exhaust leak I could put it up on stands, put soapy water on the pipes, start it up and run through the gears, but that seems highly unsafe. Anyway, any help would be greatly appreciated! |
| Sponsored Links |
#2 |
Craig
Put it up on stands and visually inspect the exhaust system, especially the joints. The engine doesn't pump much air unless it is under load, so a check neutral may not tell you anything. Do you know if it is OEM exhaust?
95 BMW M3 Current Project Cosmos Black, E46 6SP, VSL Rad, Stewart Water Pump, AA Header with 3" exhaust, aFe CAI, Euro HFM, 24lbs/hr injectors, unknown tune?, BW SS Brake Lines, Hawk HP+ Pads, M X-Brace, Mason Engineering Aluminum Strut Bar, MM Underpanel. To Do: Overhaul rear suspension, front suspension Tucson, AZ |
#3 |
The exhaust is OEM. When I put it up, how will I tell if there is a problem with the joints? Would I have the car running at the time and feel it coming out of a spot? I can't imagine its safe to engage a gear and have the tires moving while its in the air. You pretty much only hear it when you give it some gas, like when going through the gear to get up to speed.
#4 | |
Craig
95 BMW M3 Current Project Cosmos Black, E46 6SP, VSL Rad, Stewart Water Pump, AA Header with 3" exhaust, aFe CAI, Euro HFM, 24lbs/hr injectors, unknown tune?, BW SS Brake Lines, Hawk HP+ Pads, M X-Brace, Mason Engineering Aluminum Strut Bar, MM Underpanel. To Do: Overhaul rear suspension, front suspension Tucson, AZ Last edited by enderw88; Thu, Aug-09-2012 at 04:29:27 AM. |
#5 |
Thanks Enderw, assuming I can't find anything. What would be my next step?
#6 | |
Craig
It also struck me, that while you are under the car, to look at the insulation blanket and make sure that it isn't hanging down and rubbing on the drive shaft. It should be obvious, there will be a nice silver ring on the driveshaft where the blanket has been rubbing on it. Craig
#7 |
Carlos is My Co-Pilot
![]() Location: Near the Tannhäuser Gate
You can have the car running on jack stands, no problem. I did it just the other day to check for leaks after I installed my Stromung. Hell, you can even have it in gear, but I wouldn't get under it with the tires spinning. Either way, just make damn sure your jack stands are secure. Wouldn't want to exit the gene pool because you were trying to do this with a spare tire jack. :Goodluck:
75 years and 350,000 miles of fun: 1998 M3/4/5 No mods, just maintenance 1983 CJ-7 No maintenance, just mods 1983 R65LS No intention of modding it, don't know how to maintain it |
#8 | |
Craig
#9 |
Certified Geezer
You might be able to replicate the problem by trying to partially blocked the tailpipes. If it is leaking someplace, that would force it to exit in that area. Just be sure to use some very thick padding or gloves. It will get hot very quickly.
Rick Alpine/Blk 98 M3/4/5, TCK SA, Rogue SSK, X-brace, Bosch Euros |
#10 |
Craig
Possibly even easier would be to Seafoam the engine intake then look for smoke exiting where it shouldn't...and you cleaned the engine internals as well...
| Bookmarks |
| Thread Tools | |
| Display Modes | |
