Mobile M3forum |
| E46 M3 (2001-2006) Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm Total Produced: 45,000+ - Years Produced: 2001 to 2006. |
#1 |
I searched and found miky DIY with CSL headers with CSL cats.... need to know about the o2 sensor wiring if im running catless ? ..... does anyone know a DIY for the wiring if running catless??
if anyone can please help out I would greatly appreciate it... about to do the install myself if I can get this info... thanks |
| Sponsored Links |
#2 |
Dank
![]() Location: 310
send the member tonester a PM...He should be able to answer your question.
#3 |
thanks.... .ill do that!
#4 |
![]() Location: Canada
You need the pre cat O2 sensors and the EGT sensor install to the headers in order to get the car run properly. The post cat O2 sensors can be remove since you are running catless, it will be pretty much useless. But you will get a engine light unless you are getting software to bypass the post cat O2 sensor. Just lable the sensors to (Front pre cat; Rear pre cat; Front post cat; Rear post cat) and don't mix them up
| Bookmarks |
| Tags |
| catless, header, install, question |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Post Ebay Header Install Question | DimSum | E46 M3 (2001-2006) | 6 | Mon, Sep-01-2008 02:16:38 AM |
| Need to order Header studs, manifold gaskets, and other for header install quickly | silverm3man | E46 M3 (2001-2006) | 4 | Thu, Jul-17-2008 10:23:14 PM |
| Header install question? | JTrejo | E46 M3 (2001-2006) | 13 | Mon, Jun-11-2007 02:50:30 AM |
| Supersprint Header/Exhaust Install Question | ///MPT | E46 M3 (2001-2006) | 8 | Sun, Mar-11-2007 01:25:49 AM |
| SS Header Install Question | SilverState | Faults, Fixes and DIY | 1 | Sat, Aug-26-2006 05:32:07 PM |
