Mobile M3forum |
| E36 M3 (1992-1999) {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm} Total Produced: 71,212 - Years Produced: 1992 to 1999 |
#1 |
![]() Location: Los Angeles, CA
Hi all. Anyone know if the front strut mounting has some play in it? I know that camber and caster cannot be adjusted in stock form, but since I added knew koni struts, my caster numbers dont match ( L - 6.7, R - 7.3). I'm thinking the strut mounting can be moved around a bit to add to caster/camber.
Anyone know if this is true? I'm tempted to get camber/caster adjustable plates, but they're so much money. Anyone know of a cheap method to changing caster? Thanks. |
| Sponsored Links |
#2 | |
LOLiticks troll
![]() Location: Golden
#3 |
95 SC M3
![]() Location: Eldersburg, MD
Not adjustable at all, it is what it is. What little movement might be there isn't meaningful.
The only way to optimise the numbers is to go with castor/ camber plates. Then you are on the slippery slope of race car parts on a street car...
No matter where you go, there you are! Last edited by Richardsperry; Mon, Nov-02-2009 at 11:00:27 AM. |
#4 | |
LOLiticks troll
| Bookmarks |
| Tags |
| adjustable, front, mount, stock, strut |
| Thread Tools | |
| Display Modes | |
