Old Sat, Nov-21-2009, 12:34:55 AM   #1
CodyLtr
CodyLtr's Avatar
Reputation: 0 CodyLtr is on a distinguished road
Default Attacking the RTABS and Tie-Rods. Any tips?
My RTABS and Tie-rods are shot and I'm going to be changing them in a few weeks. I'm getting UUC Rtabs but not sure on the Tie-rods, should I just get stock replacements? Also any tips when replacing either of these?
Jump to top CodyLtr is offline   Reply With Quote
Old Sat, Nov-21-2009, 12:50:05 AM   #2
bmwpowere36m3
Reputation: 0 bmwpowere36m3 is on a distinguished road
Tie-rods are easy, you got a pickle fork or tie-rod spreader tool? Don't forget the "lock-nuts" for the tie-rods and OE, Lemforder tie-rods are the best. RTABs, I'd go with PF... removing the old one's will be a pita no matter what, unless you have the proper press tool. I had a full shop of tools, and they were still a pita (old ones were rusted to the trailing arms). Us anything you can to remove them, press, sawzall, air hammer, drills, etc...
Mike... aka Track Junkie_______Aiptek Low-Cost In-Car Video Setup or PM ME for details
'98.5 M3 Coupe Titan Silver
Jump to top bmwpowere36m3 is offline   Reply With Quote
Old Sat, Nov-21-2009, 02:02:47 AM   #3
ArBrnSnpr
Likes M118LR
Reputation: 0 ArBrnSnpr is on a distinguished road
I used an air chisel to remove the old ones. Granted mine weren't rusted but it took about 20-30 minutes per side to get the old ones out.
When I did them on my E46 M3 I never really thought to use the air chisel. I used a step bit on the Dewalt and went half way from each side, then hit the sleeve of the bushing with a section of hacksaw blade. That method took about 2 hours per side....Wish I would have though of the impact tools the first time around
Jump to top ArBrnSnpr is offline   Reply With Quote
Old Sat, Nov-21-2009, 04:40:01 AM   #4
fiveightandten
He'll save children, but not the British children...
fiveightandten's Avatar
Reputation: 0 fiveightandten will become famous soon enough
I had a real hard time getting my tie rod ends off. I'm in New England, but still, don't be surprised if you have to use heat. Even PB blaster didn't help out with that one. It was getting them off the inner tie rods that gave me the problem.
If you go poly for the RTABs, but sure to grease them up very very well. You don't want any squeaking, as you'll have to drop the arm again to get at them and rectify it.
-Nick
Jump to top fiveightandten is offline   Reply With Quote
Old Sat, Nov-21-2009, 02:47:32 PM   #5
cstern
Reputation: 0 cstern is on a distinguished road
So you just replaced the outer ends? I'm about to replace the entire rod and the boots with lemfoerder parts. Any tips on that? Will it be easier since I don't need to worry about the adjustment point being seized?
Jump to top cstern is offline   Reply With Quote
Old Sat, Nov-21-2009, 05:02:51 PM   #6
OahuMPower
:FACEPALM:
OahuMPower's Avatar
Reputation: 0 OahuMPower is on a distinguished road
replacing the entire rod will be much easier.....
Jump to top OahuMPower is offline   Reply With Quote
Old Sat, Nov-21-2009, 05:32:40 PM   #7
cstern
I thought so. The threads on the end that go to the rack already have some compound on them. Kinda greasy. They seem like quality pieces.
Old Sat, Nov-21-2009, 11:01:30 PM   #8
shaeff
Maintenance FTW
Reputation: 0 shaeff is on a distinguished road
I picked up an RTAB puller- made easy work of both sides. Air chisel will work well too, but mine is broken and I have yet to replace it. I like adding tools to my 'box.
Jump to top shaeff is offline   Reply With Quote
attacking, rtabs, tierods, tips
Discussing Attacking the RTABS and Tie-Rods. Any tips? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
