Old Tue, Aug-03-2010, 03:34:59 PM   #1
omar2006
Reputation: 0 omar2006 is on a distinguished road
Default Need Help. SES and EML lights on after oil change
I performed an oil change this morning and put in the correct amount of oil but i don't know what's wrong with my car now. Runs and drives fine, except for the service engine soon and EML indicators.
Any suggestions? Thanks!
I followed the DIY at http://www.madrussian.net/m3/diy_oil_change.shtml
Jump to top omar2006 is offline   Reply With Quote
Old Tue, Aug-03-2010, 04:00:02 PM   #2
lrinco01
SHOCKINVIBES MOTORSPORTS !
lrinco01's Avatar
Reputation: 0 lrinco01 is on a distinguished road
Panama
I had that same issue. i think something has to be redone to my ECU since i have the AA gen II stg II SC kit.
i will subscribe and see if anyone else chimes in and schools us on whats the issue
Leonel aka "Rico"
2001 // HPF Stg.2 Turbo M //3 Titanium Silver on Imola
661 RWHP HPF Stg. 2
- Open Dump wastegate
- AA stage 2 lwfw
- HPF stage 2 clutch
- New Precision Turbo 6766
- Aggressive Tune (More Boost)
- HPF oil cooler
and more....Simply put, Highly Modified
M //
Parts FOR SALE:
http://www.m3post.com/forums/showthread.php?t=727953
Jump to top lrinco01 is offline   Reply With Quote
Old Tue, Aug-03-2010, 04:48:50 PM   #3
intelone
intelone's Avatar
Reputation: 0 intelone is on a distinguished road
Cambodia
You forgot to plug in your tps?
6MT CB .:. IMEF IMHG OIF USMC Veteran .:. College Student
///Alpine .:. 9861 .:. H/C 701 .:. S624 .:. JL Audio .:. 300/4 300/2 500/1 .:. 10W6v2 wicked .:. Focal K2Ps
Diamond Graphite v710s .:. KW2s .:. ZCP Rotors .:. 996 Calipers .:. SS lines .:. Textar pads .:. VIS Bootlid
CSL Diffuser .:. CF Grills & Gills .:. Alcantara Steering Wheel & Boots .:. 55w 5000K TFX
My Sequential Turn Signals
Jump to top intelone is offline   Reply With Quote
Old Tue, Aug-03-2010, 08:30:48 PM   #4
1ch1ban
Reputation: 0 1ch1ban is on a distinguished road
i recently did my fluid change (engine oil, transmission, and differential) and i had the same thing.. the lights will go off after 6 cycles of engine start i think. the only thing that still bothers me is that when my key is in the ignition position 1 (not fully turned on, only the electricity is turned on), the EML and SES light will go on but once the engine turns over, those lights will go off. in addition to that, the XXXX miles to oil service/inspection is still on too at key ignition position 1.
i think the main reason is that you are supposed to disconnect your battery when you do the oil change.
also, after the XXXX miles until inspection light goes to zero, you have to run the car 500 miles (if i remember correctly) before you can reset the computer. it's not hard to do either but i can't do it now because my XXXX is not zero yet.
correct me if i am wrong.
Jump to top 1ch1ban is offline   Reply With Quote
Old Tue, Aug-03-2010, 09:07:22 PM   #5
roobe16
Certified Naysayer
roobe16's Avatar
Reputation: 0 roobe16 is on a distinguished road
Antarctica
^^Pretty sure that those lights are normal in Position 1; I can't remember which lights are always on in Position 1, but there are a few. It's not necessary to disconnect the battery when you do an oil change.
OP your SES and EML lights are likely normal, and will go away after engine cycles.
Jump to top roobe16 is offline   Reply With Quote
Old Tue, Aug-03-2010, 09:10:35 PM   #6
roobe16
Certified Naysayer
roobe16's Avatar
Antarctica
And also 1ch1ban, pretty sure that you can reset the OBC countdown at nearly any xxxxx indication, see the top of this thread for proper procedure:
http://www.m3forum.net/m3forum/showthread.php?t=190111
Old Tue, Aug-03-2010, 09:25:15 PM   #7
BlazenXLT
always money in the banana stand
BlazenXLT's Avatar
Reputation: 0 BlazenXLT is on a distinguished road
That was my idea too. Everyone's done that once.
Jump to top BlazenXLT is offline   Reply With Quote
change, eml, lights, oil, ses
Discussing Need Help. SES and EML lights on after oil change in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
