Old Mon, Jun-25-2018, 12:26:32 PM   #11
Jonnie86
Reputation: 0 Jonnie86 is on a distinguished road
Default Re: Idle-speed control valve, NC Winding
Originally Posted by Detailer View Post
Good idea about the fuel system cleaner. I'll try to source Techron in Canada.
Lol, why do people always recommend fuel system cleaner on here. That shit doesn't work...
Either pull off the injectors and get them professionally cleaned, or move on to something else, cause its a waste of money.
Jump to top Jonnie86 is offline   Reply With Quote
Old Tue, Jun-26-2018, 05:55:36 PM   #12
zingbmw
Reputation: 0 zingbmw is on a distinguished road
cleaning the injectors wouldnt be a bad idea. I would check the intake side for any cracking in the hoses and replacing those. I would also suggest a valve job especially if when you open the hood the engine is a little noisy (mine was out of spec and it helped my idle). If it looks really gummed up while youre in there doing the valve job, run sea foam or techron or something through it and hope that helps clean it up.
Jump to top zingbmw is offline   Reply With Quote
Old Tue, Jun-26-2018, 05:57:40 PM   #13
nextelbuddy1
nextelbuddy1's Avatar
i had the same issue. turned out my IACV and Alternator plugs were swapped. they both fit each other. once i swapped them my issues and codes went away.
alternator plug should be 2 wires and IACV plug is 3 wire but have the same plug. check them.
2003 ZHP 332i | S54 6 Speed | M3 Conversion
2002 ZHp Touring | M54 6 Speed
Old Wed, Jun-27-2018, 01:53:53 AM   #14
mrgizmo04
mrgizmo04's Avatar
Sea foam...?
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Sun, Jul-15-2018, 11:26:03 AM   #15
Detailer
Reputation: 0 Detailer is on a distinguished road
I'm sorry I did not upgrade this post before.
For future reference, in case someone google this issue, I should post what was my problem and fix.
There was a wire that was cut on the ICV wiring. Probably a mice or something since the car sat in a garage for 3 years without being touched or driven.
Not car runs perfectly!
Thanks all for your help!
Jump to top Detailer is offline   Reply With Quote
Discussing Idle-speed control valve, NC Winding in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
