Old Sat, Jun-23-2018, 09:48:09 PM   #31
Nate Boom
Reputation: 0 Nate Boom is on a distinguished road
Default Re: Looking for Guidance
That's true, but at this point it's definitely something else. Sounds like the vacuum line to the ICV is shot. It always idles real rough for a second on startup then smooths out.
Originally Posted by RedM3/4 View Post
I didn't read every post, but the number of times folks have messed up the 02 sensor wire locations when doing headers is ENDLESS.
ADS
APEX Arc-8's | CAE Ultra Shifter | Coby Wheel Alcantara Interior | ECS CF Lip/Diffuser | Euro Header Swap | H&R Coil-Over Kit | Mason Engineering X-Brace | Mishimoto Electric Fan | Motion Motorsports Underpanel | Porsche Boxster S Brake Setup | TMS Power Pulleys
Jump to top Nate Boom is offline   Reply With Quote
Old Mon, Jun-25-2018, 07:35:03 PM   #32
Nate Boom
Went to the stealership today, they were pretty confident it wasn't a vaccuum leak. So I just figured I'd do the fuel pump since that's what they suspect. It's due anyways soon with 130k miles and it hums a fair amount. Boo
Old Mon, Jun-25-2018, 09:44:56 PM   #33
mrgizmo04
mrgizmo04's Avatar
It's a journey to comb through and isolate/eliminate culprits...
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Mon, Jun-25-2018, 11:20:16 PM   #34
Nate Boom
For sure, more tiring than just having a single known major issue. Hopefully this will be the end of it.
Old Thu, Jun-28-2018, 04:08:15 PM   #35
Nate Boom
FINAL UPDATE (THANK GOD): So it was the fuel pump, cars running better than ever. Silky smooth and pulling strong. At least now I have a new MAF, O2 sensors, confirmed that my exhaust/intake don't leak and new fuel pump so the money wasn't totally wasted. Thanks for everybody's help!
Old Thu, Jun-28-2018, 04:14:02 PM   #36
mrgizmo04
mrgizmo04's Avatar
Nice, congrats man. Now the next time it starts the hick ups, it will be one of the other parts you collected in this process .
'05 M3 6MT coupe
Discussing Looking for Guidance in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
