Old Sat, Jun-23-2018, 02:36:47 PM   #11
bigjae1976
Default Misfire Issue - Cyl 6
Originally Posted by mrgizmo04 View Post
Jae,
It's very specific to one cylinder...outside of the usual maintenance stuff like coil, injector, plug, maybe electrical connections, you also have some internals that could be causing it - worn cam lobe, burnt valve, bent valve(?), misadjusted valve, broken piston ring or broken ridge between piston rings, etc. When you did the head gasket you notice anything on the cam or valves?
When I posted my first infamous post on the forum last Aug, chasing misfire and stutter on mostly 1 cylinder without codes, I ran through everything, coils, plugs, injectors, etc. What ended up helping me the most was a valve adjustment when I got around to it. The cylinder that was misfiring the most needed a MUCH bigger shim.
I just put on a different head/cams and the cylinders looked fine when I had the head off. Just did a valve adjustment and all of the valve shims were between .218 to .226.
I donít think timing is an issue because Iíve I had the misfire before and after removing the head.
Come to think about it...the only thing on the head that is the same is the VANOS.
Originally Posted by ThunderMoose View Post
I had some mystery misfires that I was able to resolve by cleaning the vanos solenoid valve body. My theory is that it was a tad too slow to adjust cam timing. Easy enough to do.
What error codes did you get?
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Sat, Jun-23-2018, 02:42:08 PM   #12
bigjae1976
Default Re: Misfire Issue - Cyl 6
Originally Posted by Ramp1 View Post
Double check all the wiring for the coil and injector for that cylinder. I had a similar issue on an old car i had that would come and go and Ďfiddlingí with things seemed to sometimes fix it but it always came back. Turns out a wire was damaged and would sometimes ground out but moving the wire would prevent the short sometimes. Just a thought.
Iíve replaced the ignition coil harness and checked the injector wire for continuity. I replaced the plug for cyl 6 since the contacts looked to be bent a little. No difference.
Old Sat, Jun-23-2018, 02:43:46 PM   #13
ThunderMoose
Just random misfire codes. Sometimes it would go into limp mode and cycling power would fix. These cars can be persnickety.
#67 2017 NASA TX TT3 Champion
Old Sat, Jun-23-2018, 03:14:36 PM   #14
mrgizmo04
mrgizmo04's Avatar
The fact that it's coming in and out and is not consistent leads to 2 things, variation of "something" with temperature somehow or electrical.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Sat, Jun-23-2018, 03:50:35 PM   #15
Drewster
Drewster's Avatar
How about the knock sensor on that side of the engine?
Old Sat, Jun-23-2018, 07:10:20 PM   #16
bigjae1976
It was going in and out...now itís consistent.
Old Sat, Jun-23-2018, 07:11:06 PM   #17
bigjae1976
Interesting. Whatís your thought behind that?
Old Sat, Jun-23-2018, 08:08:16 PM   #18
Drewster
Drewster's Avatar
It was a shot in the dark - looks like you've looked into most everything else (aside from physically deformed valves and VANOS?) - but it looks like most ECU's detect a misfire from how the crank wheel moves, not the knock sensor, so it's probably moot.
Old Sat, Jun-23-2018, 08:56:14 PM   #19
bigjae1976
Definitely open to ideas!
Old Sat, Jun-23-2018, 09:09:09 PM   #20
mrgizmo04
mrgizmo04's Avatar
Might as well look at cam sensors and the crank sensor.
'05 M3 6MT coupe
Discussing Misfire Issue - Cyl 6 in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
