Old Tue, Jan-15-2008, 08:28:53 PM   #1
phantom3
Reputation: 0 phantom3 is on a distinguished road
Default Misfire detected , Cyl #2
I haven't driven my car in a couple weeks and went to start and well like the thread title it felt like it was running with 5 cylinders . It was extremely rough and i noticed above average condensation coming out of the exhaust pipes . I just toughed it out and it smoothed out to 95 % normal, it still has an ever so slight "rumble" to it . Couple things , 1 .I washed the car a couple times before putting her in the garage (maybe something got wet or got water up the exhaust pipe ) 2. Gas is a month or so old 3. Very recently did the spark plugs (will recheck) 4. Just replaced the radiator and expansion tank and I ran a lean water to coolant ratio , Im in florida ,but it has been near the high 30's . Same with oil , i usually run 10-40 or heavier .
Any ideas to what happened ? Peake code table#16 , code #EF
Any help or comments is greatly appreciated
SOLD
Jump to top phantom3 is offline   Reply With Quote
Old Tue, Jan-15-2008, 08:43:04 PM   #2
phantom3
Odd thing is no CEL on dash. I just searched , so I think I know where to look. I just freaked and made a thread before searching.. lol .
SOLD
Old Tue, Jan-15-2008, 08:46:14 PM   #3
_XeRo_
Enthusiast
_XeRo_'s Avatar
Reputation: 0 _XeRo_ is on a distinguished road
I would double check your spark plugs (specifically #2). Make sure they are all properly seated and torqued to spec. (18.4 ft-lbs.)
Jump to top _XeRo_ is offline   Reply With Quote
Old Wed, Jan-16-2008, 04:18:49 AM   #4
dust4life
I hope you like drinking and sarcasm
dust4life's Avatar
Reputation: 0 dust4life is on a distinguished road
same issue, misfire in #6 with no CEL did the coils plugs and a CPS, ran beautiful for a day then started misfiring again. Went on vacation for a week started it up and it ran perfectly smooth for 15 mins...... havent touched it since, i'm too scared. Somethings loose somewhere, but i cant figure out where
Jump to top dust4life is offline   Reply With Quote
Old Wed, Jan-16-2008, 04:37:18 AM   #5
Brandon318
Reputation: 0 Brandon318 is on a distinguished road
Unfortunately, unlike wine, fuel doesn't get better with age; I'm guessing that it's the aged fuel.
Empty what gasoline you can, replace the fuel filter, fill with high-octane gas, and drive. See if that cures it.
Otherwise, take it to an indy BMW shop and have them hook it up to their GT-1 computer. That will let you know what's going on.
/// Brandon
Jump to top Brandon318 is offline   Reply With Quote
Old Wed, Jan-16-2008, 05:55:53 AM   #6
M3cosmos95
I've never even been to Mt. Vesuvius!
M3cosmos95's Avatar
Reputation: 0 M3cosmos95 has a spectacular aura about
lol gas doesn't go bad after a month...
Ansel
MY EX-///M3 || Vanos DIY || 200k ///M Club:(ask me for membership!) || Supercharged ///95 Club(ask me for membership!)
Jump to top M3cosmos95 is offline   Reply With Quote
Old Wed, Jan-16-2008, 03:03:37 PM   #7
Brandon318
LOL, I know it doesn't go bad bad, but it doesn't hurt to give this a go.
/// Brandon
Old Wed, Jan-16-2008, 04:49:05 PM   #8
phantom3
Yeah, that cylinder near the firewall can sometimes be tricky to torque down properly .
SOLD
Old Wed, Jan-16-2008, 05:08:28 PM   #9
TGBimmer
Reputation: 0 TGBimmer has a spectacular aura about
If it's an undertorqued spark plug, then you would hear a bunch of blow-by at each compression stroke. If no noises, you could remove the plug on the #2 cylinder and look at it. Make sure the electrode isn't broken. Check for good spark by having someone turn the engine over while you watch the plug. Hold it with an insulated pair of pliers and make sure the coil is still attached.
Good luck.
TGBimmer
95 M3 Coupe alpinweiß III - Sold, I will miss her
04 M3 Carbonschwarz, 6M, Cinnamon Leather
15 M3 Silverstone [the Beast]
Jump to top TGBimmer is offline   Reply With Quote
Old Tue, Feb-05-2008, 01:08:49 AM   #10
///M325i
Reputation: 0 ///M325i is on a distinguished road
my 325 misfired and i couldnt figure out what it was.....so i ran fuel injection cleaner, new spark plugs, new ignition coil boots, and oil change and everything was perfect
Jump to top ///M325i is offline   Reply With Quote
Cylindar Misfire + EVAP large leak detected bigneil E36 M3 (1992-1999) 11 Tue, Feb-28-2006 05:05:05 PM
Icelink not detected GreyMatter Audio/In Car Entertainment (I.C.E.) 1 Wed, Oct-05-2005 05:34:15 PM
are all E36 6-cyl headers the same? jmitro E36 M3 (1992-1999) 4 Tue, Aug-09-2005 12:27:19 AM
M3 6 cyl. compared to other 6 cyls. fst twch E46 M3 (2001-2006) 2 Thu, Jan-02-2003 02:32:56 AM
Large EVAP detected SanfordW E36 M3 (1992-1999) 0 Thu, Jul-04-2002 04:29:00 AM
Discussing Misfire detected , Cyl #2 in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
