Old Mon, Mar-03-2008, 01:06:43 AM   #1
sam Hsu
sam Hsu's Avatar
Reputation: 0 sam Hsu is on a distinguished road
Default detected oil leak.. help
hello, in the process of changing my oil today, I notice an oil leak running down the edges of the block or connecting point to somthing/tranny? there is a threaded rod protruding (almost like an ear where you bolt-on to-I guess) without a nut and I dont know if that would cause the leak? I was able to see this through the vents on the alum engine shield/nest to oil pan drain dust cap. I know i dont make much sense but this is best I can do. any help would be great... I did try to take pictures but digital took a crap! thanks in advance.
Jump to top sam Hsu is offline   Reply With Quote
Old Mon, Mar-17-2008, 11:24:36 AM   #2
Deric
Reputation: 0 Deric is on a distinguished road
JUST CURIOUS if the problem was solved. I too had a leak. I found the problem which was the breather which was changed along with a seal. then i had it fixed and again i had a leak and found another leak coming from what appears to be coming from a pressure bolt on the block with a Teflon disk. I ordered this part and should be receiving it today ..
Jump to top Deric is offline   Reply With Quote
Common oil leak? Oil Pan or rear main seal? ///tonic E46 M3 (2001-2006) 54 Tue, Feb-22-2011 04:26:44 AM
E46 Oil Pan Gasket Leak and diff. leak. UKtRAINE3 E46 M3 (2001-2006) 5 Thu, Aug-06-2009 07:05:42 PM
oil leak detected rear of E46 M3 valve cover? sam Hsu Faults, Fixes and DIY 0 Sat, Oct-14-2006 01:12:43 AM
Cylindar Misfire + EVAP large leak detected bigneil E36 M3 (1992-1999) 11 Tue, Feb-28-2006 05:05:05 PM
Fault Code FB - EVAP small leak detected 1999 Dinan M3 E36 M3 (1992-1999) 3 Thu, May-05-2005 03:09:32 AM
Discussing detected oil leak.. help in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
