Old Sun, Dec-13-2009, 04:40:03 PM   #11
///M3THOD
///M3THOD's Avatar
Reputation: 0 ///M3THOD is on a distinguished road
Originally Posted by hogger453 View Post
For future ref. Iv'e done four header jobs on the M3.
Number it like this:
#1 front bank
#2 rear bank
#3 front mate
#4 rear mate
The evens and odds always stay together. Works for me
If you keep driving the way you are you're going to burn up your exhaust valves.
Cats are crucial. The ECU is not going to learn the car the way it is. The peramitters are just not there. If your going to run it without cats get software ASAP.
This is not completely accurate... not only am I running the car with no cats, but the car has a smooth powerband and no SES. I have put several thousand miles on the car and it's very driveable and smooth. The ECU will learn the optimal conditions to operate the car at within a certain range, but I believe your correct about the parameters. I don't think the ECU can compensate the fuel trims drastically enough to optimize performance with no cats. I don't know though, my car is pretty smooth, I guess the only way I could compare would be with some software.
'04 TiAg ///M3 SMG vert
| JVT headers || AP section 1 || KSport || BMW Motorsport 4.10 || Depo Smoked Corners || Custom ski pass Alpine Type R|
| UUC RTAB's/FCAB's/tranny mounts || Auto Technik matte grills || Orion V2's || Anthracite Powdercoated OEM ZCP's || EAS monochrome badges |
Jump to top ///M3THOD is offline   Reply With Quote
Old Sun, Dec-13-2009, 07:20:23 PM   #12
Jumbosock
Reputation: 0 Jumbosock will become famous soon enough
I found this diagram on a different thread. Make sure Bank 1 sensor is attached to the front header. Bank 2 sensor is attached to rear header.
Jump to top Jumbosock is offline   Reply With Quote
Old Sun, Dec-13-2009, 10:34:26 PM   #13
CRIIM44
CRIIM44's Avatar
Reputation: 0 CRIIM44 is on a distinguished road
most likely o2's hooked up backwards like everyone else said
as far as a vacuum leak uniqueM3 check all lines and anything you could have touched
Jump to top CRIIM44 is offline   Reply With Quote
Old Mon, Dec-14-2009, 12:12:49 AM   #14
achtungM3
achtungM3's Avatar
Reputation: 0 achtungM3 is on a distinguished road
tomorrow i will get it on a lift and swap the o2 sensors. i will let you guys know the results. thanks for all your help
Jump to top achtungM3 is offline   Reply With Quote
Old Mon, Dec-14-2009, 09:52:39 PM   #15
achtungM3
achtungM3's Avatar
i checked today and i have the o2 sensor plugged in the right headers. the miss firing is hit and miss still. when it smoothes out the car runs really great. i am thinking i have a bad o2 sensor.
also i am thinking of just getting the custom performance innovations crt section 1, which will have post cat bungs. i wonder if i can get them to weld in a bung for my egt sensor?
Old Tue, Dec-15-2009, 05:27:12 AM   #16
///M.EngT
Reputation: 0 ///M.EngT is on a distinguished road
man.... headers seem like a huge headache..
Jump to top ///M.EngT is offline   Reply With Quote
Old Tue, Dec-15-2009, 05:38:14 AM   #17
///M3Turk
///M3Turk's Avatar
Reputation: 0 ///M3Turk is on a distinguished road
Turkey
+1....
Firat
Jump to top ///M3Turk is offline   Reply With Quote
Old Tue, Dec-15-2009, 08:30:35 AM   #18
uniqueM3
uniqueM3's Avatar
Reputation: 0 uniqueM3 is on a distinguished road
Well that's the thing that I didn't install them. The missfire is fixed for now but the motor is still running lean. And ses light still on
but yeah headers is getting to be a headache and just money to figure out if it has any problems.
Jump to top uniqueM3 is offline   Reply With Quote
Old Tue, Dec-15-2009, 09:47:34 AM   #19
e46comptM3
e46comptM3's Avatar
Reputation: 0 e46comptM3 is on a distinguished road
+1....hopefully the power is worth it the struggle
Jump to top e46comptM3 is offline   Reply With Quote
Old Tue, Dec-15-2009, 10:46:43 AM   #20
Custom Performance
Custom Performance's Avatar
Reputation: 0 Custom Performance is on a distinguished road
On the Euro M3, the EGT port is on section 1, before the cat. If you don't have the EGT probe installed, you will get a CEL, but the car should run OK. I have built a few Euro CRT where the EGT port is on the front of the cat on the CRT. Like this...
With this setup, it's just plug and play. You would just need to ensure the pre and post O2s are in the right location. Then, install the EGT probe. No CEL, no rasp, and no software needed. The challenge is finding an EGT port to weld onto the CRT cat. The EGT port pictured above come off a set of OE headers. If you have a old set of OE headers, and can cut the EGT port off, then I can build you a Euro CRT.
Jack
BMW M3 Performance Parts
We know the parts - not just the part number
For questions, quotes, or inventory checks...
Call or TXT me @ 540.903.3405
Email @
sales@custom-performance.net
FREE SHIPPING ON EVERYTHING
Visit our website - Custom-Performance.net
Jump to top Custom Performance is offline   Reply With Quote
cats, euro, headers
Discussing euro headers no cats... in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
