Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > M3Forum Marketplace > Parts for Sale/Wanted
Parts for Sale/Wanted Post your Parts Wanted, and non commercial bmw related items for sale. We ask that companies selling goods become a Sponsor to advertise your goods.
Old Wed, Nov-20-2019, 06:22:50 AM   #11
HassanEido
HassanEido's Avatar
Lebanon
Default Re: HTE Performance Tuning Group-Buy -- Let's get these cams dialed in!
Originally Posted by SamGrant951 View Post
I was going to reach out to Hassan directly so this is a plus however I prob wont even have the cams installed for 4+ months until the weather is starting to break again here...away for the winter now.
Questions:
1) My car is an E36 w/ S54 swap currently running Alpha N. Im guessing that's no problem but probably a few different settings and a few more things to delete in the software vs e46 chassis. Just checking to make sure he is cool with that or if I should just contact him offline and stay out of the group buy.
2) Dyno preference - Does he care? Not all dynos can apply a load which is preferred when tuning. I can get to one pretty easily but everyone else might not be able to - just throwing that out there.
3) Estimated dyno time to book, 2 hours? I mean Im sure he has a map thats "pretty close" out of the box for most setups and Im guessing majority of time is spent dialing in, just curious how often that usually takes.
Thanks!
1)not a problem
2)I don't really care about dyno types, since I use dynos for their delta measurement and to plot afrs vs rpms on the graph. But I usually like to use dynojet since this helps compare the output to other cars with similar mods/tune. So it's a better indication to know if the car is running well or not in comparison to so many others that usually and predominantly use this dyno type
3)usually 1 to 2 hours tops should cover it. Yes my tune targets are already pretty much dialed in*, but each car is a little different (exhaust /intake setups affect vanos targets) so the tunes end up being custom to each car. Alpha N cars require a bit more work in afr tuning, but that falls into that time estimate also
Sent from my JKM-LX1 using Tapatalk
PM for performance tune requests
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
385.7 whp 288 wtq
Old Wed, Nov-20-2019, 06:24:31 AM   #12
HassanEido
HassanEido's Avatar
Lebanon
Originally Posted by Mr.wReckless View Post
For us who live 10 hours away from the nearest dyno and overseas, any solution to a remote tune? If even only for something that will be somewhat closely in the ballpark so that it'll at least start and run fairly decent?
Regards
Yes. I got you covered, but we need a wideband to have something to work with and get afrs dialed in
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
385.7 whp 288 wtq
Old Wed, Nov-20-2019, 06:31:02 AM   #13
rbg
Reputation: 0 rbg is on a distinguished road
Hassan, would you recommend going map or alpha-n? I always thought map is the way to go, but I donít know shit if being honest
Jump to top rbg is offline   Reply With Quote
Old Wed, Nov-20-2019, 06:35:07 AM   #14
HassanEido
HassanEido's Avatar
Lebanon
Map is always the better option. Alpha N works too, but cold starts are a bit on the rough side for about 30 seconds in cold weather, but it runs just great otherwise. I personally run alpha N on my own car.
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
385.7 whp 288 wtq
Old Wed, Nov-20-2019, 07:14:24 AM   #15
C///M
Originally Posted by Dr M3an M3 View Post
Let me have Hassan chime in on what options exist for this case. Depending on the cam selected, offering a pre-configured tune MAY be possible. To my understanding, the 280/272 will drive without a retune (although it won't be optimized to take advantage of the newly installed cams) while from what I understand, the 288/280 will throw codes and won't run correctly without being properly tuned.
I got a couple of Paul Claude's "off-the-shelf" tunes (w/CSL map sensor) when I installed my airbox and SS v1s, the 2nd tune being for the addition of the 288/280 cams. So you can either go PC's OTS route or I'm sure Hassan can put together a generic tune for the group as well.
My only concern is that I specified Schrick's cam specs at the time and I'm not sure if the cam sync offset values are the same between Schrick and Cat Cams. I feel like last time I looked, a couple were ever-so-slightly different.
Sent from my Pixel 2 XL using Tapatalk
Jump to top C///M is offline   Reply With Quote
Old Wed, Nov-20-2019, 07:18:59 AM   #16
C///M
well, 280 272 cams idle like stock. That car was probably mistimed or something else wrong with it.. But a tune is definitely a requirement as the car runs the risk of running too lean, it will be down on power too. But it should be fine to drive it on part throttle to get it tuned
Hassan - do you know offhand if the cam sync offset values are the same between Schrick and Cat's 288 intake / 280 exhaust cam setups?
Old Wed, Nov-20-2019, 08:11:35 AM   #17
HassanEido
HassanEido's Avatar
Lebanon
Yes they are sightly different than the schricks, but the schrick offsets should work, I've had customers use them before with no issues. They are too close for it to really matter, but it's something to consider
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
385.7 whp 288 wtq
Old Wed, Nov-20-2019, 02:58:07 PM   #18
SamGrant951
SamGrant951's Avatar
Reputation: 0 SamGrant951 is on a distinguished road
1. Dr M3AN M3
2. EliasZ
3. Whips333
4. rbg
5. dutchhome
6. samgrant951
Thanks Hassan for the quick reply, list updated.
86 951 - VEMS
95 M3 LTW - S54 http://www.bmwmregistry.com/detail.php?id=15735
17 GTI
Sold: 97 M3/4/6 Byzanz, 99 M Coupe, 02 M Coupe
Jump to top SamGrant951 is offline   Reply With Quote
Old Wed, Nov-20-2019, 03:15:52 PM   #19
heinzboehmer
heinzboehmer's Avatar
Reputation: 0 heinzboehmer is on a distinguished road
This is great. It'll probably be a while until my car has cams (and an airbox and exhaust) but I'll definitely contact you Hassan once it does, even though that means I'll miss the group buy.
Jump to top heinzboehmer is offline   Reply With Quote
Old Tue, Nov-26-2019, 06:37:29 PM   #20
Dr M3an M3
GroupBuyingPower@outlook. com
Dr M3an M3's Avatar
BUMP!
IG: DrM3anM3
Mods: Genuine OE CSL Bumper, Both Karbonius and Streamline CSL Airboxes, OE CSL Snorkel w/ working Flap, OE Map Sensor + OE Air Rail, Paul Claude Custom Tune, CSL Engine management with CSL converted DME, Supersprint V1 Stepped Headers w/ Oversized HJS Race Catted section 1, SS 2.5" Twin-Piped Oversized Custom section 2, Custom Oversized Supersprint muffler, Catcam's Billet 280/272 cams, WPC treated rod-bearings, VinceBar (weld) + Redish Plates, Full Beisan VANOS lockdown, BBS LMs w/ PSS, Brembo GT6 (front) + GT4 (rear) BBK, CSL style CF diffuser, Vorsteiner CF CSL Bootlid, CSL SMG Engine DME tune, CSL '255' SMG DME tune, SMG Pump Relocated.
OE CSL Bootlids, Supersprint Headers/Exhaust thread, New Supersprint Oversized Twin-Piped Section 2, HTE Tuning Group-Buy OE CSL Wheel
Discussing HTE Performance Tuning Group-Buy -- Let's get these cams dialed in! in the Parts for Sale/Wanted Forum - Post your Parts Wanted, and non commercial bmw related items for sale. We ask that companies selling goods become a Sponsor to advertise your goods. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
