Old Thu, Feb-16-2017, 01:49:17 AM   #11
E30toF30
E30toF30's Avatar
Reputation: 0 E30toF30 is on a distinguished road
Default Re: Installing AGK Quickshifter - What Else Should I Do While I'm at It? What Small
Originally Posted by bigjae1976 View Post
10 cent plastic washers.
Yes...you can spend $125 for a DSSR to fix a problem that a 10 cent washer can fix.
So something like this? Maybe get a few thinner ones and stack a couple of them up if needed?
Jump to top E30toF30 is offline   Reply With Quote
Old Thu, Feb-16-2017, 01:58:10 AM   #12
CrookedCommie
Captain Slow
CrookedCommie's Avatar
Bulgaria
Originally Posted by E30toF30 View Post
Hey,
DO you mind snapping some pictures of what these square headed bolts look like for mounting the shifter?
I've emailed AKG a few days ago but have not gotten a response yet. Will email them again but thought I might reach out this way too.
Thanks!
Hey bud, the shifter is installed and I don't wanna jack the car up, but the bolts look like this - what you'll need is one big enough to fit the three square holes in the transmission tunnel around the shifter where the AKG mounts to. This just makes it easier to mount it yourself from up above. If you got a helper you can use any bolt head with a lock nut big enough to fit through the shifter mounting cutouts.
I believe it's called a cariage head bolt:
Old Thu, Feb-16-2017, 01:59:09 AM   #13
E30toF30
E30toF30's Avatar
Just getting ready to do this install.
I've removed the bottom covers off the car and went out to grab an E14 socket to remove the midpipe.
I'm looking at some of the DIY's on MadRussian. They have 3 DIY's for different SSK's (Autosolution, Rogue, UUC). Too bad not a specific one for AKG.
Any of these should be good enough for me to follow along correct? Or is one better than the other for me to follow? There seem to be a lot of additional parts mentioned in these DIY's (mainly the Carriers). Since I'm not changing my carrier, I just skip this section right? Or do I need to remove my carrier in order to install my SSK/Shift lever?
So far i've been following the Autosolutions DIY. And one of the steps is to remove the tranny brace. Looks like this would be the perfect time to replace the OEM tranny bushings with my AKG 75D ones right? lol
Thanks all!
Old Thu, Feb-16-2017, 02:00:20 AM   #14
CrookedCommie
Captain Slow
Bulgaria
And here's your plastic washer part # if you aren't sure which ones to get:
25111220439
Old Thu, Feb-16-2017, 02:01:22 AM   #15
E30toF30
E30toF30's Avatar
Oh ok. So a standard lock nut and bolt is sufficient if I have a helper to either in the car or under the car. But the square bolt head prevents the bolt from spinning so I could do it as a one man show.
Got it. Thanks! I'll see if I can find any of these at the hardware store/Home Depot.
Thanks!
Old Thu, Feb-16-2017, 02:02:27 AM   #16
CrookedCommie
Captain Slow
Bulgaria
Thanks all!
Yeah you'll remove the carrier - you won't use that at all with the AKG shifter. The AKG just mounts to the selector rod which mounts to the gearshift rod joint, everything else get rid of.
Old Thu, Feb-16-2017, 02:05:14 AM   #17
CrookedCommie
Captain Slow
Bulgaria
Here's the diagram so you can visualize it.
http://www.realoem.com/bmw/enUS/show...diagId=25_0375
Old Thu, Feb-16-2017, 02:06:25 AM   #18
E30toF30
E30toF30's Avatar
Oh damn. I dont even use a carrier with my shifter? interesting. Good thing I checked!
Thanks for the link on the washer! I'll probably just end up swinging by the dealer to pick up a couple....they will probably rape me and charge $1 each or something stupid.
Awesome support. Much appreciated!
Old Thu, Feb-16-2017, 02:08:10 AM   #19
CrookedCommie
Captain Slow
Bulgaria
NP, shoot me a PM if you got any more questions and I'll try to help out.
BTW - I called up AKG today to order some dssr pins, and it went straight to VM stating that they had a family emergency and will be a little bit slower to respond and ship.
Old Thu, Feb-16-2017, 02:36:13 AM   #20
bigjae1976
Just something pretty thin. A thin wave washer might work but I just use the OE yellow plastic washers. Typically, it's just 1 on each side of the shifter rod.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Discussing Installing AGK Quickshifter - What Else Should I Do While I'm at It? What Small Par in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
