Old Wed, Feb-22-2017, 02:45:49 PM   #41
E30toF30
E30toF30's Avatar
Reputation: 0 E30toF30 is on a distinguished road
Default Re: Installing AGK Quickshifter - What Else Should I Do While I'm at It? What Small
Originally Posted by bigjae1976 View Post
Did you try shifting it though the gears yet?
I did go through the gears... Didn't change anything unfortunately
Sent from my ONEPLUS A3000 using Tapatalk
Jump to top E30toF30 is offline   Reply With Quote
Old Wed, Feb-22-2017, 02:46:25 PM   #42
E30toF30
E30toF30's Avatar
Originally Posted by CrookedCommie View Post
Hmm yeah, can you find a stock lever close by to try? That seems to be the only thing left.
Don't get frustrated, the shifter is totally worth it!
No stock lever around. Just the e60 lever.
Old Wed, Feb-22-2017, 09:13:26 PM   #43
bigjae1976
Originally Posted by E30toF30 View Post
Thanks for the tip. After a lot of reading I decided to not do the dssr as a lot of consensus was that it made no difference compared to oem selector rod with the added yellow washers.
As for the motor and tranny Mounts, I installed the akg 75d tranny while I was doing this ssk install and was going to do the motor Mounts after I was done the ssk install (also akg 75d) .
Maybe I'll take a break from the ssk for now, do the motor Mounts first and then come back to the ssk to see if it makes a difference? That could give a me a breather and get some forward momentum going again maybe....as long as the motor Mounts dont give me more headache hahaa
If a motor mount is collapsed then I could see how it would cause the shifter to lean.
At least it's 1/10th the pain to remove/install the shifter now!
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Sun, Jun-24-2018, 03:32:40 AM   #44
M3AN ONE
Reputation: 0 M3AN ONE is on a distinguished road
Any update on how the AKG tranny and motor mount install went and how they function over stock. Thinking of installing them when I do my SMG to 6 speed shop.
2003 M3 Track/HPDE
2018 Triumph 765 RS
2017 Ram 1500 Daily
94' Six Spd 800rwhp *Gone
2005 M3 convertible *Gone
1995 850 T5R *Gone
Jump to top M3AN ONE is offline   Reply With Quote
Discussing Installing AGK Quickshifter - What Else Should I Do While I'm at It? What Small Par in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
