Old Tue, Apr-03-2007, 04:32:39 AM   #1
mat3
Reputation: 0 mat3 is on a distinguished road
Default compression test help
I recently got a compression test at my local shop. I wanted to make sure my 99m3 with 70k mile engine was up for some FI. But I'm a little confused about the results. Here they are:
1: 138
2: 139
3: 142
4: 134
5: 136
6: 137
When I first saw the numbers I thought it looked good because they were pretty close.
Then I started looking at other m3 reads. They were all around 190. It was below freezing when they did the test, could that have factored in? Has anyone else seen similar reads in cold weather?
The engine runs strong. So, I'm not sure if that was an accurate read. Please Help.
Jump to top mat3 is offline   Reply With Quote
Old Tue, Apr-03-2007, 04:35:03 AM   #2
97estorialM3
It's "Estoril"
97estorialM3's Avatar
Reputation: 0 97estorialM3 is on a distinguished road
The numbers don't vary too much, which is good. as long as they are within somewhere around 5 of each other you are looking good. It was under my impression that compression under 140 was bad though. I am sure someone can clarrify this.
-Justin
2004 Pontiac GTO Black/Red 6 Spd
Ms4 camshaft 239/242 .649 .609 lift/Chromoley hardened 7.4 pushrods/Comp 921 double valve springs
Pacesetter coated LT headers/off road mid pipes
Powerbond underdrive pulley
CS Performance intake with K&N filter and relocated IAT
NGK TR 55 spark plugs/taylor spark plug wires
GMM Race short shift kit
Nitto 275 555r's
160 degree thermostat
Ls6 timing chain
6000k HID kit
Tuned by Outlaw Motorsprts
More coming soon
1997 Estoril/Black M3 5spd coupe
Jim Conforti Shark Injector, K&N CAI, ///M stitching Shift boot
Sold
1992 Honda Prelude Black/Black 5spd
Full exahust (header, downpipe, cat back), intake, chip, still slow
Sold
Jump to top 97estorialM3 is offline   Reply With Quote
Old Tue, Apr-03-2007, 04:45:37 AM   #3
Exacc
Reputation: 0 Exacc is on a distinguished road
I was told that different measuring devices read differently...similar to dynos, where you can't compare one from the other.
I was told that as long as it reads realtively close to each other then it should be fine. What are the odds that all 6 cylinders are equally bad?
Jump to top Exacc is offline   Reply With Quote
Old Tue, Apr-03-2007, 04:51:10 AM   #4
95RogueM3
^Needs More Garage Space..
Reputation: 0 95RogueM3 has disabled reputation
Usually people will say a compression test was good so long as the numbers are above 190 or 195 AND have little variance. Did the shop check each cylinder a few times? Ive seen a test done where 1 cylinder of the 6 came up at 130 the first time around, and then we went back and checked it again it was closer to 200. (this was only 1 of the 6, though and not all 6)
Those #s are low enough that I would be concerned something is wrong with your motor. Im not sure if you can run a leakdown on a motor that is still installed (Im pretty sure you can) but that would be the next step and would tell you if your rings are no longer sealing properly, etc
'98 M3 Sedan - Built 2JZ Swap - 915whp, 791wtq
'95 M3 - 37k Miles
Jump to top 95RogueM3 is offline   Reply With Quote
Old Tue, Apr-03-2007, 04:52:07 AM   #5
thedood
Can't touch this
Reputation: 0 thedood is on a distinguished road
probably just different units. a pressure gauge wouldn't vary by 30+%; not one that is any good, anyway.
like exacc said, though, your cylinders are close to one another, with a max spread of 5% or so, most falling right in between it looks like. i'd say you're fine, but check with the shop to see what kind of gauge they use (units).
Jump to top thedood is offline   Reply With Quote
Old Tue, Apr-03-2007, 04:55:48 AM   #6
PhYrE
Mmmmm-3
PhYrE's Avatar
Reputation: 0 PhYrE is a glorious beacon of lightPhYrE is a glorious beacon of light
There are several factors:
- strength of your starter motor - remember, if your starter isn't performing optimally, it's not cranking as hard
- accuracy of the gauge - need I say more?
- number of cranks - the difference between 4 cranks and 8 cranks could be a good 80+psi, as they build pressure. You won't build up to 190+ on 4-5 cranks, and in some cases it may take you more. If the shop went to 3, 4, or 5 and then stopped, then that's why your figures are low.
- strength of the battery - battery will crank the starter motor harder
- tightness of the gauge and its fittings I had a reading 30 under from not quite tightening my first one down properly. It's hard to tighten these, as a hose comes out of them, so you're finger-tightening by twisting a hose and hoping for the best (even attachments you then twist in the hose). This is more of the person doing them
- whether all spark plugs are out - Some believe that you should leave the remaining 5 spark plugs in place. This pulls your numbers down, as you're slowing your compression stroke by some other cylinder going through a portion of its (in a 4-cyl, each cylinder will be in a different stage, but in a 6, it can matter). Keeping them all out means that you're testing the compression of one cylinder and removing the other variable.
- throttle body open - We found no change between keeping it open or closed, but it can't hurt.
In general, there's lots of variables there that can affect the actual numbers. You are looking really for consistency, as if done the same on all six, the numbers should be around the same. Yours are.
That being said, lower compression numbers could mean general wear without any particular cylinder being down, but with any reasonable amount of mileage, I wouldn't worry about it. If the motor pulls strongly, then it's just the testing procedure- but since they're all the same, you should be okay.
If I remember correctly, 11 bar, so 1 bar = 14.5037738 pounds per square inch so 160psi. I think 11 was the number I posted up a few days ago. Check that search.
PS: Compression tests is a great DIY. You can almost always find someone willing to dry-start your car for half an hour.
-M
2008 BMW M3 Coupe (White on Fox Red)
CF everything / Lowering springs / EDC / Tint
AA Short Shifter
SOLD - 1997 BMW M3 Coupe (Estoril Blue]
VFE Supercharger Stage 1
Bilstein Sport Shocks/Struts
Euro-M3 Springs
Two-Piece Euro Rotors
JVC KD-AR5500 Headunit
Euro Headlights w/ TSX Projector Retrofit and HIDs
VDO Gauges
Harmon Kardon Amplifier retrofit
18-button OBC conversion retrofit
BMW Euro (clear) corners, tails, sidemarkers
ROH RT wheels / (f) 245/40/17 (r) 265/40/17 Toyo T1R
Jump to top PhYrE is offline   Reply With Quote
Old Tue, Apr-03-2007, 03:03:35 PM   #7
mat3
Thanks for all the good info guys. Like Exacc said what are the chances of having all of the cylinders low? Anyone know? Especially one with only 70k on it. I've had friends that had cars with bad compression (1 myself too), but its always a couple cylinders that are low. I've owned a couple bmws so I somewhat know how these cars should drive, so you would think I would know if there was something that wrong...and it wouldnt pull as smooth as it does, right? PHYRE maybe I'll just do it myself when I have time. Thanks
Old Wed, Apr-04-2007, 04:01:26 AM   #8
mat3
just did a compression test myself. here are the numbers
1:196
2:196
3:199
4:199
5:197
6:198
Looks pretty damn good to me!!
I think the shop must have not cranked it enough.
Thanks Guys!
Old Wed, Apr-04-2007, 04:36:48 AM   #9
PhYrE
Mmmmm-3
PhYrE's Avatar
1:196
2:196
3:199
4:199
5:197
6:198
Yup- that's likely all good. It is an easy and fun DIY as you saw, though you really feel for dry-starting the car. Without the fuel pump fuse, fuel pump relay fuse, and DME fuse, the car just seems sad.
Again, your numbers are consistent. Who knows which of the factors they did differently- the cranking times is very likely, as it's easy to have a 'method'.
That being said, neither is right or wrong- a compression test is to make sure your cylinders will take, build, and hold pressure. How you actually go about testing that doesn't matter, but you can't compare different methods. 5 cranks will give you lower results than 8 (or until it stops going up), but gives you the same information.
-M
AA Short Shifter
Euro-M3 Springs
VDO Gauges
Old Wed, Apr-04-2007, 09:26:18 AM   #10
mtpktz.
Reputation: 0 mtpktz. is on a distinguished road
1:196
2:196
3:199
4:199
5:197
6:198
Thanks Guys!
Just curious, how many times did you crank to get these numbers compared to the Mid 130's?
Jump to top mtpktz. is offline   Reply With Quote
Compression/leakdown test scmgoblue E46 M3 (2001-2006) 18 Wed, Apr-04-2018 02:45:12 AM
Compression Test Results. Braymond141 E36 M3 (1992-1999) 19 Wed, Dec-27-2006 05:57:19 AM
Compression test with supercharger help MrBlonde E36 M3 (1992-1999) 0 Tue, Feb-28-2006 05:48:52 PM
Compression Test Results:: resisTm3 E36 M3 (1992-1999) 23 Sun, Sep-05-2004 02:10:10 PM
Discussing compression test help in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
