Old Thu, Mar-15-2012, 10:00:43 PM   #51
jgalaxy
jgalaxy's Avatar
Reputation: 0 jgalaxy is on a distinguished road
Default Re: E46 M3 Brake Cooling Duct Quandary....
Originally Posted by See-Fu View Post
i think porsches come with something like that from the factory. Arn't you really only cooling 1 side of the rotor with something like that, and isn't that bad?
Air is being channeled towards the rotor. I'm not sure how the hose system does anything different.
Track prepped - Oxford Green | A light sprinkle of mods
“I promise you I will listen to what has been said here, even though I wasn’t here.” - George W
Jump to top jgalaxy is offline   Reply With Quote
Old Sat, Jun-30-2012, 11:55:40 PM   #52
mscott7426
Reputation: 0 mscott7426 is on a distinguished road
I noticed a lot of these pics don't have foglight brackets. do you think any of the ducts on pegasus or racerwholesale would work with the foglight bracket?
I just got my M3 and one of the foglights is broken.
Rather than replace the foglight, I'd like to get a duct in there. I would prefer to use a bolt/screw to mount it to the foglight bracket.
Sound plausible?
Jump to top mscott7426 is offline   Reply With Quote
Old Sun, Jul-01-2012, 01:05:54 PM   #53
jmciver
jmciver's Avatar
Reputation: 0 jmciver is on a distinguished road
Your best bet, outside of custom fabrication, would be a Hamann style fog light insert. There are a lot of them on eBay.
James
2005 Imola Red M3 - VF Engineering Stage I Supercharged, Track Prepped, Yet Very Streetable
E46 M3 VF Engineering Stage I Supercharger DIY
Jump to top jmciver is offline   Reply With Quote
Old Fri, Jul-06-2012, 06:22:38 AM   #54
mscott7426
Those keep the foglight right? or can you run them without the fogs?
Old Fri, Jul-06-2012, 09:38:34 AM   #55
jmciver
jmciver's Avatar
Yes, with the Hamman style ones you can keep the fog lights if you wish. Just Google them and you will find plenty of pics, including on eBay.
James
Old Fri, Jul-06-2012, 06:27:45 PM   #56
aznbo187
MCLA
aznbo187's Avatar
Reputation: 0 aznbo187 has a spectacular aura about
If you are looking for solutions that allow you to delete the foglight completely and run a duct, Turner Motorsports and Bimmerworld have that available.
MCLUB | Los Angeles
Jump to top aznbo187 is offline   Reply With Quote
Old Fri, Jul-06-2012, 07:57:31 PM   #57
DEFIspeed
DEFIspeed's Avatar
Reputation: 0 DEFIspeed is on a distinguished road
TO keep or not to keep the fogligh - currently going through the same quandary...thinking about deleting rather than trying to work around keeping them...
'02 ///M3 6MT
FS;
STaSIS Alcon 365mm mono6 BBK
Custom Muffler
- http://youtu.be/eNa0RURHP1c
Jump to top DEFIspeed is offline   Reply With Quote
Old Fri, Jul-06-2012, 07:58:06 PM   #58
Tarmac_E36_M3
If it ain't lightweight, it ain't the right weight.
Tarmac_E36_M3's Avatar
Reputation: 0 Tarmac_E36_M3 is on a distinguished road
Deleted looks better imo.
Current: 1969 Ford Mustang Coupe; 351w (5.8L) carb engine; Champion 4 row radiator; Edelbrock Performer RPM Intake Manifold; Edelbrock 750 CFM Carb; 15" Cragar Wheels; 215/60-15 front tires, 255/60-15 rear tires; Doug Tri-Y Headers; Custom 2.5" Dual Side Exit Exhaust w/Xpipe; MSD 6AL; Electric Fuel Pump; March Performance U/D Pulley Set; Monte Carlo Bar; 3200 lbs.
1995 M3; single 3" exhaust after cats; CF hood; Apex ARC-8 17x9" wheels; Conti DW 245 square; BC Racing Coilovers.
SOLD: E46 M3 SMG; Intrax coilovers; ACPT CF DS; SS V1 Headers/Section 1; Zionsville Type 17 kit; VAC Ultra light pulley set; BMW MS 4.10; Evolve-R Tune; 2980 lbs.
Jump to top Tarmac_E36_M3 is offline   Reply With Quote
Old Fri, Jul-06-2012, 10:05:29 PM   #59
PerkM3
PerkM3's Avatar
Reputation: 0 PerkM3 is on a distinguished road
With the ducting kits that are on the market (BimmerWorld and Turner) the air is forced to the rotor hub forcing it up through the veins which cools both the faces of the rotor from the inside. I believe the scoop method above would only cool the inner face.
Cosmetic/Aero: BW splitter, BW canards, Brooks pro wing, V-CSL bootlid, Tekerbon CSL diffuser, V-GTR hood, CF moonroof delete, CF kidney grills, CF gills, and CF roundels
Suspension/Brakes: MOTON CS 850/450 (rear coilover), GC F/R race sways, RE FCAB/RTAB (track), TMS rear camber arms, GC race camber plates, TMS solid subframe bushings, ZCP F/R rotors, brass caliper guides, BW SS lines, PFC RH665, PFC-01, BW brake ducts/baking plates.
Performance: BW/EPIC Tune, aFe stg2 intake, SS V2 stepped headers, BW race exhaust, TMS pullies, JB Racing clutch/LW flywheel, TMS solid motor mounts, TMS solid trans mounts, BW solid diff mounts, RE shifter linkage, and BW race shifter.
Misc: TMS subframe reinforcement kit, Sparco PRO ADV seat, Sparco side mounts, VAC floor mounts, Kirk Comp. Roll Bar, Schroth Profi III 6-Point harnesses, Jafster shift knob, BimmerWorld 75mm wheel studs, and Enkei NT03+M.
Jump to top PerkM3 is online now   Reply With Quote
Old Thu, Jul-19-2012, 03:13:29 AM   #60
Damian
Reputation: 0 Damian is on a distinguished road
here is what I did and have been very happy. Although I do have one cercern I'd like to hear input on...
1) Hamman knock offs like $20 or $30
2) BW backing plates
3) Ducting similar to what this guy did. I run the hose right from the hamman style duct, cut up the stock duct to get into the undershield and then exit the undershield near the front roll bar. http://www.davidparis.org/coupe/brakeducting.html
It works great and full lock with 265's is not an issue.
CONCERN: I have effectively blocked any air flow that might have come into the intake via the drivers side duct. I believe this was mentioned earlier with regards to getting air for a S/C. I don't have a S/C so do I need to be concerned about getting air from here for the intake? And if so, how?
Jump to top Damian is offline   Reply With Quote
Discussing E46 M3 Brake Cooling Duct Quandary.... in the M3 Track: Racing and DE Forum - Best mod for speed is learning to get the most out of what you currently have. Tracks and DE's is the place to start! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
