Old Thu, Jul-08-2010, 05:21:36 AM   #1
cw
Reputation: 0 cw is on a distinguished road
Default Xenon bulb finally dies after 8.5 years...
Should they last this long? Or longer? Anyhow I'm in the market for a replacement set. I'm not sure what to replace it with. 35w or 55w? I've got bi-xenon, so is that any different?
Thanks!
Jump to top cw is offline   Reply With Quote
Old Thu, Jul-08-2010, 06:54:30 PM   #2
NikolaiD
NikolaiD's Avatar
Bulgaria
In theory the xenon bulbs should last longer than the life of the car. Does BMW sell replacements at all?
MSS54 Error Codes
(work in progress)
Old Thu, Jul-08-2010, 07:52:08 PM   #3
pardo
Not A Super Robot
pardo's Avatar
Reputation: 0 pardo is on a distinguished road
did the bulb just go out? or did it explode?
02 M3 Titanium Silver
Mods AST 4100, Hyperco 600F/750R, H&R Sways, Evolve-R Stage 1, Dinan Exhaust, 18x9.5 Volk RE30 Gunmetal, Yokohama AD08, Vorshlag Camber Plates, Ferodo DS2500, StopTech SS, ZCP Rotors, Turner 12.5mm Spacers, Rogue RTAB Shim, HD RSM, Turner Endlinks, Turner Stud Kit, Kics 40, GSP Pedals, CF Trunk, CF Rear Diffuser, CF Front Splitter, CF Dash Overlay, CF SMG Dome, Euro Tray, AMT Stealth Camera Mount, Matte Black Front/Side Grille, Blackout Decals All-Around, Black Vinyl Roof Overlay, Mycarr Angel Eyes, Yellow Fogs, Escort 9500ix
Jump to top pardo is offline   Reply With Quote
Old Thu, Jul-08-2010, 08:04:24 PM   #4
mugenh22a4
เป็นคนจีน
mugenh22a4's Avatar
Reputation: 0 mugenh22a4 is on a distinguished road
Hong Kong
assuming they never get turned off.
The life estimates are based on continuous use. Constant off / on dramatically reduces the life of the bulb. That's why I never leave my light switch on "auto"
2008 ISF, Smokey Granite Mica on Black
[IMG]http://img25.imageshack.us/img25/780/dsc3038mod.jpg[/IMG ][IMG]http://img641.imageshack.us/img641/6913/dsc2821edited.jpg[/IMG ]
Jump to top mugenh22a4 is offline   Reply With Quote
Old Thu, Jul-08-2010, 08:37:42 PM   #5
NikolaiD
NikolaiD's Avatar
Bulgaria
That is a great point, I didn't think about that when I posted.
OP, how do you know it's the bulb? It is more common for ignitors to go bad than bulbs. And those are for sure replaceable.
MSS54 Error Codes
(work in progress)
Old Thu, Jul-08-2010, 09:27:19 PM   #6
keca10
Useful Posts: 5
keca10's Avatar
Reputation: 0 keca10 is a jewel in the rough
Thanks!
Mine died after 5 years.
When you say 35w or 55w that makes me think you are talking about halogens. Those don't work with your housing/electronics. The 9006 fits the fog light however.
Replace it with a stock xennon pn: 07119904790. They are about $175 bucks from a dealer.
Wear nitrile gloves when you do it if you want it to last at all. These suckers have thin glass and they get really hot. The glass will crack if you have oil on it.
If you don't know what you are doing have the dealer diagnose your problem since your 175 dollar bulb isn't returnable if it turns out your ballast died and not the bulb.
You can switch them around to see if the other bulb works in the same housing. if it doesn't - it's your ballast. again... wear nitrile gloves.
good luck
Jump to top keca10 is offline   Reply With Quote
Old Thu, Jul-08-2010, 09:35:18 PM   #7
keca10
Useful Posts: 5
keca10's Avatar
The bulbs still degrade over time quite a bit. Lifetime is sometimes defined as 70% or 50% original brightness - so the bulb can be considered dead even though it still lights up. Most of us wait until it catastrophically dies (different mechanism).
These Xennons continuously drop in luminance output over time.
My guess is that most of them reach 75% brightness in 1200 hours, and 50% in 2000 hours (which is not that bad).
There is probably a trade off of output vs lifetime. So some models might be designed to last longer than others.
Old Thu, Jul-08-2010, 09:44:45 PM   #8
RSM333
M Therapy
RSM333's Avatar
Reputation: 0 RSM333 is on a distinguished road
I thought a couple of times my bulb went out on me too. It turned out to be my habit of backing out of the garage and turning on the headlights right at a slight bump. I think if there's an interruption while the auto level has a chance to adjust, for some reason the passenger headlight stays off. Only parking and shutting off and on the car, will it start working again. Happen to me like 3x already.
_________________________________________
03 Tiag || KW V2 coilovers w/ Vorshlag CP || Brembo 355/345 || Afe Stg1 || Okada Plasma Coils || SS v2 stepped headers, SS Race Cats, El Diablo muffler|| OEM Csl diffuser, OEM Csl trunk || APEX 18x9.5 /18x10.5
My Journal
Jump to top RSM333 is offline   Reply With Quote
Old Thu, Jul-08-2010, 10:03:31 PM   #9
keca10
Useful Posts: 5
keca10's Avatar
yeah mine flickered on bumps then died completely.
Old Thu, Jul-08-2010, 10:35:44 PM   #10
cw
Actually I don't know if its the bulb or ignitor. Would the ignitor cause a bulb out message on the dash as well?
Before it officially died, it was dimmer and dimmer, and would flicker when turned on. Right now it seems like that doesn't even happen.
How can I tell what died?
bulb, dies, finally, xenon, years
Discussing Xenon bulb finally dies after 8.5 years... in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
