Old Tue, May-17-2016, 09:56:29 PM   #1
yosshaa
Proud ZCP Owner
yosshaa's Avatar
Reputation: 0 yosshaa is on a distinguished road
Default Yossha's 2006 IB Dove M3 ZCP SMG
The e46 M3 has been one of my favorite cars since the day it came out. This was the car that was on my wall in High School. I thought I would never have the opportunity to practically own one until recently. When the dream of owning an e46 M3 became a reality I researched and searched for months to find the example that was right for me. For two months straight I researched and did my due diligence on a specific car.
On May (Friday) the 13th I made it official and few from Phoenix, Arizona to Denver, Colorado purchase my 2006 BMW ZCP in Interlagos blue with SMG and Dove grey interior. The car is in excellent condition has a great record history, super low miles (53,XXX) and had just had its inspection 2.
I left the bank and headed to Pikes Peak outside of Colorado Springs to take the M up the world-famous hill climb to the summit at over 14,000 feet. Over the next two days, I drove the car back home through Colorado, Utah, and Arizona making stops at the Arches National park outside of Moab and to Monument Valley and driving through towns like Fairplay, Breckenridge, Vail, and Flagstaff.
I'm amazed at how smooth the car is. Other than those reversible mods I plan on enjoying this car as BMW intended.
Updates:
6/2016
Installed audiovox Bluetooth to stream iPhone music
11/2016
57,976 miles
-Oil change Mann filter, 10w-60 m twin power turbo oil, new drain bolt, o-rings, washers.
-TTFS SMG tune installed
-Clean MAF, clean air filter, wipe down filter housing.
3/2017
59,045 miles
Suspension refresh
-Koni Yellows
-Eibach Prokit springs
-New RTAB with ECS limiters
-Whiteline 30 mm front sway bar and poly sway bar bushings
-new front sway bar end links
-power flex rear sway bushings
also euro long trey
11/08/2017
New Battery
EverStart Maxx, Group Size H6
12/6/2017
60,2xx
Air bag recall fixed by Chapman BMW North Scottsdale
1/7/2018
60,300
OEM ZCP front brake rotors
Hawk HP plus pads
URO Front pad sensor
1/17/2018
New Tire Day
Front - 245/40ZR-18 SUMITOMO HTR Z III XL
Rear - 265/40ZR-18 SUMITOMO HTR Z III XL
2/28/2018
61,025
Oil Change Day
3,049 on old oil (replaced filter added 10-60 m power twin turbo oil)
3/11/2018
61,138
Installed
Mann air filter c25114
Mann cabin filter
3/12/2018
Blackstone oil report came back
Report Summary:
Lead (from bearings) was our main point of concern in the previous report and we're happy to see
it at just 6 ppm, which is right in line with universal averages. Copper, on the other hand, is steady and still
shows excess brass/bronze wear. If any work was done since the last sample, then copper may just be
from new parts wearing in. The other wear metals are fine after 3,049 miles of oil use. As a reminder,
universal averages show typical wear for the S54 engine after ~4,800 miles on the oil. The 1.0% fuel isn't a
concern. Overall, things look a little better.
10/1/2019
Took to BMW North Scottsdale
62,354-mile oil change
subframe dropped and inspected for cracking, everything looks great, no cracks, suspension torqued to spec
three rear sway bar bushing bolts replaced.
Blackstone oil sample sent in... waiting to see if metals go up.
2006///M3-ZCP-SMG-IB/Dove
43,779 E46 M3's produced for NA
26,202 E46 M3 Coupes
2,410 E46 M3 Coupes with ZCP Package
843 US / 54 CA ZCP in Interlagos Blue
366 US / 21 CA ZCP in Interlagos + SMG
154 US / 6 CA ZCP in Interlagos with N5TT (Dove Gray)
76 US / 2 CA ZCP in Interlagos + N5TT (Dove Gray) + SMG
WTB 1 Rear mint ZCP wheel no tire or center cap needed P/N 36112282999
Jump to top yosshaa is offline   Reply With Quote
Old Thu, Feb-02-2017, 08:51:16 PM   #2
yosshaa
Proud ZCP Owner
yosshaa's Avatar
Default Re: Yossha's 2006 IB Dove M3 ZCP SMG
holy shit I should have resized the images... d
Old Fri, Feb-03-2017, 09:49:57 AM   #3
Mr._T-Rex
Mr._T-Rex's Avatar
Reputation: 0 Mr._T-Rex is on a distinguished road
Netherlands
aaaaaand now your quota has run out.
I'm curious to see the fellow IB/Dove SMG ZCP
M3 Competition - Interlagos on Dove - Journal - iovo_m3
Jump to top Mr._T-Rex is offline   Reply With Quote
Old Fri, Feb-03-2017, 06:02:13 PM   #4
sooch
Reputation: 0 sooch is on a distinguished road
pics dont work
Jump to top sooch is offline   Reply With Quote
Old Sun, Feb-05-2017, 03:48:15 PM   #5
yosshaa
Proud ZCP Owner
yosshaa's Avatar
Originally Posted by sooch View Post
pics dont work
Old Sun, Feb-05-2017, 03:48:55 PM   #6
yosshaa
Proud ZCP Owner
yosshaa's Avatar
Old Sun, Feb-05-2017, 03:50:21 PM   #7
yosshaa
Proud ZCP Owner
yosshaa's Avatar
Old Sun, Feb-05-2017, 03:51:06 PM   #8
yosshaa
Proud ZCP Owner
yosshaa's Avatar
Old Mon, Mar-27-2017, 07:57:32 PM   #9
yosshaa
Proud ZCP Owner
yosshaa's Avatar
Update:
Suspension refresh at 59,045
Koni Yellows
Old Mon, Mar-27-2017, 09:41:58 PM   #10
Nice, should feel amazing! May I suggest fresh OE FCABS? Unless you already did them...
/// 2004 SilberGrau M3 Coupe 6MT slicktop zero options ~3100lbs JOURNAL
Evolve-R Alpha N Evolve CF CSL Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 2.5" sect 1 SS unres 2.5" sect 2 SCZA 2.5" sect 3 Besian RE pulleys/fan delete CSL battery
Bilstein HD B6 + GroundControl/Eibach 325/550lb + GC "tall" RSMs Hotchkis front sway F & R strut bars TMS camber & subframe plates Eibach alu rear camber arms RE trans mounts AKG poly subf/diff 95a SDW RTAB OE weighted ///M knob + ZHP alcantara boot + UUC DSSR
OE CSL trunk Cobra Nogaros + BK + manual OE bases TMS black pedals Sportline 8S 18"x 8.5/9.5" MPSS 245/275 APEX 75mm Studs Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL ZHP "712" rack
interlagos, smg, zcp
Discussing BlazenXLT - '02 M3 - Journal in the Member Journals Forum - Do you have a long term project you would like to share with the community? Use this forum to create a single thread which you can update over time to document the progress. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
