Old Tue, Sep-02-2008, 02:26:54 AM   #21
LightWerkz
Automotive Lighting Innovations
LightWerkz's Avatar
Reputation: 0 LightWerkz is on a distinguished road
I say go to your first track day with the car how it is, assuming you still have life left in the current pads and the fluid has been flushed.
Then decide if you plan to keep tracking it. The brake kit is definitely a worthwhile upgrade if you track hardcore, but if you dont, its merely a cosmetic mod.
Caesar Rowinski - LIGHTWERKZ
2001 BMW M5 - Alpine White on Caramel
Jump to top LightWerkz is offline   Reply With Quote
Old Tue, Sep-02-2008, 03:26:41 AM   #22
BlazenXLT
We've had one yes, what about second breakfast?
BlazenXLT's Avatar
Reputation: 0 BlazenXLT is on a distinguished road
That's my plan for now. I'll go with the stock setup for the first time, then go from there.
How did you like your PFR rotors lightwerks?
Jump to top BlazenXLT is offline   Reply With Quote
Old Tue, Sep-02-2008, 03:32:04 AM   #23
LightWerkz
LightWerkz's Avatar
I loved them. Definitely the best set of rotors for this car, under a BBK setup.
Old Tue, Sep-02-2008, 05:59:21 PM   #24
kwikieman146
kwikieman146's Avatar
Reputation: 0 kwikieman146 is on a distinguished road
where did you end up getting the helmet?
TiAG///M3 6SP
///Dice///hyperwhite///CDV delete///Stoptech SS lines///Powerflex RTABS///BBS CH//Hardwired V1///Dinan Rear Strut Bar
Jump to top kwikieman146 is offline   Reply With Quote
Old Tue, Sep-02-2008, 06:36:18 PM   #25
BlazenXLT
BlazenXLT's Avatar
A shop in N. Virginia called OG racing (www.ogracing.com). It's a nice shop with lots of helmets available to try on. I tried 3 or 4 before deciding.
Old Fri, Sep-12-2008, 03:33:10 PM   #26
///power///
///power///'s Avatar
Reputation: 0 ///power/// is on a distinguished road
Saudi Arabia
Originally Posted by BlazenXLT View Post
Cool. I'm leaning towards going the CSL route. Can you really hear the brakes with the ultimate pads, or is it a result of the rotor itself? Thanks for the info!
Yes you can and it's annoying compared to the oem ones. I don't think it's a result of the rotors. And I noticed that these pads are aggressive on the rotors too.
I heard Hawk pads are great.
______________________________________________
'13 Ford Raptor Black/Black
'95 E36 2JZ Drift car Gray/Black
'06 E60 ///M5 SMG AW/Black - Sold
'02 E46 ///M3 6 Speed TiAg/Black - Sold
'98 E36 ///M3 Estoril Blue - History
Jump to top ///power/// is offline   Reply With Quote
Old Mon, Sep-22-2008, 02:28:18 PM   #27
BlazenXLT
BlazenXLT's Avatar
22 Sept 2008
One year of ownership! Absolutely no regrets! Took the M on a road trip this week of about 450 miles (including passing 91k). On board computer displayed 27.3 mpg for the whole trip. Ran flawlessly.
Should have additional updates soon... first driving event is coming up soon, brake upgrade plan is in motion, and I need to fix my stupid sunroof shade.
...turns out the sunroof shade was an easy fix. The glass had pushed the shade back into the roof and it didn't come back out when the roof was closed. With the glass half open, I was able to get my fingers in far enough to pull the shade back out. It seems to still be on the tracks, but I'll be leaving it closed just in case. I really wish I had a sunroof-delete car.
Old Thu, Sep-25-2008, 04:59:50 PM   #28
BlazenXLT
BlazenXLT's Avatar
I picked up an extra set of OEM calipers so that I can take my time cleaning and painting them. I'm leaning towards upgrading to CSL brakes when my current set-up is ready to be replaced (this winter most likely).
I've only cleaned one of them, can you tell?
I'm going to use the POR-15 caliper kit for paint.
After the calipers are clean, I'll likely rebuild them and replace the seals and bushings.
12 Sept 2008
Car had it's first tech inspection for my upcoming driving event. Everything was fine, although my brake pads have about 40% life left. Brake fluid was flush and filled with ATE superblue.
Old Thu, Sep-25-2008, 05:26:31 PM   #29
LightWerkz
LightWerkz's Avatar
You should really get a new set of pads, or keep a very close eye on the current ones.
Old Thu, Sep-25-2008, 08:56:10 PM   #30
BlazenXLT
BlazenXLT's Avatar
Ya, the 40% was a little lower than I would have liked, although the shop said the fronts were closer to 50%. I figure I'll run the first day and keep an eye on them.
blazenxlt, journal
Matl's Journal!... finally matl Member Journals 9 Fri, Jul-16-2010 03:50:31 AM
Journal of the new S/C setup Krank E36 M3 (1992-1999) 14 Thu, Dec-27-2007 11:03:55 AM
undertow's personal journal (2002 M3) undertow E46 M3 (2001-2006) 10 Sat, Jan-21-2006 11:05:31 PM
My M3 Journal - Discover Problem KD428 E46 M3 (2001-2006) 7 Tue, May-11-2004 07:49:56 AM
Discussing BlazenXLT - '02 M3 - Journal in the Member Journals Forum - Do you have a long term project you would like to share with the community? Use this forum to create a single thread which you can update over time to document the progress. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
