Old Mon, Feb-06-2006, 08:41:32 PM   #1
asiupang
asiupang's Avatar
Reputation: 0 asiupang is on a distinguished road
Default ZCP/CSL Brake Carrier Part Number request
I would like to get the part number for the CSL/ZCP caliper carrier part number, I tried looking for it on realoem and i couldn't identify where it would be under.
thanks in advance
Art
Team Vorsteiner
AA Stage 3, Alcohol Injection, Vorsteiner CF Roof, Double Sided Carbon Fiber Trunk, Double Sided CF GTR Hood, CF VCSL Bumper, CF Diffuser, VCSL CF Console, VCSL CF Engine Cover, BBS 19" CH, Rotora 6POT Front 4POT Rear, CSL Header, 4.10 Gear Ratio, Diablo Exhuast, EVC X Pipe, TC Kline Suspension, Quatro CF Strut, Powerflex Front & Rear, Eibach Sway Bar
Jump to top asiupang is offline   Reply With Quote
Old Mon, Feb-06-2006, 09:04:40 PM   #2
Jack-O-Lantern
Chalupas for Everyone!
Jack-O-Lantern's Avatar
Reputation: 0 Jack-O-Lantern is on a distinguished road
I got my OEM boxes at home. Let me give you the part number off the boxes later after I get home from work.
thanks in advance
Art
Jump to top Jack-O-Lantern is offline   Reply With Quote
Old Mon, Feb-06-2006, 09:13:07 PM   #3
M3Tech
M Powered
M3Tech's Avatar
Reputation: 0 M3Tech is on a distinguished road
thanks in advance
Art
http://www.realoem.com/bmw/showparts...57&hg=34&fg=05
Jump to top M3Tech is offline   Reply With Quote
Old Tue, Feb-07-2006, 02:00:20 AM   #4
Jack-O-Lantern
Okay I got home and confirmed on my box. Part # is 34112282619. They are identical so there is no left or right.
Old Tue, Feb-07-2006, 02:06:27 AM   #5
JPinTO
2001 E46 M3 + 2007 E60 M5
Reputation: 0 JPinTO is on a distinguished road
How many of those other parts are required for the upgrade? TIA!
Jump to top JPinTO is offline   Reply With Quote
Old Tue, Feb-07-2006, 02:45:17 AM   #6
ninook
In "M" we trust.
ninook's Avatar
Reputation: 0 ninook is on a distinguished road
Front upgrade you need
Caliper carriers and ZCP rotors only. ZCP calipers and stock calipers are the same with the exception of paint. ZCP rotors are larger thus the need for different carriers to relocate the calipers.
Rear upgrade is euro rotors only. They are the same diameter as stock. No need to relocate the calipers.
Jump to top ninook is offline   Reply With Quote
Old Tue, Feb-07-2006, 04:32:19 AM   #7
Jack-O-Lantern
Plus for about $28 online you can get some G2 paint and paint the calipers to match the carriers. I just finished that this weekend and it looks perfect.
FCAB carrier part number? pachieh E46 M3 (2001-2006) 4 Mon, Oct-06-2008 05:16:52 PM
ZCP/CSL Alcantara wheel: part number? F1Kal-El E46 M3 (2001-2006) 13 Mon, Mar-05-2007 08:20:47 AM
ZCP Front caliper carrier part numbers? r6vr6 E46 M3 (2001-2006) 2 Sun, Nov-05-2006 11:51:41 AM
Part # for ZCP/CSL Alcantara E-Brake Handle? TCG///M3 E46 M3 (2001-2006) 4 Fri, Sep-08-2006 01:33:46 AM
ZCP brake pad part number? elh0102 E46 M3 (2001-2006) 1 Fri, Jul-22-2005 03:23:10 AM
Discussing ZCP/CSL Brake Carrier Part Number request in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
