Old Mon, Jun-02-2003, 12:44:56 PM   #1
agapehme
Reputation: 0 agapehme is on a distinguished road
Default Clutch Master / Slave cylinder
Hello all,
Can anyone give a description of how the clutch feels if your Clutch Master or Slave cylinder is bad or should I say going Bad?
Thanks
Agapehme
Jump to top agapehme is offline   Reply With Quote
Old Mon, Jun-02-2003, 01:05:06 PM   #2
eduardo gonçalves
Team Empty Wallet Racing
eduardo gonçalves's Avatar
Reputation: 0 eduardo gonçalves is on a distinguished road
If it has a leak you should feel your pedal loosing pressure. Press the clutch with the engine running and engage first gear and maintain your pedal down...after a while see if you can disengage the gear easily or if the car starts moving ahead...
Eduardo.
Jump to top eduardo gonçalves is offline   Reply With Quote
Old Mon, Jun-02-2003, 08:51:37 PM   #3
agapehme
Default ..
Thanks!
Agapehme
Clutch master cylinder replacement djungel-Jim E36 M3 (1992-1999) 3 Tue, Jul-22-2008 12:25:52 PM
Clutch master cylinder phantom3 E36 M3 (1992-1999) 7 Sat, Jul-14-2007 02:18:46 PM
Leaking clutch master cylinder virsipe E46 M3 (2001-2006) 2 Mon, Feb-05-2007 08:08:36 PM
Clutch Slave Cylinder Bleeding hayjay13 E46 M3 (2001-2006) 1 Tue, Jan-10-2006 04:13:19 PM
Clutch Slave Cylinder Replacement WhiteOut E46 M3 (2001-2006) 11 Tue, Oct-18-2005 01:28:08 PM
Discussing Clutch Master / Slave cylinder in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
