Old Mon, Mar-06-2006, 07:20:08 PM   #1
:torque:
Entitlement Kid
:torque:'s Avatar
Reputation: 0 :torque: has disabled reputation
Default Headers + RE Rasp Pipe
Right now, my exhaust setup has a Rasp section 1 from RE and a dinan exhaust. I love the sound so much that I would never give it up for anything. My questions are, I know the Rasp pipe eliminates rasp but does it also restrict airflow? IN other words would it be a waste to get headers, or a section 2 to try to squeeze out a couple hp? Also, if I do this, will the rasp still be gone or would headers and the RE pipe bring back the rasp?
Paulie
Jump to top :torque: is offline   Reply With Quote
Old Mon, Mar-06-2006, 10:04:55 PM   #2
E46M3Rod
E46M3Rod's Avatar
Reputation: 0 E46M3Rod has disabled reputation
If it is giving you a somewhat quieter sound....then it seems to me there is a good chance it is restricting airflow.
If I am not mistaken...the RE rasp section 1 weighs a bit more than the stock unit itself.
I don't like the rasp myself....but I'm not sacrificing even the slightest performance decrease.
Most rasp pipes deliver on what it says it does....eliminate the rasp. They claim no hp gains nor even state that it doesn't even lose performance.
And as far as headers go....if you go with the Euro type....the cats are in the Section 1 part....not part of the header like the US version. So if you switch to the euro header....you'd be running no cats with your current set up. Not sure if this was your intention. You'll probably get some fault codes unless you get the Conforti Shark software. You still won't pass smog and if you get caught with no cats....pretty big fine.
19x8.5F 19x10R Work Wheels RezaxII Toyo T1-R
Jump to top E46M3Rod is offline   Reply With Quote
Old Mon, Mar-06-2006, 10:46:13 PM   #3
:torque:
Entitlement Kid
:torque:'s Avatar
what about a section 2 pipe? you think its even worth it?
Paulie
Ebay Headers + RE Rasp Pipe = FTW ///M3 Craig4 E46 M3 (2001-2006) 52 Fri, Jul-25-2008 03:56:17 AM
evosport headers and RE Rasp Pipe NS E46 M3 (2001-2006) 12 Mon, Dec-04-2006 09:55:01 PM
Anyone with aftermarket headers and rasp pipe? RhaceM3 E46 M3 (2001-2006) 1 Sun, Jul-09-2006 01:52:37 AM
Rogue Rasp(s)pipe and headers ViNNie0722 E46 M3 (2001-2006) 4 Wed, May-10-2006 08:47:47 PM
I want to put on CSL headers with the RE Rasp pipe.... SinCityM3 E46 M3 (2001-2006) 7 Sat, Nov-05-2005 12:37:58 AM
Discussing Headers + RE Rasp Pipe in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
