Old Thu, Mar-09-2006, 06:49:17 PM   #1
sjehrlich
sjehrlich's Avatar
Reputation: 0 sjehrlich is on a distinguished road
Default Warranty and service bulletins
If your car is out of warranty and a problem arises that is covered in an SIB, do you have to pay to have the repair work done??
A buddy of mine had a failure of one of his ignition coils and had all of them replaced under warranty as the SIB specified. If my 02 (out of warranty) suffers the same problem will I have to replace all six out of pocket, or would I just have the affected coil replaced on my dime? They wouldn't take care of it under the 6/100k engine warranty would they?? :nixweiss:
2005 Silver Gray M3 SMG Vert
Jump to top sjehrlich is offline   Reply With Quote
Old Thu, Mar-09-2006, 07:13:58 PM   #2
tdc
still notorious
tdc's Avatar
Reputation: 0 tdc will become famous soon enough
If it's a RECALL, then the work is done under warranty. If it is simply a bulletin, you would pay out of pocket.
As for the specific issue of the ignition coils, I do believe that is covered under your 6yr/100k engine warranty as they are part of the engine.
stockWERKZ
M3BC #57
"Time cannot be influenced by mankind. It gives each of us a beginning and an end.
And this makes us question the significance of what comes between. But if you can
create something time cannot erode, something which ignores the eccentricities of
particular eras or moments...something that is truly timeless, this is the ultimate victory."
- Dr. Ing. h.c.F Porsche
Jump to top tdc is offline   Reply With Quote
Old Thu, Mar-09-2006, 07:23:35 PM   #3
sfhondapilot
Reputation: 0 sfhondapilot has disabled reputation
I would be surprised if that was the case. I thought the 6/100k engine warranty covers only oil lubricated parts. I'd be hard pressed to argue that the ignition coil is an oil lubricated part.
David
2007 997 TT
2003.5 M3Cic (IR on Black)
Jump to top sfhondapilot is offline   Reply With Quote
Old Thu, Mar-09-2006, 08:10:21 PM   #4
WillC310
Reputation: 0 WillC310 has disabled reputation
Jump to top WillC310 is offline   Reply With Quote
Old Thu, Mar-09-2006, 10:26:14 PM   #5
PatrickJr
PatrickJr's Avatar
Reputation: 0 PatrickJr has disabled reputation
You're right. I asked the dealer about checking to see if my car is leaking oil, and if it is, would that be covered under the 6/100k....
They said no, only moving lubed engine parts.
Fcukers...you would think regarding oil leaks they would want to take care of that...
PK
To quote Chris Rock, "My job is to keep her off the pole".
OEM MODS: Engine Head Machine Plug, Both Door Window Seals, Driver Seat Motor, Driver Seat Belt Tensioner, Sun Roof, what else can go wrong once you're out of warranty!!!
sig by Grimm
Jump to top PatrickJr is offline   Reply With Quote
Old Thu, Mar-09-2006, 11:13:04 PM   #6
bmw_jeff
bmw_jeff's Avatar
Reputation: 0 bmw_jeff is on a distinguished road
We actually got a "Recall" letter from BMW for the coils in my wife's '03 325i. It stated something about California Emissions basis for the Recall. This may not apply in all states but in CA almost every 3 series model incl M3 was Recalled. Since the coil is a emissions related component (according to the Recall I got) I would think you could get them to cover it under the emissions warranty period (6 or 8 years I think)? Good luck!
2006 M3 ZCP 6spd. Alpine/Imola -only options: ZCP and Xenon
2003 540ia M-sport Jet Black/Black ultra low miles! (daily cruiser)
1967 1600-2 matching #'s nice original body and paint Florida Green/Brown interior restored to original
SOLD -2003 325i Sport/Premium Sapphire Black/Black
SOLD -2000 323ci coupe Silver/Black
SOLD -1989 535i 5-speed Jet Black/Black
SOLD -1988 325e sedan White/Tan
DEAD -1970 1600-2 White/Black RIP
Jump to top bmw_jeff is offline   Reply With Quote
Old Sat, Mar-11-2006, 09:29:17 PM   #7
B_man76
B_man76's Avatar
Reputation: 0 B_man76 is on a distinguished road
Hey.
Any luck on that coil replacement? I'm afraid I'm having the same situation. Whenever I pull out with load at rpms under 2k I get misfiring at most any gear although it is most prominent in 1st. Did you have any luck getting this replaced?
Brad
Jump to top B_man76 is offline   Reply With Quote
Old Wed, Mar-15-2006, 12:19:01 AM   #8
S18adeli
S18adeli's Avatar
Reputation: 0 S18adeli is on a distinguished road
Check out this thread...
http://www.m3forum.net/m3forum/showt...1&page=1&pp=10
if your car fits under the certain years, yes, the dealer will replace all free of charge. My coils are going bad however they will not change them because my VIN# does not indicate the TSB.
Garage:
E46 M3 Convertible - 6 speed
E36 M3 Sedan - 5 speed
E36 328i - 5 speed
Jump to top S18adeli is offline   Reply With Quote
Service Bulletins grmnrkt E46 M3 (2001-2006) 3 Tue, Mar-14-2006 11:53:31 AM
What happened to the service bulletins???? smoldin Member Notes and Requests to Admin/Mods 35 Sat, Apr-02-2005 10:51:53 PM
service bulletins? recalls? chang_lee Off Topic 1 Thu, Nov-25-2004 08:46:19 PM
Service Bulletins.....who's responsibility is it to notify me? ClearM3 E46 M3 (2001-2006) 21 Thu, Jun-03-2004 01:44:03 AM
Recalls and Technical Service Bulletins? revenant E36 M3 (1992-1999) 0 Sun, Dec-21-2003 03:57:33 AM
Discussing Warrantee and service bulletins in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
