Old Sat, Apr-01-2006, 05:25:07 PM   #1
torresmd
torresmd's Avatar
Reputation: 0 torresmd will become famous soon enough
Default Help with O2 sensor diagram!!
I am looking for a diagram that shows the mapping of each O2 sensor and exactly with bung it goes in on the headers. I have found this:
http://www.realoem.com/bmw/showparts...17&hg=11&fg=50
It shows the lengths which is helpful, but it does no show where each headers each should go. If you know this info please share.
Thanks
2004 996TT Gaurds red/Black interior GT660 550 whp on 91 octane
2004 IMOLA CAB
[/SIZE]
Jump to top torresmd is offline   Reply With Quote
Old Sat, Apr-01-2006, 11:38:17 PM   #2
jajja
M3 Guro
Reputation: 0 jajja is on a distinguished road
I'd ask these guys..
http://bimmer.roadfly.com/bmw/forums/e46m3/
LSB BMW //M3 6 Speed
Evosport Under Drive Pulleys / UUC EVO3 Short Shift Kit / Superchips Performance Software / AFE Intake / Bosch Irridium Plugs / 19" HRE 546R Rims / Falken 245/35 & 275/30 Tires / H&R Coil Over Kit Suspension / H&R Front & Rear Sway Bars / Strong Strut Front Brace / Ground Control Adjustable Control Arms / Ground Control Rear Bushing Kit / Hamam Fog Light Inserts / Angel Eye Light Kit Upgrade / ACS Shift Knob & E-Brake / ACS Gas & Shift Pedals / ACS Seat Pads / Euro Cross-Drilled Rotors / Hawk HPS Brake Pads / 4.10 Diff Gear Upgrade / UUC Race Flywheel / UUC Race Clutch / SuperSprint Header / New Prototype Rasp X S pipe/ SuperSprint X Pipe / SuperSprint Race Exhaust
Jump to top jajja is offline   Reply With Quote
Old Sun, Apr-02-2006, 05:16:43 AM   #3
gonzjed
gonzjed's Avatar
Reputation: 0 gonzjed is on a distinguished road
Thanks
torresmd, I'm not sure exactly what your asking. Are you looking for a wiring diagram or physical component location other than the link you posted.
I attached a wiring diagram for the pre-cats, let me know if I'm tracking or not.
Jump to top gonzjed is offline   Reply With Quote
CEL: 02 Sensor (Primary) Replace o2 Sensor, or cats too? BMWchubbs E36 M3 (1992-1999) 15 Sun, Sep-21-2008 07:22:09 AM
DIY Wideband O2 Sensor Replacing Stock O2 Sensor (E46 M3) Finally Done.... jmciver Forced Induction (F/I) 2 Thu, Oct-25-2007 05:11:14 PM
Coolant sensor and windshield wiper fluid sensor, are they on the same circuit? nlpamg E46 M3 (2001-2006) 0 Fri, Oct-05-2007 06:22:07 AM
Exhaust Temp Sensor, Intake Valve #6 and 7, Knock Sensor! callon1 E46 M3 (2001-2006) 12 Thu, Jun-15-2006 01:41:59 AM
Wiring Diagram help IIrjII E36 M3 (1992-1999) 3 Wed, Sep-03-2003 07:57:08 PM
Discussing Help with O2 sensor diagram!! in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
