Old Mon, Apr-10-2006, 09:14:13 PM   #1
deilenberger
deilenberger's Avatar
Default Oil temp sensor?
I'm guessing here - is it part of the oil-level sensor? I can't find anything in the TIS or ETK referring to a seperate sensor, and since the oil-level sensor IS a thermal sensor - seems logical.
Reason I'm asking - after getting an oil-pan gasket replaced - I no longer have an operating oil-temp gauge, and the oil-level-warning flashes for about 30 seconds after starting the car up.
Somehow - I think they two are related..
Anyone know where the connector is located? I'm about willing to bet it's above that big aluminum plate under the engine..
  • 2001 M-Coupe - TiSilver/Black - Das Boot..
  • 2006 Cayenne/S - Iceland Silver Metallic/Stone-steel Gray - Truckster.
  • 2007 R1200R - Roadster, black mit/white pinstripes - the REAL BMW..
Old Sun, Apr-05-2009, 02:04:22 AM   #2
Steve Jarvis
Steve Jarvis's Avatar
Reputation: 0 Steve Jarvis is on a distinguished road
I have exactly the same problem. My quess is you are correct.
Later, Steve
2001 M3 IR/Blk 6sp, UUC rasp-X and exhaust, GC street/school coil-overs, VMR V715's wheels 19x9.5" 275/30R19 front and rear
2006 M5 Sapphire Black Metalic/Blk, Stock for now
2001 GT610 911 Turbo blk/blk
Jump to top Steve Jarvis is offline   Reply With Quote
Old Sun, Apr-05-2009, 02:17:51 AM   #3
JeST
Old Skool
JeST's Avatar
Reputation: 0 JeST will become famous soon enough
China
Yes, Don. It's part of the oil level sensor. Also it's on the bottom of the oil pan which requires the aluminum undershield to be removed.
ps. If the car needs an oil change soon might as well do it now. Or you can find a bucket to catch the oil and put it back in if its relatively new still.
1988 M3 - Henna/black on black alcantara
2012 Ducati 848 Evo Corse
Jump to top JeST is offline   Reply With Quote
Old Sun, Apr-05-2009, 02:44:36 AM   #4
Tonester
Reputation: 0 Tonester is an unknown quantity at this point
Viet Nam
To check the connector itself you don't need to drop the reinforcement plate.
You can actually see it from the side of the wheel well.
Jump to top Tonester is offline   Reply With Quote
Old Sun, Apr-05-2009, 02:52:38 AM   #5
ohnoes
Reputation: 0 ohnoes is on a distinguished road
I'd just wait till the next oil change and fix it then. Kinda silly to spend almost $100 (oil) on something that isn't really critical. You probably know how long the car takes to warm up, on average, and unless you track the car, which is unlikely being that it's a 'vert, oil temp isn't a huge concern.
Jump to top ohnoes is offline   Reply With Quote
Old Sun, Apr-05-2009, 02:53:54 AM   #6
deilenberger
Pssss.... look at the posting date for the original thread. It was also fixed in 2006..
Old Sun, Apr-05-2009, 02:57:14 AM   #7
ohnoes
D'oh.
Old Sun, Apr-05-2009, 04:06:15 AM   #8
JeST
Old Skool
JeST's Avatar
China
Old Mon, Apr-06-2009, 10:36:27 PM   #9
Steve Jarvis
I hate when i'm searching and do that.
Later, Steve
Old Mon, Apr-06-2009, 10:48:40 PM   #10
JeST
Old Skool
JeST's Avatar
China
Later, Steve
If Don had that question 3 years ago and you had it recently I'm sure others would benefit from the advice in this thread also
oil, sensor, temp
M3 Jeopardy: Will low oil temp / water temp throw the SES light? Scuba Steve E46 M3 (2001-2006) 2 Sat, Dec-09-2006 04:12:05 AM
Exhaust Temp Sensor, Intake Valve #6 and 7, Knock Sensor! callon1 E46 M3 (2001-2006) 12 Thu, Jun-15-2006 12:41:59 AM
E36 Gauge Panel w/VDO Boost, Oil Temp, Oil Pressure ESP Parts for Sale/Wanted 1 Wed, Mar-08-2006 09:32:13 PM
Temp Sensor BMW325ise E36 M3 (1992-1999) 2 Wed, Aug-11-2004 02:59:36 PM
Temp. Sensor??? silent_drag E36 M3 (1992-1999) 2 Fri, Oct-24-2003 01:15:24 PM
Discussing Oil temp sensor? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
