Old Mon, Apr-17-2006, 03:43:22 PM   #1
GBORK
M3 VERTING
GBORK's Avatar
Reputation: 0 GBORK has disabled reputation
Default need advice spacers and lower
Hey,, just want to know the most effective route to take. I would like to lower my 04 convertible(e46) and also would like to widen the stance (spacers) What size spacers and what type of springs ect will work w/o rolling my fenders????? I have 19" OEM wheels.
respect to all
Jump to top GBORK is offline   Reply With Quote
Old Mon, Apr-17-2006, 05:57:29 PM   #2
geonet
works for me
geonet's Avatar
Reputation: 0 geonet is on a distinguished road
eibach springs.. if you go coilovers most go with the PSS9, GC (ground control), Tein, or TC Kline. If you will be tracking a lot, I'd say GC or TC Kline.
as for spacers go with Rogue or H&R. i'm running 12mm all around on OEM ZCP. many also do 10mm all around , also 12mm front/10mm rear
2006 Porsche 997S Black
2003 M3 Carbon Black
Jump to top geonet is offline   Reply With Quote
Old Fri, Sep-21-2012, 01:41:40 AM   #3
e46m3darknight
e46m3darknight's Avatar
Reputation: 0 e46m3darknight has disabled reputation
Default Re: need advice spacers and lower
I would also like to put some spacers on my m when i lower it. I just dont know what size to put on . Can you post a pic of your set up ?
Jump to top e46m3darknight is offline   Reply With Quote
Old Fri, Sep-21-2012, 03:13:20 AM   #4
e46m3darknight
by the way my tires are size 225 front 255 rear with oem 19"
Posted from M3forum.net App for Android
Old Fri, Sep-21-2012, 03:22:01 AM   #5
RaceMX-M3
Scott@Radar-Mirror.com
RaceMX-M3's Avatar
Reputation: 0 RaceMX-M3 is a jewel in the rough
As I recall 12 front / 10 rear is the best fit. Try a search, must be 500 threads on this.
Jump to top RaceMX-M3 is offline   Reply With Quote
Old Fri, Sep-21-2012, 03:23:25 AM   #6
Nofar
Reputation: 0 Nofar is on a distinguished road
To the OP,
I have Eibach Pro-Kit springs with stock shocks, plus 15mm front and 10mm rear spacers. If you want pictures let me know.
Regards,
Christopher
2006 M3 ZCP. Interlagos Blue on Dove Grey. 6 speed manual.
Eibach Pro-Kit / DDM Aluminum Pedals / BMW Performance Short Shift Kit / Clutch Delay Valve (CDV) removed / Painted reflectors / Stealth bulbs / Turner 15mm/10mm front/rear spacers.
Jump to top Nofar is offline   Reply With Quote
Old Fri, Sep-21-2012, 03:33:31 AM   #7
Sandeep1212
Sandeep1212's Avatar
Reputation: 0 Sandeep1212 is on a distinguished road
This is one of those topics where there is SO MUCH info on this forum. All you have to do is use the search function.
Jump to top Sandeep1212 is online now   Reply With Quote
DIY - E36 Lower Windshield Cowl Replacement - "Lower Seal" Braymond141 Faults, Fixes and DIY 22 Fri, Jun-29-2012 02:39:41 PM
WTS: RE Spacers 12mm w/ lug bolts or WTT: for 10mm Spacers LightWerkz Parts for Sale/Wanted 3 Mon, Apr-14-2008 02:20:16 AM
Wheel Spacers Advice BondoM3 E36 M3 (1992-1999) 3 Fri, May-25-2007 11:35:51 AM
Spacers - Need Advice kpkpkp E46 M3 (2001-2006) 0 Sun, Feb-18-2007 10:04:23 PM
Looking to lower my M3... Need advice... xXVanquishXx E46 M3 (2001-2006) 19 Fri, May-20-2005 07:12:11 PM
Discussing need advice spacers and lower in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
