Old Thu, Jun-19-2003, 12:19:22 AM   #1
EMMM TREE
EMMM TREE's Avatar
Reputation: 0 EMMM TREE is on a distinguished road
Default burning smell
i get a burning smell from my rear left wheel, the intensity of the smell grows the longer i drive.....its been like that since i bought the car recently...........furtheremore i hear a low growling/grinding sound coming from the left rear at low speeds
any thoughts? they could be related or 2 seperate problems...
95 cosmos emmm tree
Jump to top EMMM TREE is offline   Reply With Quote
Old Thu, Jun-19-2003, 12:21:59 AM   #2
///Mphantom
Turbo Please!
///Mphantom's Avatar
Reputation: 0 ///Mphantom is on a distinguished road
I had this same problem on my 93 318i, it turned out to be a shot wheel bearing if I remember correctly, you need to get that replaced ASAP because its causing damage more and more you drive!!! I could be wrong though, but from what you describe I am pretty sure that is the problem.
Jump to top ///Mphantom is offline   Reply With Quote
Old Thu, Jun-19-2003, 12:26:38 AM   #3
Ramtruk
Member
Ramtruk's Avatar
Reputation: 0 Ramtruk is on a distinguished road
That would be my first guess too. Get it figured out so you aren't left stranded somewhere!
1998 M3 Coupe Cosmos Black
UUC SSK(with DB's and CB's)
X-Brace
H&R OE Sport Springs
Koni SA's
Jump to top Ramtruk is offline   Reply With Quote
Old Thu, Jun-19-2003, 01:16:16 AM   #4
M3AN
mmm... lovely!
M3AN's Avatar
Yep, I vote for bearing as well - get it sorted ASAP for the reasons above.
Only other think I can think of is that your handbrake balance is way out and the left side is sticking - similar symptoms.
M3AN
Old Thu, Jun-19-2003, 10:42:36 PM   #5
EMMM TREE
EMMM TREE's Avatar
ok it makes sense for the grinding noise........but why the burning smell? almost like rubber!
Old Thu, Jun-19-2003, 10:50:53 PM   #6
M3AN
mmm... lovely!
M3AN's Avatar
EMMM TREE>
"Almost like rubber."
Brakes. Get them checked ASAP
M3AN
Old Thu, Jun-19-2003, 11:56:34 PM   #7
EMMM TREE
EMMM TREE's Avatar
since when are brakes made of rubber?
Old Fri, Jun-20-2003, 12:21:13 AM   #8
///Mphantom
Turbo Please!
EMMM I had a little of that smell also, but it was faint. I believe its the smell coming from the bearings. Metal grinding metal smokes and leaves a smell similair to burning rubber. I believe if you get your wheel bearing replaced you wont smell rubber anymore. I feel like a pro at this problem because my mechanic went over it with me in detail, I was too skeptical to replace it myself. Get that thing fixed before it throws everything off
Old Fri, Jun-20-2003, 12:27:28 AM   #9
Ramtruk
Member
Ramtruk's Avatar
There are also grease seals, made of rubber, next to the bearings.
X-Brace
Koni SA's
Old Fri, Jun-20-2003, 12:40:06 AM   #10
EMMM TREE
EMMM TREE's Avatar
that makes sense.........thanks alot for the input guys!
Burning Clutch Smell Falcon E46 M3 (2001-2006) 10 Fri, Mar-10-2006 12:32:13 AM
Oil Burning Smell apexapex E46 M3 (2001-2006) 9 Mon, Feb-06-2006 10:26:47 PM
Burning smell mj1133 E46 M3 (2001-2006) 18 Sat, Jan-14-2006 07:12:34 PM
What is this burning smell? martinmartin E46 M3 (2001-2006) 7 Tue, May-17-2005 04:45:48 AM
burning smell please help IIrjII E36 M3 (1992-1999) 2 Thu, Jul-04-2002 04:59:00 AM
Discussing burning smell in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
