Old Tue, Jun-27-2006, 08:31:21 PM   #31
cntrvrsy
cntrvrsy's Avatar
United Nations
I don't have any photos to show but I have OEM CSLs w/ 235/35 & 265/30 T1Rs. I'm lowered on H&R coil springs with RE 15mm up front and 12mm in the back with no rubbing.
sig engineered by Fcukupayme
Jump to top cntrvrsy is offline   Reply With Quote
Old Tue, Jun-27-2006, 09:07:53 PM   #32
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
Originally Posted by sixmillbaby
I know you're the CSL man so I trust you're judgment. So in english (final answer) what size spacers for my car with stock suspension, csl replicas from Modbargins 19x8.5front/19x9.5 rear (m3 offset) and 245/35/19 and 275/30/19 tires?
VB3
Bolt Pattern
5x120mm
Center Bore
72.6mm
Available Sizes
18x8.5" / +40mm / Silver
18x9.5" / +40mm / Silver
18x9.5" / +22mm / Silver
19x8.5" / +40mm / Silver
19x9.5" / +45mm / Silver
19x9.5" / +22mm / Silver
Description
Our most popular wheel! The M3 CSL replica wheel. Featured on E46fanatics.com.
http://www.velocitymotoring.com/wheels.php
the VB3 wheel comes in this size for the m3:
19x8.5" / +40mm / front
19x9.5" / +22mm / rear
oem csl wheels are:
19x8.5" / +44mm / front
19x9.5" / +27mm / rear
so.. if i can run 10mm on my oem csl safely, you should be able to run these spacers to be equal to my CSL wheels. please dont quote me as i never tried running spacers on VB3 wheels before. this is purely just hypothetical data.
suggested spacers for VB3 on M3:
14mm fronts (40mm ronts stick out 4mm less then oem csl fronts)
15mm rears (22mm rears stick out 5mm less then oem csl rears)
Old Tue, Jun-27-2006, 09:09:37 PM   #33
daytonaviolet
OEM CSL Whoore
yes.. u can get away with the 12mm rear spacer because your rear tires are 10mm smaller (5mm more space per each side of the tire). your running 265mm when most of us are running 275's
Old Tue, Jun-27-2006, 09:51:43 PM   #34
cntrvrsy
cntrvrsy's Avatar
United Nations
You're right, the rears are cutting it pretty close. And with 275s out back I'd probably touch under serious dips .
Old Tue, Jun-27-2006, 09:55:16 PM   #35
Irrenarzt
My lady is hotter than yours
Irrenarzt's Avatar
Reputation: 0 Irrenarzt is on a distinguished road
Originally Posted by herkdriver007
just get yourself some RG4s
I agree with this assessment
Jump to top Irrenarzt is offline   Reply With Quote
Old Tue, Jun-27-2006, 10:44:48 PM   #36
sixmillbaby
sixmillbaby's Avatar
Reputation: 0 sixmillbaby has disabled reputation
VB3
Bolt Pattern
5x120mm
Center Bore
72.6mm
Available Sizes
Description
oem csl wheels are:
You rock man, thanks for taking the time. I got an email from Modbargins and they said that I don't need spacers because the wheels are designed for the m. HMmmmmm go figgure. I just want them to be flush with the fenders. There's nothing worse that wheels that don't sit right.
Sig pic too large, max 600x250
Jump to top sixmillbaby is offline   Reply With Quote
Old Fri, Jun-30-2006, 08:01:48 AM   #37
Keith_m3-4
Keith_m3-4's Avatar
Reputation: 0 Keith_m3-4 is on a distinguished road
Not to thread jack but since thing is about wheel spacers.
I just installed Rogue 12mm spacer all around with my RS-GT's.
Tire sizes are 245 front and 275 rears(PS2's).
I had to remove the rear hubcentric rings so they will fit. No issues such as vibration or signs of being off balance. Should I be concerned?
'02 TiAG SMGII
Jump to top Keith_m3-4 is offline   Reply With Quote
Old Fri, Jun-30-2006, 08:25:26 AM   #38
daytonaviolet
OEM CSL Whoore
if you have no vibrations then your cool. the hubcentric rim helps centers your wheels. but if you hit a bad pot hole it may mis-center your wheel
Old Fri, Jun-30-2006, 03:24:18 PM   #39
Keith_m3-4
Keith_m3-4's Avatar
no vibrations.. wonder why BBS only chamferred the front wheel but not the rear? also.. is it just me or does the are actually handle different with the spacers? Doesn't feel as planted. Sure looks aggressive though!
'02 TiAG SMGII
Old Thu, Jul-06-2006, 04:42:33 AM   #40
dizzy
dizzy's Avatar
Reputation: 0 dizzy is on a distinguished road
I've had 10mm front and rear spacers for a while now with stock suspension and wheels on my '05 ZCP. It drives fine, with the exception that the fronts contact the fender under very hard braking. I can hear/feel it and can see the rubber on the inside of the fender from the few times I've had to brake that hard. I'm about to remove the fronts to avoid this problem.
I don't know what options I have other than to lose the spacers. I'll keep the rears for now and hope that it doesn't affect the handling. When I finally get around to tracking the car (one of these days), I'll remove the rears as well... at least for the track days.
If I have any other options (that will let me keep the spacers all around), I'd love to hear about it...
BTW, the sig pic is pre-spacers.
-David
2005 SilverGrey/Blk Leather, ZCP, SMG,
Xenons, H/K sound, Moonroof, SS lines, P7II brake pedal
Jump to top dizzy is offline   Reply With Quote
csl, spacers, stance, wide
A few shots of the new stance... VeeM3 Member Photos and Videos 25 Tue, Jul-22-2008 11:14:11 PM
Pics of the new toy-- e36 track car that I'll be wide LS1ing and wide bodying Obioban Member Photos and Videos 42 Sun, Jul-20-2008 01:15:13 AM
finally bought a WIDE lens. my dish is wide too. so gti Member Photos and Videos 11 Sun, Feb-04-2007 02:27:21 AM
Wheel spacers, Wide CSL look... Part 2 Benjithx E46 M3 (2001-2006) 46 Thu, Sep-07-2006 11:19:10 PM
Discussing wide stance (csl look) spacers in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
