look at me!!!
got my new tires mounted balanced and wheel alignment now my steering wheel is is not centerd instead its center point is to the right whats that mean?
Dr. Evil Returns
That means they screwed up. Take it back and have them center the wheel and realign.
Alex
#3 | |
look at me!!!
#4 |
Full Tilt Boogie
![]() Location: Queens,N.Y.
The steering wheel needs to be locked down in the centered position and then have them readjust the toe setting.
They need to use something like this or a similar variation: RJ
2006 Interlagos Blue 6spd - ZCP, Xenons, HK, NAV, Alcantara Interior, and not much else. |
#5 |
Tire shop put new tires on my '05 M3 and, after three attempts, steering wheel is still off center (counterclockwise)... seems to be getting a bit worse. other than changing tire ships, any thoughts?
#6 |
honestly, your tire shop flat out sucks if they can't get the wheel centered on 3 tries, I watched the guy at my shop center my wheel in less than 5 mins after it was on the lift
#7 |
could anything else be contributing? it does seem to be getting more off-center?
#8 |
![]() Location: Lakeland
To the original poster: Did you have 4 tires mounted? Is the steering off to the right but the car tracks str8? If so then yea the toe is off and they need to readjust it.
To Stephen F, lot of variables in your situation, did you have all 4 replaced or just 2? Does the alignment rack there using look fairly new, did you ask the shop when the last time was they had the rack calibrated?
02 Vert SMG silver on silver. |
#9 |
Thanks. Just the rear tires were replaced and i didn't look at their equipment.
#10 |
![]() Location: Hong Kong
I always request to sit in the car make sure the steering wheel is really in the center position during alignment, but should only be possible in an indie shop.
![]() GC07 - CSL - TE37 - OEM - 547R - C22- 565R 8-year-old M3 is sold!! |
| alignment, centered, mounted, steering, tires, wheel |
| steering wheel crooked...not alignment | prorcracer87 | E46 M3 (2001-2006) | 14 | Tue, Jul-21-2009 04:57:11 PM |
| Wheel Alignment, New Tires, Car Still Drifts Right | R1blade75 | Faults, Fixes and DIY | 3 | Sat, Sep-06-2008 07:01:40 AM |
| steering wheel vibrating, even after alignment | TakmaN | E46 M3 (2001-2006) | 8 | Thu, Jun-19-2008 02:50:57 AM |
| Steering wheel alignment off after snow tires????? | baltimoreM3 | E36 M3 (1992-1999) | 12 | Thu, Feb-01-2007 11:03:46 PM |
| Steering wheel becomes so light after Alignment. Please help! | M3_Fan | E46 M3 (2001-2006) | 7 | Sun, Oct-29-2006 04:54:22 AM |
