Old Thu, May-25-2006, 01:47:24 AM   #1
///dean
98 AW M3/2/5
///dean's Avatar
Reputation: 0 ///dean is on a distinguished road
Default Rattle when closing the driver door w/ window fully down
Is it normal that the driver door has an ugly sounding rattle to it when closing the door w/ the window completely down? The passenger side is ok..no rattle, solid sound when slammed. But..the driver door, different story, sounds like an old domestic (no offense ) when slammed. Feel free to run out to your garages and experiment
Jump to top ///dean is offline   Reply With Quote
Old Thu, May-25-2006, 01:50:26 AM   #2
Beowoulf
Dr. Evil Returns
Beowoulf's Avatar
Reputation: 0 Beowoulf has disabled reputation
United Nations
This is what happens when you close the door using the window. Take it to the dealer and they will fix it.
Alex
Jump to top Beowoulf is offline   Reply With Quote
Old Thu, May-25-2006, 02:02:22 AM   #3
///dean
98 AW M3/2/5
///dean's Avatar
I guess that was the way it was closed while on the dealer lot....I sure as hell don't close my door that way, it's only 1400 miles old.
Old Thu, May-25-2006, 02:08:14 AM   #4
Beowoulf
Dr. Evil Returns
Beowoulf's Avatar
United Nations
Don't sweat it, it is an old BMW problem and mine did the same thing. If you have tint, make sure you check it after they fix it since they may damage it like they did mine.
Alex
Old Thu, May-25-2006, 05:54:33 AM   #5
///dean
98 AW M3/2/5
///dean's Avatar
Thanks....just got back from a 2 hour drive home and what do you know. I noticed slight window rattle even when fully closed and occasionally a sound of seeping wind.
By the way, is this a simple fix short enough for me to wait for?
Thanks for the info.
Old Thu, May-25-2006, 03:29:05 PM   #6
ThatOneGuy
In the left lane, flashing to pass.
ThatOneGuy's Avatar
Reputation: 0 ThatOneGuy is on a distinguished road
Germany
I took mine in for a rattle in the door with the window up. They put some aqua-felt (sp?) in frame that the holds the window. Rattle fixed.
Jump to top ThatOneGuy is offline   Reply With Quote
Old Thu, May-25-2006, 09:30:49 PM   #7
fun2drv
Reputation: 0 fun2drv is on a distinguished road
I had that problem in my 330Ci several times and it was caused by a wire bundle coming loose inside the door. It is a quick fix that should take less than 1 hr.
Jump to top fun2drv is offline   Reply With Quote
Old Thu, May-25-2006, 09:57:47 PM   #8
nutz330ci
Reputation: 0 nutz330ci is on a distinguished road
Mine rattles from the rear windows when they are open and I go over bumps around town etc. I looked at it and dont see an easy fix?
06 M3 Vert
CB/Imola
Jump to top nutz330ci is offline   Reply With Quote
Old Fri, May-26-2006, 04:16:09 PM   #9
The Dough
The Dough's Avatar
Reputation: 0 The Dough is on a distinguished road
United Nations
I had the problem in my 330ci many times also. There is a metal sleeve in the door with 4 bolts that can come loose. It could also be the window regulator that is broken or defective. Its an easy fix...don't worry too much.
Jump to top The Dough is offline   Reply With Quote
Old Thu, Sep-18-2008, 07:32:34 PM   #10
kkamakasi
울산박
kkamakasi's Avatar
Reputation: 0 kkamakasi is on a distinguished road
South Korea
I just noticed today that my driver side window does not make solid contact with the rubber seam (part of the B-Pillar) that keeps the water out. When the door is opened and the window is fully up, the window seems to sway from side to side by about 5 mm or so. There is movement, that's what I'm trying to say. The passenger one is fine. I do have a bentley manual but can't find a fix for tightening up the window so that it won't have any play in the door. Anyone know a DIY or a page number?
Gone...... and forgotten
Jump to top kkamakasi is offline   Reply With Quote
Rattle when closing door and window down *fix* LBSOHK E46 M3 (2001-2006) 28 Wed, Apr-24-2013 04:33:24 AM
Problem: driver side door window opens and closes and hazards flashing lightspeed E46 M3 (2001-2006) 4 Mon, Jan-10-2005 06:24:07 PM
dealer F'ed up my window-rise on closing door Raffy-D E46 M3 (2001-2006) 9 Fri, Dec-03-2004 08:39:58 PM
Auto window closing adder_uk E46 M3 (2001-2006) 4 Sun, Mar-28-2004 04:54:05 PM
Door closing problem Speedfreak E46 M3 (2001-2006) 1 Thu, Aug-01-2002 09:46:00 AM
Discussing Rattle when closing the driver door w/ window fully down in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
