Old Mon, Jun-12-2006, 08:22:35 PM   #1
YYZ-M3
Reputation: 0 YYZ-M3 is on a distinguished road
Default Heated Seat Retrofit
Has anyone used the OEM BMW kit:
http://www.realoem.com/bmw/showparts...=52&fg=95&hl=9
And pulled this off?
Cheers!
Jump to top YYZ-M3 is online now   Reply With Quote
Old Mon, Jun-12-2006, 08:41:15 PM   #2
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
wow.. that looks kewl. i use to have heated seats before switching to CSL seats. i wonder, i can just get the heating elements and retrofit it? i believe i have everything else.
Old Mon, Jun-12-2006, 08:51:06 PM   #3
YYZ-M3
Since you already have the harness/switches in place, I wonder if you could just buy a kit like this:
http://www.pfyc.com/store/merchant.m...ory_Code=GTINT
Another source:
http://www.leatherseats.com/products2.asp?c=7&id=367
And wire it up!?
Old Mon, Jun-12-2006, 08:54:54 PM   #4
daytonaviolet
OEM CSL Whoore
And wire it up!?
i'd prefer to stay OEM as much as possible. i have my oem leather seats, i'll take a closer look at them and see if i can just buy the similar heating elements and plug/play. yes i believe its just a simple 12v heating element. the stock connector on the oem seats allows for additional compnents to be added. on my CSL seats, its the identical connector but of course the heated element plug is not there. i'll update you what i find
Old Fri, Jun-16-2006, 01:44:21 AM   #5
Chris S
This is how I roll...
Chris S's Avatar
Reputation: 0 Chris S is on a distinguished road
Hey fern...
How can you tell from looking at the underside of a front seat...if it's heated or not?
Any definitive way ? Thanks bud.
2008 Alpine/Black e92 M3, 6MT, loaded...
SOLD!!!!!: 2003 Alpine/Imola M3, 2002 996TT White/Natural
Jump to top Chris S is offline   Reply With Quote
Old Sat, Jun-17-2006, 02:53:35 AM   #6
daytonaviolet
OEM CSL Whoore
Originally Posted by Chris S
Hey fern...
yup.. here is the main connector for our M3 seats. i circled the connector which is used for the heated seat option.
from left to right:
1) power for electric seats (black plug 3 wires)
2) buckle pretensioner (yellow plug)
3) seat belt sensor (black plug)
4) heated seats (black plug)
Old Sat, Jun-17-2006, 03:51:44 AM   #7
YYZ-M3
Thinking about this more, do you happen to have a wiring diagram that relates to this? How many wires are dedicated to the heated seats (looks like at least 5?)
Thanks!
Old Sat, Jun-17-2006, 05:27:54 AM   #8
daytonaviolet
OEM CSL Whoore
Thanks!
the connector has 3 pins. then the 3 wires split up. 3 goes to the back warmer and 3 goes to the butt warmer.
Old Wed, Jul-19-2006, 10:47:58 PM   #9
YYZ-M3
Hey Fern,
I now have the switch panel and the wiring diagrams for the car. Looks like the switch panel controls/regulates the heat (which is great) and now I just need to build a harness from fuse panel to the switch panel and another harness to run from the switch panel to the seats!
Could I trouble you to snap a picture of the connector that is mounted in the car that connects up to the heated seats? Or is it all integrated into the one factory plug?
Thanks for your help with this!
Old Thu, Jul-20-2006, 12:07:54 AM   #10
daytonaviolet
OEM CSL Whoore
Hey Fern,
let me try to take that pic tonight.
heated, retrofit, seat
heated seat retrofit diy with oem parts bmwbob E46 M3 (2001-2006) 32 Wed, Sep-22-2010 01:52:14 AM
Heated Seats Retrofit? gz97zx E46 M3 (2001-2006) 2 Fri, Apr-07-2006 06:19:07 PM
Heated seat retrofit? Shinkaze E46 M3 (2001-2006) 10 Wed, Oct-13-2004 11:33:24 PM
heated seat retrofit? DMan E36 M3 (1992-1999) 12 Wed, Oct-13-2004 06:39:18 PM
heated seat question low_bmw E36 M3 (1992-1999) 2 Fri, May-28-2004 10:34:55 PM
Discussing Heated Seat Retrofit in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
