Old Thu, Jun-29-2006, 03:20:24 AM   #11
willThomas
///M3 Wi11
willThomas's Avatar
Reputation: 0 willThomas is on a distinguished road
I think the problem in the E36 climate control was the control unit and a capacitor on it. I've seen some posts about that and it was a common problem. I don't know that you'll have a problem with your 04 M3. Seems like they would have fixed it by then. Good luck!!
///M3 Wi11
Jump to top willThomas is offline   Reply With Quote
Old Fri, Sep-29-2006, 03:34:19 AM   #12
TxnBluDvl
Too far gone.
Reputation: 0 TxnBluDvl is on a distinguished road
I just did this on a 3/01 build 2001 M3. The pictures are accurate and the procedure is completely right.
Jump to top TxnBluDvl is offline   Reply With Quote
Old Mon, Oct-02-2006, 06:49:38 PM   #13
zshiek
zshiek's Avatar
Reputation: 0 zshiek has disabled reputation
great work.. your less lazy then myself. :-)
Jump to top zshiek is offline   Reply With Quote
Old Sat, Jan-12-2008, 07:20:29 PM   #14
denzbeanz
Reputation: 0 denzbeanz is on a distinguished road
awsome thanks this sorted out my intermittent fan problem, many thanks
Jump to top denzbeanz is offline   Reply With Quote
Old Sat, Jan-12-2008, 07:46:14 PM   #15
Silver///M
۞Fahad ۞
Silver///M's Avatar
Reputation: 0 Silver///M is on a distinguished road
Qatar
Just FYI guys if you don't do the FSR sooner your car might look like this someday.
Jump to top Silver///M is offline   Reply With Quote
Old Tue, May-06-2008, 04:27:32 PM   #16
aram535
Reputation: 0 aram535 is on a distinguished road
Default Lost the T20 screw
Can anyone tell me or send me a picture of that gold T20 screw? I was putting everything back and it dropped into the abyss of the car innerads never to be found again.
I went to the local bmw shop but they couldn't find a exploded diagram of the section so that we can identify the screw part number.
Thanks.
Jump to top aram535 is offline   Reply With Quote
Old Sat, Nov-29-2008, 02:55:07 PM   #17
RADV
Reputation: 0 RADV is on a distinguished road
After searching and reading several bimmer forums I found this! The most complete explanation and pics are really helpful.
But to have the job done on my 2002 E46 was another story. Was really, really, really hard! I was almost to give up couples of times. It took me 2 hours! My body is contorted by now!
But finally I managed to do it and everything works fine!
I really appreciate your help. Thanks a lot!
RADU form Romania
Jump to top RADV is offline   Reply With Quote
Old Mon, Jan-26-2009, 09:07:15 PM   #18
odiedog52
Reputation: 0 odiedog52 is on a distinguished road
i spent a few hours on this today ... and have clear access to the FSR. But there is something slightly blocking it and i can't pull the FSR all the way out. It says something about getting a piece off in front of the FSR but honestly i can't figure it out.
Any help???
2002 TiAG M3 AA Gen 3 Level 2 supercharged with meth injection and nitrous wrecked
Best Time: 12.34 @ 115.74 (no nitrous)
469rwhp/321tq (no nitrous)
Jump to top odiedog52 is offline   Reply With Quote
Old Mon, Jan-26-2009, 09:18:03 PM   #19
willThomas
///M3 Wi11
willThomas's Avatar
Any help???
Well, there's a couple of things. Go back and read the procedure closely. There's a vent valve that you have to take out and then there's the wire harness attached to the Final Stage Resistor itself. There's also a small bent metal bar that could provide some interference, but from what I remember, once everything was prepared like in the procedure, it came out pretty easy. Make sure you've taken out all the screws too. If it doesn't seem like it's budging at all, it's probably a screw you forgot to take out. Good luck.
///M3 Wi11
Old Thu, Jan-29-2009, 01:58:20 AM   #20
odiedog52
It was the vent valve (or what it mounted to) i'm pretty sure. Got really frustrated and ended up ripping it off ... :/ i didn't think it was important, woops. Luckily this wasn't my M3 and it was the 330. I couldn't figure out for the life of me how to get the thing out of the way.
diy, e46, final, resistor, stage, w or pics
DIY: E46 M3 Final Stage Unit / Resistor Location zshiek Faults, Fixes and DIY 10 Sat, Oct-30-2010 06:00:07 AM
Blower motor or final stage resistor? mighty-dog E36 M3 (1992-1999) 2 Mon, Nov-27-2006 11:12:47 PM
Blower Motor Resistor vs Final Stage Unit bigneil E36 M3 (1992-1999) 3 Fri, Mar-31-2006 11:23:20 PM
WT heck is the Final Stage Resistor (blower motor) on my 99 M3?! magas E36 M3 (1992-1999) 5 Sat, Jun-19-2004 05:01:40 PM
final stage blower resistor install??? punkska20 E36 M3 (1992-1999) 1 Fri, Jul-25-2003 06:46:52 PM
Discussing DIY- E46 Final Stage Resistor w/pics in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
