Old Tue, Jul-25-2006, 01:23:17 AM   #1
Techno ///M3
Techno ///M3's Avatar
Reputation: 0 Techno ///M3 is on a distinguished road
Default What is the E36 M3's gear ratio
is it true what i am reading? 3.23:1?
it feels like 4:10
Jump to top Techno ///M3 is offline   Reply With Quote
Old Tue, Jul-25-2006, 01:26:20 AM   #2
it feels like 4:10
95 3.15
96+ 3.23
Old Tue, Jul-25-2006, 01:27:09 AM   #3
Doc_SoCal
Negative Elitist Bastard
Doc_SoCal's Avatar
Reputation: 0 Doc_SoCal is on a distinguished road
There were four different transmissions used on 3.2-liter M3s. European-spec models have a Getrag six-speed manual transmission with the following ratios: 4.23 (1), 2.51 (2), 1.67 (3), 1.23 (4), 1.00 (5), .83 (6). This same gearbox was later used (with the same ratios) as the internals of the Sequential M Gearbox (SMG).
The North American-spec 3.2-liter E36 M3 retains the ZF Type C five-speed manual gearbox of the 3.0-liter version, with the same internal ratios: 4.20 (1), 2.49 (2), 1.66 (3), 1.24 (4), 1.00 (5). Starting with the 1997 model year, the ZF 5HP18 five-speed automatic returned as an option with the same internal ratios used on the 3.0-liter model: 3.67 (1), 2.00 (2), 1.41 (3), 1.00 (4), .74 (5).
All 3.2-liter M3s equipped with a manual gearbox (including SMG) use a shorter 3.23:1 final drive and limited slip differential. North American-spec M3s with the ZF five-speed automatic transmission have an even shorter 3.38:1 rear end, also with limited slip. In addition, all 3.2-liter North American-spec E36 M3s are equipped with Automatic Stability Control plus Traction (ASC+T) which can apply the brakes and/or reduce engine power in order to maintain traction. It includes an orange warning light under the M logo in the instrument cluster and can be switched off via a console-mounted button.
Jump to top Doc_SoCal is offline   Reply With Quote
Old Tue, Jul-25-2006, 01:31:36 AM   #4
TAMUmpower
Blessed with M Power...
TAMUmpower's Avatar
Reputation: 0 TAMUmpower is on a distinguished road
Well, im assuming your comparing your car to another manufactured car. The M3 uses high transmission ratios and a low final drive ratio. Where other cars can have the same total ratio because they have the opposite gearing. you have to look at the total ratio when comparing cars.
My Car's Site
Jump to top TAMUmpower is offline   Reply With Quote
Old Tue, Jul-25-2006, 02:52:21 AM   #5
Techno ///M3
okay totally understood, but what if i want to build up my engine? Get it to about say 400 to 500 hp? you know like adding a super charger + internals. wouldnt it be wise to change out to a better gear ratio?
Old Tue, Jul-25-2006, 03:02:47 AM   #6
VTRick01
VTRick01's Avatar
Reputation: 0 VTRick01 has disabled reputation
word has it anything much over 400 hp is not cheap or especially easy....you might be happy with 400 hp and changing your ratio...
98 M3 Sedan, Cosmos Black /// Alpine head unit, JL Audio Sub, Xtant Amp, MB Quart component front spkrs /// UUC Clutch stop /// Axxis Ultimates /// Rogue RSMs /// Powerflex RTABs
Jump to top VTRick01 is offline   Reply With Quote
Old Tue, Jul-25-2006, 03:33:28 AM   #7
Techno ///M3
yea thats what i am speaking of, but which ratio is recommended for motors putting out over 400 hp
Old Tue, Jul-25-2006, 05:55:26 AM   #8
SG_M3
#56 JP M3
Reputation: 0 SG_M3 has disabled reputation
for a s/c car? 3.64 or 3.46.
turbo? 3.15 or 3.23.
Sean
Jump to top SG_M3 is offline   Reply With Quote
Old Tue, Jul-25-2006, 08:03:14 PM   #9
Techno ///M3
then how come corvette and z28 drivers say i should go to 4:10...probably because i drive a bmw, they dotn know any better lol
Old Tue, Jul-25-2006, 08:08:30 PM   #10
Z Driver
Z Driver's Avatar
Reputation: 0 Z Driver is on a distinguished road
The V8 guys aren't geared like a four cylinder from the factory like the M3. They can get away with shorter ratios.
Our 5th gear ratio is 1:1. That is usually the 4th gear on most transmissions.
A turbo car can benefit from a taller than stock ratio because it lets the car build and stay in the boost longer.
1996 ///M3 Boston Green / Modena, Lux package, sunroofless, factory wing
2001 Honda S2000
Jump to top Z Driver is offline   Reply With Quote
The benefits of a shorter gear ratio in the E46 M3 Divexxtreme M3 Track: Racing and DE 46 Sat, May-17-2008 01:32:47 PM
gear ratio questian youlost E36 M3 (1992-1999) 5 Fri, Jan-13-2006 05:38:44 PM
gear ratio cougarslammer E36 M3 (1992-1999) 3 Tue, Aug-30-2005 02:25:34 AM
4.10 gear ratio mpowr3 E46 M3 (2001-2006) 2 Wed, Mar-16-2005 12:16:33 AM
3.91 Differential Ratio Gear 1/4 time Tiago E46 M3 (2001-2006) 12 Wed, Dec-03-2003 05:57:09 PM
Discussing What is the E36 M3's gear ratio in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
