#11 | |
![]() Location: Keller
Have others ever tried an electric fan and seen a benefit on track? You could test for an improvement by removing the mechanical fan during a hot session and checking your lap times. I could wrench for you if you want to try it, lemme know.
#12 |
![]() Location: Austin
Step 1 is to wire in the aftermarket gauge for water temp and get your readings. If it's hot then start worrying about adding/deleting fans, bigger radiators etc...
At least that's my plan. |
#13 | |
Brake.Enter.Apex.Exit.Acc elerate
![]() Location: Oceanside, New York
John
BMW M3 ZCP 2005 - TiAg/Cinn - 6spd Performance: CSL Headers/BMW Msport 4:10/BW Race Exh/TMS Intake/Epic Tune(GTS3)/TMS Race Pulleys/ BW Oil DV/ BW Solid Trans and Engine Mounts/ BW Oil Cooler and CR Radiator, BW Diff Cooler Safety: Schroth Profi II 6pt Hans/Hans/4l Fire Suppression Brakes: PFC Z45 (F), PFC DD Rear Suspension: MCS Rear Coilover 2Way 800/425, Rogue RTAB/FCAB/RSM/RLCA/GC Camber Plates/H&R Front Sway/ F&R Subframe/PF Subframe bushings Wheels: TR-1 18x9.5 w/ 275/35 Hoosier (R6) Apex Arc-8 Hoosier (R6)/ Apex Arc-8 18x9.5 w/ 275/35 Conti Ext Cont DW (WET) Interior: OMP HTE/BW Solid Shifter/Jaffster Shift Knob/CF Sunroof Delete/ Full Cage (Dave Weaver) Exterior: BW Brake Ducts/Vorsteiner Trunk and Rear Diffuser, BW Dive Planes, BW Wing, Weaver Splitter |
#14 |
///M POWER
30101516 is the fan I got, and was recommended to get by bimmerworld. They said it would be fine to run in my m3 with no front aux fan(mine is not working for unknown reasons atm..) It turns on when the temp is at the second white line(pretty uncomfortably high for me...) I have a bored out thermostat(came with the car) and the car runs at half way on the freeway and maintains a good temp around town unless i'm sitting at a light for a while or going up hills and in traffic... When the car is moving at any speed however the fan doesn't turn on and even if it did, it would be absolutely worthless, it feels like I could blow at the radiator just as hard as the fan blows -.- The worst part being I spent about 140$ to get the whole kit and it doesn't even work the way its supposed to... Is there one or two speeds for this fan? How do I set the controller as mentioned earlier in the thread?
![]() TRM |
| fan, installation or parts, list, spal |
| Spal Fan | TJ_GUNZ | E36 M3 (1992-1999) | 7 | Wed, Aug-20-2008 01:48:34 AM |
| List and prices of OEM parts? | jared1048 | E46 M3 (2001-2006) | 7 | Thu, Aug-17-2006 02:37:46 AM |
| Spal Fan Controller question | Stewbacca6 | E36 M3 (1992-1999) | 1 | Thu, Aug-03-2006 01:34:34 AM |
| Parts list for PSS9 needed! | AxelF | E46 M3 (2001-2006) | 2 | Tue, Jun-13-2006 10:41:33 PM |
| GB: Spal Cooling Fan for FDM | NY98M3 | Parts for Sale/Wanted | 1 | Wed, Mar-02-2005 05:16:11 PM |
