Old Mon, Jan-01-2007, 06:19:45 PM   #21
bmw4life13
bmw4life13's Avatar
Reputation: 0 bmw4life13 is on a distinguished road
How much does a new glove box assembly cost?
Jump to top bmw4life13 is offline   Reply With Quote
Old Mon, Jan-01-2007, 06:21:43 PM   #22
bmw4life13
bmw4life13's Avatar
Braymond141, what did you mean by expanding the hole toward the front of the glove box? Sorry, but I'm confused.
Old Mon, Jan-01-2007, 08:40:41 PM   #23
bigneil
bigneil's Avatar
Reputation: 0 bigneil is on a distinguished road
It is $600 for a new glove box, before discount. And going up over time. With discount, you can get one for about $500, and can hock your old one for $120 on eBay. So it's really only about $400 to upgrade (after shipping).
Jump to top bigneil is offline   Reply With Quote
Old Mon, Jan-01-2007, 10:33:39 PM   #24
epj3
Reputation: 0 epj3 is on a distinguished road
Originally Posted by PurpleM3Pursuit
thinking the same thing.. maybe ill sell the glove box for 50$ (since its not sagging and put a nice panel in there.. lol..
Carbon fiber glovebox mod1!!!11
Jump to top epj3 is offline   Reply With Quote
Old Tue, Jan-02-2007, 01:31:30 AM   #25
TheSt|G
Resident Tamed Racing Driver
TheSt|G's Avatar
Isle of Man
Originally Posted by Dreams190
I just want mine fixed because the glovebox sags and the light stays on and glows through the opening at night, lol
My brother's does that. I poke his glovebox every time I'm in his car since it bugs me, he doesn't care about it tho.:nixweiss:
Andrew
Current - '10 E82 M-Sport 6MT Coupe
Sold - '03 Lemans on Lemans E39 6MT M5
Sold - '99 Kosmos-Schwarzes on Dove E36 5MT M3 Coupe
Maxed Out Bolt-On E36 ///M3 | My E36 Member Journal
No third pedal no care
Old Tue, Jan-02-2007, 01:36:18 AM   #26
You need to look at the pictures on the DIY.
Old Tue, Jan-02-2007, 04:21:16 PM   #27
ollie, ollie M3
ollie, ollie M3's Avatar
Reputation: 0 ollie, ollie M3 is on a distinguished road
Originally Posted by ollie, ollie M3
I got the parts and was just getting ready to do this fix today, but the domain name expired 12/01/06. Did anyone save this .pdf elsewhere?
OK, for what it's worth, here's the Google html version of the .pdf but without the pix. As long as I have the parts, I'm going to do this anyway.
This is the html version of the file http://www.totalbmwmag.com/HandsOn/TechFeb04.pdf.
G o o g l e automatically generates html versions of documents as we crawl the web.
To link to or bookmark this page, use the following url: http://www.google.com/search?q=cache...s&ct=clnk&cd=1
Google is neither affiliated with the authors of this page nor responsible for its content.
These terms only appear in links pointing to this page: totalbmwmag com handson techfeb04 pdf
Saggy glovebox letting your 3-Series interior down? Sort it
out with an hour’s work and the cheapest parts you’ll ever
buy at BMW.
Parts Counter
51 16 8 168 863
Plastic tongue
51 16 8 177 889
Glovebox latch
51 16 1 960 458
Blanking plugs (black)
The good news is it’s simple to fix. Totally
rebuilding the lock with new parts from BMW
will cost just £3.50, so if you’re sick of looking
at a wonky dashboard in your 3-Series, read
on and find out how to smarten things up.
1
Here’s your problem: the glovebox lid doesn’t shut properly and you can see
the latch mechanism through the gap. In really bad cases the light will be on
permanently at night, too. Michael Caine-style driving gloves are optional.
2
You don’t need to remove the entire glovebox assembly to access the lock,
since the mechanism is actually part of the vent panel above the glovebox lid.
Start by removing the two crosshead screws hidden in the top outer corners.
3
The lower edge of the panel is held in by two more screws. They’re hidden
behind these small plastic blanking plugs, which you will need to carefully
prise out. Use a small screwdriver and be careful not to gouge the plastic of the
frame. It’s almost impossible to remove these plugs without damaging them, but
since they’re only 16p from the dealer, treat yourself to a new pair.
4
Once you’ve removed the screws, slide the vent panel out and you can access
the latch assembly.
5
The problem is that the tongue which holds the metal catch closed is made
from plastic and over the years it just wears away, latching the lid progres-
sively less tightly.
6
A new plastic tongue is just a few pence and you can see how it compares to
the old item here. Fitting it is just a question of removing the retaining
bracket and then unscrewing the replacement tongue. Slip the new tongue into its
place and remember to hook the spring around it. Tighten it into place but don’t
overdo it — make sure it can still spring backwards and forwards.
7
Slide the vent panel back into place, tighten the screws and press the blanking
plugs over the lower two screws. Remember to seat the vent panel properly and
tighten the screws firmly. The bottom two screws have a ridge around the head which
the blanking plugs clip to, so make sure you get the screws the right way round.
8
The tongue for the latch on the glovebox lid is made from brittle alloy and you’ll
often find the corners snapped away if someone’s previously over-tightened it.
It’s easy to replace and since it’s only £1 you may as well replace it while you’re doing
the job. You’ll need a miniature crosshead screwdriver to remove the two small
screws holding it to the glovebox lid.
9
Job done. Total cost just £3.50, a glovebox which finally shuts properly and a
dashboard which looks like it belongs in a BMW, not a Fiat. You’ll also find the
glovebox light isn’t permanently on.
TOTAL BMW FEBRUARY 04
'95 Avus M3a
looks stock
Jump to top ollie, ollie M3 is offline   Reply With Quote
Old Sun, Jan-07-2007, 01:36:58 PM   #28
gregoryp
Reputation: 0 gregoryp is on a distinguished road
Smile Glovebox Fix
I tried the slotted hole fix and it didn't make any difference, but after messing with it I realized that the two tabs on the bottom of the vent assembly were not engaged with the holes in the front edge of the glove box. I snapped those in and it is great now.
Thanks.
Jump to top gregoryp is offline   Reply With Quote
Old Fri, Sep-05-2008, 10:45:21 AM   #29
chicane
Reputation: 0 chicane is on a distinguished road
Did anyone save off this PDF by by any chance? Are there other methods for repairing a sagging glovebox?
Jump to top chicane is offline   Reply With Quote
Old Fri, Sep-05-2008, 03:58:15 PM   #30
M3CH
Reputation: 0 M3CH is on a distinguished road
http://www.m3forum.net/m3forum/showthread.php?t=134066
///M3
1998 Jeep Cherokee
97 BMW M3
95 Toyota Supra TT
11 Harley FXDWG
09 Kawisaki ZX-6R
08 E90 BMW M3 SSII 6 speed(SOLD)
05 E46 BMW M3 TI Silver 6 speed (SOLD)
Jump to top M3CH is offline   Reply With Quote
fix, glovebox, saggy
Can't get my glovebox open RedFD3SR1 E46 M3 (2001-2006) 63 Tue, Jan-19-2010 07:01:02 PM
Saggy Gas Lid DIY??? CantbePhaded04 E36 M3 (1992-1999) 9 Thu, Oct-11-2007 09:58:47 PM
QUick E36 Saggy Glove Box Fix Doc_SoCal E36 M3 (1992-1999) 11 Tue, Jul-11-2006 03:49:01 PM
Glovebox vibration after "fix" to sagginess. bigneil E36 M3 (1992-1999) 5 Fri, Oct-14-2005 11:33:34 PM
Removing the glovebox DMan E36 M3 (1992-1999) 9 Thu, Jan-20-2005 01:39:32 AM
Discussing Saggy glovebox fix in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
