Old Mon, Sep-11-2006, 07:42:02 PM   #1
Gtrial
Reputation: 0 Gtrial is on a distinguished road
Default Oil dipstick marks...
Does anyone know how much oil you need to bring the oil level from the bottom mark to the top mark on the dipstick?
Jump to top Gtrial is offline   Reply With Quote
Old Mon, Sep-11-2006, 07:50:14 PM   #2
spta97
spta97's Avatar
Reputation: 0 spta97 has disabled reputation
Default According to page 122 in the manual
"The oil volume between the two marks
on the dipstick corresponds to approx.
1.4 US quarts/1.3 liters."
Jump to top spta97 is offline   Reply With Quote
Old Mon, Sep-11-2006, 07:50:28 PM   #3
eMphatic
MMM
eMphatic's Avatar
Reputation: 0 eMphatic is on a distinguished road
I believe it is supposed to be in the middle. Basically those lines are min and max marks.
Jump to top eMphatic is offline   Reply With Quote
Old Mon, Sep-11-2006, 07:52:08 PM   #4
spta97
spta97's Avatar
I don't know about that. According to the mad russian site 6 liters (which the S54 calls for) fills it up to the top mark on the dipstick.
Now do you guys have any tricks for actually seeing where the oil is? When I change oil (in any motor) I have a very difficult time seeing where it is because it is pretty clear. The best I came up with was pressing it on a paper towel.
Old Mon, Sep-11-2006, 07:54:26 PM   #5
Estoril 2004
Estoril 2004's Avatar
Reputation: 0 Estoril 2004 is on a distinguished road
I would never have my oil at a level where it's in the midde of the stick. I think right on the top line is ideal, but never over it.
2004 Estoril blue, Individual Series, Nav, 19" BBS RS GT, CDV Delete, UUC SSK, Euro cross-drilled rotors, Axxis Ultimates, Rogue mid-pipe, clear reflectors, Hardwired Passport X50, Blinder M20 Laser Jammer, 35% Tint (SOLD)
2006 E55 Renntech Stage One
Jump to top Estoril 2004 is offline   Reply With Quote
Old Mon, Sep-11-2006, 07:58:01 PM   #6
Joe@PTech
NorCal BMW Specialists
Joe@PTech's Avatar
Reputation: 0 Joe@PTech is on a distinguished road
In the middle would mean you are low. I would not recommend that advice to anyone. Your oil should be close to the top line but not over. You should check your oil level every other full tank of gas to insure you are running a safe amount at all times.
Always check your oil prior to an aggressive drive or event. Lastly, carry 1 bottle of Castrol TWS with you in case you are low. This oil is very hard to find outside of a dealer, so it is a good idea to carry one with you at all times. The dealer even sells a oil kit with the TWS oil, leak proof bag, etc. all for about $12. It can stay in your trunk.
Joe Gaffey | Performance Technic
email: info@performancetechnic.com | phone: 925.426.1361
facebook | twitter | PerformanceTechnic.com
Jump to top Joe@PTech is offline   Reply With Quote
Old Mon, Sep-11-2006, 08:02:11 PM   #7
ArtM3
Reputation: 0 ArtM3 is on a distinguished road
BMW states it should be in the middle...
having said that anywhere between the marks is OK...
when adding, add just a little, 1/4 bottle, and check...
the factory fill number is 5.5 liter (bottles) or 5.8 qts
Jump to top ArtM3 is offline   Reply With Quote
Old Mon, Sep-11-2006, 08:02:43 PM   #8
Estoril 2004
Amen!!
Old Mon, Sep-11-2006, 08:05:48 PM   #9
fastfed
fastfed's Avatar
Reputation: 0 fastfed is on a distinguished road
Dipsticks=Dummysticks..
They are not all that accurate and vary between cars.. I know that sounds crazy but its true..
Here is how I do all my cars..
I change the oil and put "ONE" less quart in the car, I start it up and let it run for a little and then let it sit for a minute.. I mark the dummystick then add the other quart and mark that line.. It will now show you if its a quart or so less and where YOU SHOULD BE with the other mark..
Jump to top fastfed is offline   Reply With Quote
Old Mon, Sep-11-2006, 08:06:38 PM   #10
Beowoulf
Grumpy
Beowoulf's Avatar
Reputation: 0 Beowoulf has disabled reputation
United Nations
and never put in 6 liters of oil at an oil change. 5.5L, drive and then check before adding more.
Alex
Jump to top Beowoulf is offline   Reply With Quote
Watch Your Electronic Oil Dipstick! sciaenops E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) 19 Fri, Oct-03-2008 03:52:53 AM
Oil dipstick loose after M50 Manifold swap bigneil E36 M3 (1992-1999) 8 Sat, Sep-13-2008 03:16:55 PM
i noticed yellowish gunk at the end of oil dipstick.... 24601 E46 M3 (2001-2006) 9 Sat, Apr-29-2006 07:07:05 PM
How dark should the oil be on the dipstick after an oilchange? miktrebla09 E46 M3 (2001-2006) 7 Wed, Mar-15-2006 09:18:01 PM
Question on oil level dipstick. screwdriver E36 M3 (1992-1999) 1 Mon, Dec-29-2003 02:18:59 PM
Discussing Oil dipstick marks... in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
