Old Wed, Sep-20-2006, 08:26:47 PM   #1
Zlatko
Jugosloven
Zlatko's Avatar
Reputation: 0 Zlatko is on a distinguished road
Bosnia and Herzegovina
Default Subframe Bushing DIY?
Heya fellas, i actually DID search, and couldnt come up with anything, does anyone have a detailed subframe bushing DIY?
I know the entire subframe is going to have to come out of the car, and ive come to terms with that, i think im ready..
Anyone know of a good DIY?
Thanks yous
1998 M3 Coupe. RTABs w/Shims. JT-Design RSMs. TMS Solid Diff Bushings. AA DSB
Jump to top Zlatko is offline   Reply With Quote
Old Thu, Sep-21-2006, 01:17:46 AM   #2
SG_M3
#56 JP M3
Reputation: 0 SG_M3 has disabled reputation
Its not hard. Just remove everything. Then use a press or the torch method to remove the old bushings.
Sean
- 98 M3 EB/BLK
Jump to top SG_M3 is offline   Reply With Quote
Old Thu, Sep-21-2006, 03:11:04 AM   #3
Zlatko
Jugosloven
Zlatko's Avatar
I know about the removal of "Everything" dude, but i still would like SOME form of guidance while im down there
Old Thu, Sep-21-2006, 03:18:09 AM   #4
jmd471
jmd471's Avatar
Reputation: 0 jmd471 is on a distinguished road
Good luck with that! Make a writeup for posterity
Jump to top jmd471 is offline   Reply With Quote
Old Thu, Sep-21-2006, 03:22:54 AM   #5
SG_M3
#56 JP M3
remove exhaust
remove diff
remove upper control arm
remove lower control arm
undo the 4 bolts holding the subframe on
fronts are just bolts, the rears are a bolt with a nut on the end of the bushing. then they thread into the body
then either use a torch to heat the bushing then beat it out. Or just have a shop press out the old bushings. If you are using oem then you will need them to press the new ones in.
There are no tricks, thats why i said everything. Its pretty fookin easy to get under your car and look to see what needs to be removed. Can't hold your hand via teh interweb
Sean
- 98 M3 EB/BLK
Old Thu, Sep-21-2006, 03:27:14 AM   #6
Zlatko
Jugosloven
Zlatko's Avatar
Honestly...i will...
I'll make you guys a DIY.
Im tired of more complex jobs not having any kind of quidance grawrrr
And SG_M3, chillax mah brotha..
I had an idea as to what to do, i just was wondering if there were some sort of tips or snags to avoid..
Old Thu, Sep-21-2006, 03:33:47 AM   #7
SG_M3
#56 JP M3
i know you have removed the diff, thats why its only a couple of more steps. The removal of the bushings in the PITA off the project.
Sean
- 98 M3 EB/BLK
Old Thu, Sep-21-2006, 04:17:20 AM   #8
///M3 CRAZY
A.K.A. Drew
Reputation: 0 ///M3 CRAZY is on a distinguished road
buy a bentley. or get a copy of the TIS.
Jump to top ///M3 CRAZY is offline   Reply With Quote
Old Thu, Sep-21-2006, 04:54:22 AM   #9
Zlatko
Jugosloven
Zlatko's Avatar
No worries with that, im taking the subframe to a shop to have them pressed out and new ones pushed in (probably some tms race ones)
Old Thu, Sep-21-2006, 12:26:02 PM   #10
SG_M3
#56 JP M3
solid subframe bushings are not the best idea. Solid bushings anywhere for a street car are a bad idea.
Sean
- 98 M3 EB/BLK
DIY-Rear Trailing Arm Bushing Terrapin Faults, Fixes and DIY 35 Sat, Mar-02-2013 12:28:20 AM
can a subframe be diy eurone46 E46 M3 (2001-2006) 22 Mon, Apr-30-2007 09:40:06 PM
subframe.....DIY? f1nutter25 E36 M3 (1992-1999) 5 Wed, Apr-25-2007 10:07:33 AM
When to weld during subframe bushing job bigneil E36 M3 (1992-1999) 1 Sun, Oct-15-2006 07:35:17 PM
Rear Subframe bushing removal PDoane Faults, Fixes and DIY 0 Mon, May-01-2006 01:24:33 PM
Discussing Subframe Bushing DIY? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
