I noticed water leaking through the seals on both of my rear windows and they are closed shut - I thought is might be due to dust but they continue to leak despite cleaning.....Any suggestion on correcting the problem without bringing it to the dealer??
Is their any cracking around the rubber seal of the window?
AA boosted ..... 71 trim/70 mm pully.... and I LOVE it ! 500+ hp ![]() |
No crack that I can see...the car is only 5 months old. Just wonder if anyone has similar experience with quick fix
#4 |
Its a common problem - the dealer replaced the seals on both sides of my car and it is 3 years old. No more leaking!
#5 |
if you pull the plastic covers you'll see the mechanism is held down by bolts...they are slotted so they can be adjusted...
mine leaked: I pulled the cover opened the window a 1/8" or so loosened the bolts and pulled the actuator in about the same... tightened the bolts and closed the window, seals much better, quieter and no leaks... |
#6 |
Thanks for the recommendations! I think i will take the beast to the dealer and have them fix it....I hate pulling off trim covers - I often either crack them or rip my nails off
#7 |
USAF Fighter Jet Mechanic
![]() Location: North Las Vegas
I guess I'm not the only one. I thought it was due in part to using a pressure washer at the local car wash. I refuse to use the brush on the paint, so I pressure wash the dirt & debris off almost weekly. I do avoid the rear windows as much as possible now. I don't have any problems in the rain though.
2004.5 Silbergrau ///M3 coupe ///6MT ///ZPP black leather ///19" OEMs ///PDC ///Xenons ///Nav ///HK ///Htd seats ///Adj seats with lumbar ///Rear side airbags ///Alum trim MODS: Silver steering wheel trim, Painted headlight trim, Stealth Bulbs, Keyhole cover, Preditor Chromium Angle Eyes, painted fog light covers Also in garage: 2008 Toyota Highlander 2WD |
#8 |
Does the cracking around the rubber seal be covered under maintenance warranty/new car warranty, to get a replacement?
Or is the cracking considered a normal wear and tear, thus NOT covered by the maintenance/new-car warranty? |
#9 |
Dealer just replaced my rear window seals - quick fix if your M is still under warranty. it leaked a little at first then no more after 1 week. The seal must have conformed to the window shape
| leak, rear, window |
| 1997 M3/4 Rear Differential Leak | gregoryp | E36 M3 (1992-1999) | 12 | Sun, May-30-2010 10:54:06 PM |
| Rear quarter windows leak | Bill-banger | E46 M3 (2001-2006) | 1 | Thu, Apr-10-2008 10:19:40 PM |
| rear differential leak | cmy32go | E46 M3 (2001-2006) | 1 | Tue, Oct-31-2006 07:59:57 PM |
| Air Leak From Driver's Side Window | carbon_e46 | E46 M3 (2001-2006) | 8 | Wed, Jan-25-2006 11:38:47 AM |
| Rear Quarter Windows Leak | M3_guy_84 | E46 M3 (2001-2006) | 2 | Sun, Jul-24-2005 05:39:27 PM |
