![]() Location: Houston/Denver
Hey guys..
i was going to put some washer fluid in the windshield fluid tank, and i noticed it started dripping to the ground, even tho the reservoir was not full... i removed the fog light to see the tank better, but i could not see where the leak was coming from.. What is the best way to access this reservoir without removing the bumper? Also, any idea how much this piece will cost to replace? Thanks, Niels |
![]() Location: P.V. and Irvine
mine does the same thing
just dont bother its just extra weight slowing you down |
OEM CSL Whoore
you can access the water bottle by removing the wheel, then the fender liner cover behind the bumper. i think its like 4 screws, 3 on the top and one under the bumper. unless there is a hole in bottle, the pump or level sensor is loose.
Click my sig and view my pics! Tischer aka GetBmwParts VCSL - Bumper DIY VCSL - Bootlid DIY FS: Rear black door panels FS: Oem trunk |
#4 |
thanks!
any idea how much this part will be to replace? |
#5 |
CM.E.AM
![]() Location: Orlando, FL
is there any way to loose this thing? it looks like it weighs a bunch
#6 |
Got Pony?
![]() Location: San Francisco
take is off, and throw it away
Stock: 2006 CB/B. ZPP. Nav. Xenon. HK. SMG. 19". Heated Seats. Cosmetic Mods: Royal F1. Predator Chromium Angel Eye. HID Fogs 6K Prolumen. Premier PPF. 30% Huper Optik Tints. DEPO corners. Painted front reflectors. Stealth Bulbs. M3 logo engraved aluminum pedals. Vorsteiner front splitters. Vorsteiner rear Diffuser. I.C.E.: DICE iPod Integration, EAS VSM. Full Video iPod Integration. Rearview Keyhole Camera. Performance Mods:: D/A Street Software. Streamline Panel Filter. Hardwired V1 (adds 100 ponies). Solid Design Muffler. BBS RS-GT 19" Diamond Black. |
#7 |
i go to school in colorado, so occasionally i need some washer fluid!
#8 | |
OEM CSL Whoore
#9 | |
OEM CSL Whoore
perhaps you can get AA SC stg2 and use the sensor as the alcohol/water injecter level indicator ![]()
#10 |
you can access it by taking off the plastic fender liner.....thru the wheel well
you can remove it and eliminate the light by soldering/attaching/connecting a wire between the two poles....easy to do with any piece of wire and electric tape. the plastic tank weighs next to nothing when empty.....i drained 6 qts of fluid out of mine....so someone can do the calculation to how much was in there....it may hold more than 6qts when full, mine was not...but anyway.
| fluid, question, reservoir, washer, windshield |
| cracked washer fluid reservoir vs CPO | so gti | E46 M3 (2001-2006) | 4 | Sun, Mar-22-2009 09:57:50 PM |
| Question about the windshield wiper fluid reservoir... | hdsr09 | E46 M3 (2001-2006) | 9 | Thu, Apr-10-2008 10:58:38 PM |
| Is the M3 Windshield washer fluid>> | Fstcmpny | E46 M3 (2001-2006) | 1 | Thu, Jan-11-2007 08:26:38 PM |
| Windshield Washer Fluid w/ De-icer | Caz | E46 M3 (2001-2006) | 1 | Wed, Dec-07-2005 11:39:41 PM |
| WTB:windshield washer reservoir (Tank) | Silver///M | Parts for Sale/Wanted | 10 | Thu, Jul-14-2005 01:52:52 AM |
