Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > M3Forum Marketplace > Parts for Sale/Wanted
Parts for Sale/Wanted Post your Parts Wanted, and non commercial bmw related items for sale. We ask that companies selling goods become a Sponsor to advertise your goods.
Old Thu, Dec-07-2006, 12:12:31 AM   #1
tom @ eas
tom @ eas's Avatar
Reputation: 0 tom @ eas is on a distinguished road
Default [eas] * New product announcement * Flash2Pass™ Garage Door Opener System!
You know your garage door remote. Maybe it’s clipped to your visor, or in your purse or your jacket pocket, or under the seat, or in the glove compartment, or stashed away in the console. Maybe it just drove away in the other car.
You know what the battery looks like, too, you replace it every year or so. It’s a nine-volt, or is it two AA’s? You better check before you buy new one. You might even worry about somebody swiping it and using it to get into your house.
We’ve solved these problems by electronically integrating the activation of your garage door opener remote into the high beam switch of your turn signal lever. A double flash of your headlight high beams opens or closes your garage door. <br>
Details:
- A small one time investment gets you the maintenance free system
- Less than half the price of HomeLink™ systems, especially in convertibles
- No remote transmitter to get lost or stolen
- No battery to buy or replace…Flash2Pass™ gets its power from your vehicle
- Digital encrypted signal and rolling code technology for ultimate security
- Quick and easy do-it-yourself installation
- Up to six transmitters may operate a single receiver
- Additional receivers may be installed elsewhere and programmed to your Flash2Pass™ equipped vehicle.
- Works with virtually any garage door opener manufactured since 1982
The Flash2Pass™ consumer products consist of the patented transmitter, and its corresponding receiver.
The transmitter is a radio frequency device that is mounted under the hood of the car. It is relatively small, approximately 2” x 2” x ¾” and is attached under the hood with either the enclosed screws, or the plastic zip tie. The wires are attached with quick crimp connectors to the headlight high beam positive wire and to the ground wire. The Flash2Pass™ transmitter is non-polarized so you can attach either wire to the headlight wires.
The Flash2Pass™ receiver is designed to replace the pushbutton inside your garage. If you have additional functions on your pushbutton that you would like to keep, the receiver can be installed next to your original pushbutton and “piggybacked” to it.
Features:
- A double flash of headlight high beams opens or closes garage door
- Can also open and close gates
- Transmitter mounted under hood of car
- Up to 6 transmitters may operate a single receiver
- “Doggie Door” feature that allows the garage door to be stopped in a partially open state to allow pets to enter and exit the garage.
The Flash2Pass™ transmitter and receiver are packaged as a set that is pre-programmed at the factory, <img src="/images/vendors/f2p/f2pcontentssm.jpg" align="right">or they are available individually. For instance, if you had a two-car garage with one large door for both bays, you would buy one set and an additional transmitter. The additional transmitter would be installed in the second vehicle and the receiver programmed to accept it.
Say you had a vacation home with a garage door opener. You could get an additional Flash2Pass™ receiver for it and then program your car to it. That way, you wouldn’t have to remember to bring the remote with you. It will always be at your fingertips…both at home and on vacation.
Now, if you live in a gated community and the community installed the F2P Integrated Control Access System, you would be able to access the community gate, and your individual garage. We call this the “gate to garage” concept. Also if you worked in a place that had some sort of parking control and the F2P ICAS were in place, you again could use your Flash2Pass™ transmitter to gain access, assuming you were authorized and/or programmed into the receiver.
Models Supported:
1996-2007 3-series, including M3
1997-2007 5-series, including M5
1995-2007 7 series
2004-2007 X3
2000-2007 X5
1996-2002 Z3, including M-Roadster/Coupe
2003-2007 Z4, including M-Roadster/Coupe
2000-2003 Z8
2002-2007 MINI Cooper, including Cooper S & MINI GP
Installation is simple for the DIY type and should take no longer than 15 minutes
http://www.europeanautosource.com/pr...roducts_id=619
Introductory special until Dec 17th!
Tom G. | european auto source (eas)
email: tom@europeanautosource.com web: www.europeanautosource.com
tel 866.669.0705 | ca: 714.369.8524 x22 | fax: 714.908.1796
Blog | Facebook | YouTube | Flickr | Twitter
Jump to top tom @ eas is offline
Rate Seller View Rating
Old Thu, Dec-07-2006, 02:01:50 AM   #2
isugoo
Reputation: 0 isugoo is on a distinguished road
thats really cool!
Will you have DIY write up soon?
Current:
08 E90 Dinan M3 (Exhaust, Mid-Pipe, Suspension, Stage II Software, Intake, Pulley), RE SSK, Performance Steering Wheel, 6MT
Past:
03.5 E46 Dinan Stage III M3 Coupe
08 E92 335i AW/CR
99 E36 M3 Coupe
03 Z33 Nismo R-Tune Z
Jump to top isugoo is offline   Reply With Quote
Old Thu, Dec-07-2006, 03:25:21 AM   #3
tom @ eas
tom @ eas's Avatar
Originally Posted by isugoo
thats really cool!
Sure thing, it will only be about 3 steps since you need to tap one wire and ground another. This is possibly the easiest mod you can perform on your M3.
Jump to top tom @ eas is offline   Reply With Quote
Old Thu, Dec-07-2006, 03:28:49 AM   #4
Rguy
Reputation: 0 Rguy is on a distinguished road
Wont it look silly always flashing your high beams twice and then your garage door opens? People gonna wonder if you have someone hired to sit in your house and wait for you to flash them before they open the garage for you.
Jump to top Rguy is offline   Reply With Quote
Old Thu, Dec-07-2006, 03:31:11 AM   #5
tom @ eas
tom @ eas's Avatar
Doubt it. I'm sure they will want one for their garage as well.
Old Thu, Dec-07-2006, 03:35:35 AM   #6
dreaM3
dreaM3's Avatar
Reputation: 0 dreaM3 is on a distinguished road
^^^^that makes it even cooler. People will think that there's always somebody home
Jump to top dreaM3 is offline   Reply With Quote
Old Thu, Dec-07-2006, 04:21:48 AM   #7
t3stman
t3stman's Avatar
Reputation: 0 t3stman is on a distinguished road
Perfect timing. I might just get this instead of homelink but need to read up on it. Hey Tom, any discount for a GB ?
2005 ///M3Alpine White with Imola Red Nappa Leather, 19", NAV, ZCP Competition Pck, and SMG
Cosmetic Mods: OEM CSL Bootlid, OEM CSL Diffusor, OEM Euro Fire Extinguisher, Premium Clear Bra, EAS Aurora Angel Eyes 6000k, EAS CF Titanium seat outer trims, EAS CF Titanium upper trim, EAS CF Titanium SMG Dome, Ice-Link, Painted Matching Bumper Reflectors, Painted Hood Grill, 40% Huper Optik Tint, and Ultimate pedals.
Performance Mods: VFE Stg2, SS stepped headers, cats, x-pipes, and NOW KW v3
91 Pump - 478.86 HPs
MS-109 - 511.56 HPs
Future Mods: Eibach or GC swaybars, BBK, and Hard wired V1
Jump to top t3stman is offline   Reply With Quote
Old Thu, Dec-07-2006, 04:37:59 AM   #8
tom @ eas
tom @ eas's Avatar
I already removed my HomeLink and sold it on eBay, this covered the cost of the kit with some extra cash. We've talked with the F2P guys for some time on this in the past and waited for the new version which was just released.
We're going to run the special until late next week. This is a great deal and not much more than a replacement remote....and much cooler.
Old Thu, Dec-07-2006, 08:49:48 AM   #9
M3 Beast
Reputation: 0 M3 Beast is on a distinguished road
what's the range on these? I like to open my garage door like a few houses away so by the time i pull up the driveway it's opened already. Can it do that?
Jump to top M3 Beast is offline   Reply With Quote
Old Thu, Dec-07-2006, 11:02:03 AM   #10
mastek
M3 Pilot
mastek's Avatar
Reputation: 0 mastek is on a distinguished road
This is awesome Tom,
good work
now let's see about those windows up and down by press of key (not hold down).
Ideally:
- Press once = Unlocks All Doors & Trunk
- Press twice = Opens Front Windows
- Press thrice = Opens Rear Windows & Sunroof
And locks:
- Press once = Locks All Doors & Trunk
- Press twice = Locks All Windows & Sunroof
Sorry for the jack, but if Europe can have it why cant we ...
and it seems right up ur alley
Jump to top mastek is online now   Reply With Quote
announcement, door, eas, flash2pass™, garage, opener, product, system
[eas] * New product announcement * GUNMETAL * CSL wheel & Tire Packages tom @ eas Parts for Sale/Wanted 151 Sat, Jan-08-2011 02:54:28 AM
[eas] * New product announcement * BlackOut M3 Trunk Badges! tom @ eas Parts for Sale/Wanted 22 Thu, Jun-05-2008 05:18:09 AM
eas | NEW PRODUCT ANNOUNCEMENT - MYCARR LED Angel Eyes for most BMWs tom @ eas Parts for Sale/Wanted 65 Thu, May-29-2008 07:30:40 PM
[eas] New Product announcement - e46 eurotray with integrated cupholder! tom @ eas Parts for Sale/Wanted 104 Mon, Apr-16-2007 05:20:04 AM
[eas] * New product announcement * DICE High Definition Radio w/ iPod Integration! tom @ eas Parts for Sale/Wanted 59 Tue, Mar-13-2007 05:14:23 PM
Discussing [eas] * New product announcement * Flash2Pass™ Garage Door Opener System! in the Parts for Sale/Wanted Forum - Post your Parts Wanted, and non commercial bmw related items for sale. We ask that companies selling goods become a Sponsor to advertise your goods. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
