Old Sun, Feb-11-2007, 01:23:05 AM   #1
Krank
Reputation: 0 Krank is on a distinguished road
Default LTW flywheel no longer chatters... Eurosport pulleys involved
So half a year ago, I got a Fidanza LTW flywheel with Sachs clutch when my stock clutch started slipping. At the same time, I had Eurosport underdrive pulleys installed. I've always had this strange grinding-ish noise on deceleration past ~3k rpm that I never had before, but that's another issue. I had read in another recent thread that having a LTW FW and aftermarket pulleys together was a bad combination? My flywheel no longer chatters like it used to, at all, which is something that I'd never heard of before. I was curious if something got tweaked because of the combination and my flywheel isn't 100% right?
Thanks guys.
Jump to top Krank is offline   Reply With Quote
Old Sun, Feb-11-2007, 02:49:49 PM   #2
epj3
Reputation: 0 epj3 is on a distinguished road
Thanks guys.
The rule is no aftermarket crank pulley, since the stock one is a vibration dampener. I'm thinking something happened to the fluids in your transmission. Pulleys would have no effect on the gears chattering inside the transmission (which is where the sound comes from.)
Jump to top epj3 is offline   Reply With Quote
Is the LTW Flywheel worth it (LTW FW owners only please) bigneil E36 M3 (1992-1999) 23 Sat, Feb-10-2007 07:09:54 PM
ltw flywheel vs pulleys(crank) blueM3sd E36 M3 (1992-1999) 1 Sun, Oct-23-2005 08:53:08 AM
Work Involved With Clutch and Flywheel Swap? sam01 E46 M3 (2001-2006) 0 Thu, May-26-2005 03:54:14 PM
Eurosport Pulleys itsme E46 M3 (2001-2006) 10 Sat, Mar-20-2004 09:39:33 PM
Pulleys, flywheel or cams?? Meow 3 E36 M3 (1992-1999) 6 Fri, Sep-27-2002 04:28:48 PM
Discussing LTW flywheel no longer chatters... Eurosport pulleys involved in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
