Old Sun, Jan-15-2012, 02:34:41 PM   #131
DZ_Nupe
Reputation: 0 DZ_Nupe is on a distinguished road
Default Re: DIY: E46 M3 Spark-Plugs with Pictures
Just used these instructions to replace one of my Ignition Coil... Great write-up! One question however, how dows the board feel about using Advance Auto coils?
Jump to top DZ_Nupe is offline   Reply With Quote
Old Sat, Feb-18-2012, 06:29:33 PM   #132
onlyloco
Reputation: 0 onlyloco is on a distinguished road
Thank you for the detailed instructions. I was able to complete the work in 2 hours. I dropped a socket while doing it and it took some time to fish it out and also had to go to Home Depot for an adapter
Overall easy DIY! thank you! next beer is on me..
Here are my Sparkplugs after 57k miles
Jump to top onlyloco is offline   Reply With Quote
Old Sun, May-20-2012, 11:20:06 AM   #133
kabalZA
Reputation: 0 kabalZA is on a distinguished road
South Africa
thanks a lot, this was very useful.
btw, I havent read all pages of this thread, but my OEM plugs clearly state 22Nm, not 22ft/lbs
Jump to top kabalZA is online now   Reply With Quote
Old Tue, Jun-19-2012, 10:09:40 AM   #134
uscbeemerM3
uscbeemerM3's Avatar
Reputation: 0 uscbeemerM3 has disabled reputation
Great diy. Did this today and wanted to add to the thread.
For getting off the coils, I used what I already had in the garage, a straight jaw locking plier aka vise grip and moved side to side while pulling up. I gripped the base of the plastic part of the coil just above the rubber part. I put black tape on the teeth so it wouldn't dig into the plastic on the coil.
You'll want to get the 5/8 "extended" spark plug socket. The normal size spark plug socket wouldn't fit over the spark plug. The length of the socket I used is 5in, a regular spark plug socket is around 3in. I used an 8in. ratchet extension. To clear the oil cap for spark plugs 1 and 2 toward the front of the car, you need about 10in. from the bottom of the socket to the ratchet tip.
I hand tightened everything from the engine cover nuts (x6) to the spark plugs, didn't use my torque wrench. After putting back the coil on top of the spark plug, it helped secure the spark plug from coming out. You'll notice that when you loosen the engine cover nuts and the spark plugs, they aren't on tight to begin with. You don't want to over torque the spark plugs and end up stripping the threads of the valve cover.
You don't need to disconnect the battery and you can leave the fan shroud in place and still get to the engine cover bolt next to it.
The oem spark plugs that I took out were the ngk DCPR8EKP multi-ground spark plug (it says NGK R on the spark plug). $10 amazon prime, was $20 at the dealership.
2005 SMG II. Imola Red Inside
Stock Except for M Track Mode (with M Track Mode light in the cluster)
and CSL software (faster shifts and launch control at 4800rpm), both via autologic
Jump to top uscbeemerM3 is online now   Reply With Quote
Old Thu, Sep-27-2012, 04:03:49 AM   #135
M3man2001
GO M3
M3man2001's Avatar
Reputation: 0 M3man2001 is on a distinguished road
Thanks a ton for the thread! I knocked mine out tonight no problem. Advance Auto Parts had a coupon so I got the 6x NGK Platinums for like $52, score!
Jump to top M3man2001 is offline   Reply With Quote
Old Thu, Sep-27-2012, 04:21:07 AM   #136
AltF4
In for pics...
AltF4's Avatar
Reputation: 0 AltF4 is on a distinguished road
2002 E46 M3 ~ SMGII
VMR V710 : TR MT01 : ZCP Brakes : StopTech : PFC : AR20 : UUC / Corsa
Ground Control Susp/Sway : RE FCAB : DICE : BW : AFE : PF : DEPO : Scoops
Coby Wheel : Black Trimming : Custom Alcantera / Brushed Alum Dove Grey
Jump to top AltF4 is online now   Reply With Quote
Old Sat, Oct-06-2012, 07:32:15 PM   #137
NY
Reputation: 0 NY is on a distinguished road
Just bumping this. Doing mine tomorrow if the weather holds up. I'm midway through Inspection 2. Woke up today to knock them out but the weather was iffy here so I held off.
Jump to top NY is offline   Reply With Quote
Old Tue, Oct-16-2012, 11:34:29 PM   #138
Zoomz
Vroom.. Vroom.....
Zoomz's Avatar
Reputation: 0 Zoomz is on a distinguished road
Replaced my coil packs today. I guess I should have done the spark plugs too. I thought with 53k they should be ok, but from some of the pictures in this thread I think I'm ordering plugs now.
Thanks lax for you 5 year old write up, still works like a charm
Far from stock
Jump to top Zoomz is online now   Reply With Quote
Old Wed, Oct-17-2012, 06:16:25 AM   #139
NY
You definitely shoulda did them. I did them last week with 47,8xx and this is what cylinder 1 looked like compared to new:
Old Wed, Oct-17-2012, 06:38:07 AM   #140
see.m3.go
see.m3.go's Avatar
Reputation: 0 see.m3.go is on a distinguished road
Originally Posted by simonappolis View Post
One added tip tht helps me remove the coil/plug. After disconnecting the connector from the coil, take a shoelace and slide it under the female connector and use this to pull out the coil. Its a pain in the a## to do it by pulling on the top of coil with your fingers, but pops right out using a shoelace (or similar).
+1... Tried using my finger, and pullled fairly hard without the coil coming out, but I used a screwdriver, stuck it through the ring, pulled up, and it popped out super easily
2003 TiAg/Imola: AST 4100, Vorshlag Camber Plates, TMS Power Pullies, Status Gruppe Headers, Status Gruppe Muffler, Ar20, Iconz Lip, Hardwired V1, ZCP Brakes, MH Stud Conversion, APEX ARC-8 Hyperblack 18x9.5 et35, Hankook R-S3 265/35/18
My Journal
Jump to top see.m3.go is offline   Reply With Quote
diy, e46, pictures, sparkplugs
I gave up any DIY for the spark plugs? Silver///M Faults, Fixes and DIY 2 Thu, Aug-25-2005 06:20:28 AM
spark plugs, how often? DIY? num3owner E36 M3 (1992-1999) 7 Fri, Nov-05-2004 12:42:30 AM
DIY Spark Plugs? itsme E46 FAQ 4 Tue, Oct-19-2004 06:35:43 PM
DIY on spark plugs? Drifter E36 M3 (1992-1999) 6 Thu, Sep-16-2004 02:53:51 PM
Spark Plugs - Definite DIY!! FLi GLi E36 M3 (1992-1999) 27 Sat, Apr-24-2004 01:05:49 PM
Discussing DIY: E46 M3 Spark-Plugs with Pictures in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
