Old Thu, Mar-22-2007, 05:39:39 AM   #1
mikymu
Reputation: 0 mikymu will become famous soon enough
Smile CSL M3 = MINI Cooper, battery that is. Weight benefit?
delete
Jump to top mikymu is offline   Reply With Quote
Old Thu, Mar-22-2007, 05:43:48 AM   #2
chopstik
Reputation: 0 chopstik is on a distinguished road
Taiwan
Originally Posted by mikymu View Post
So, i caught the awful German CSL measles and can't seem to shake it since the CSL exhaust mod. Decided to trim couple more lbs from the rear by getting a CSL battery. Well, the same goes with all CSL parts - can not get it. Jon at roadshow tried but the part number got kick back every time he tries to order. He would have only charge me around $85 but no go - plus it is a hazard item and shipping along will cost $50. What to do, what to do??
Well, I been hearing rumor that MINI is secretly using CSL battery and I want to know if it is true. Went to my friendly local MINI superstore and pick up a 05 MINI Cooper battery which has all the right specs. let's do some comparison:
Stock vs CSL battery - courtesy of silver ///M .................................................. ...................................... Stock vs. MINI battery (that MINI wing logo is HOT!)
CSL battery - courtesy of silver///M .................................................. .............................MIN battery - both have identical build, specs and share some parts numbers
Here comes the most important part. Weight difference:
Stock battery: 45.4 lbs ................................ CSL/MINI battery 34.4 lbs
What!? only 10 lbs difference?? I thought US stock battery is 50 lbs?? That was the number i been seeing. Unless Exide change their battery production method and lost some dead weight for stock M3 battery. This is really puzzling. Does this apply only to newer M3 like my 06? The CSL/MINI battery weight is right on the mark at 34.4 lbs
Couple interesting note. The CSL/MINI battery has all the right dimensions as stock except it is not as long. it also has all the right port and holes to fit the red plastic cap shielding the positive terminal and the little black vent pipe on the positive terminal side which connect to a plastic fume vent tube out of the battery compartment
The install was super easy. Just unclip the 2 plastic screw and lift the gray insulation away from the grove on the black battery tray.
Careful not to snap the green fuel filler release
Final fitting comparison: Stock on right and CSL/MINI on left
Driving impression: man the car screams and accelerate like mad!! .... just kidding. By adding the lighter weight battery even out the weight distribution. Now i have 15 lbs off the rear due to lighter battery and CSL muffler and 10 lbs off the front due to lighter CSL headers. There are many light weight battery out there that will reduce even more weight but I was looking for OEM fitting and did not want to sacrifice too much CCA and reserve since this is not a track car .... yet. Man, i got to make an appointment to see Dr. Jekyll about this nasty CSL German measles before it turn into a full blown meningitis ..... or is it too late?
wow...good find...
Jump to top chopstik is offline   Reply With Quote
Old Thu, Mar-22-2007, 05:47:16 AM   #3
stephentross
Geaux Tigers
stephentross's Avatar
Reputation: 0 stephentross will become famous soon enough
Nice write up. I think I might want the extra weight on my rear....
Jump to top stephentross is offline   Reply With Quote
Old Thu, Mar-22-2007, 06:25:31 AM   #4
Luiscarlos
Luiscarlos's Avatar
Reputation: 0 Luiscarlos will become famous soon enough
Very good post.....yes Mini batt is CSL batt I installed mine last week and works perfect.
You wont get any performance by doing this but if you take 11lbs 20 there etc then perf will come but the cost is hi....it is just money and it is fun to mod your M LOL,,,,,,,,
PICS IN MY GALLERY
Jump to top Luiscarlos is offline   Reply With Quote
Old Thu, Mar-22-2007, 06:34:15 AM   #5
mikymu
Hey Luis, i need to thanks you for letting us know CSL = MINI battery wise. yeah, it is fun to mod our ride
Old Thu, Mar-22-2007, 06:34:40 AM   #6
DirtySpoon
Dirtiest M3
DirtySpoon's Avatar
Reputation: 0 DirtySpoon is on a distinguished road
What . ..very cool .. .my next mod . . muaha
Jump to top DirtySpoon is offline   Reply With Quote
Old Thu, Mar-22-2007, 06:36:02 AM   #7
versace7866
versace7866's Avatar
Reputation: 0 versace7866 is an unknown quantity at this point
rep points to you
awesome find
Jump to top versace7866 is offline   Reply With Quote
Old Thu, Mar-22-2007, 09:59:09 AM   #8
fun2drv
Reputation: 0 fun2drv is on a distinguished road
Two quick questions.
1- What year Mini did you ask for? I know that it is probably the same for all of them, but the guys behind the parts counter usually wants a year when buying parts...
2- Does the Mini have the battery also in the back?
Jump to top fun2drv is offline   Reply With Quote
Old Thu, Mar-22-2007, 11:34:44 AM   #9
That's a lot of pics for a battery replacement (and that's no complaint )
You're making the rest of us look bad with all these details you use, what's the big idea?
Old Thu, Mar-22-2007, 12:40:41 PM   #10
JohnnyBravo
JohnnyBravo's Avatar
Reputation: 0 JohnnyBravo is on a distinguished road
British Antarctic Territory
Nice write up.
06' M3 Alpine White / Cinnamon
Mods:Rogue SSK with WSR, Rogue Rasp pipe, Dixis Ti Exhaust, UUC TME, UUC SS Clutch Line, TMS Rear Subframe Reinforcement Kit, TMS Adjustable Rear Camber Arms, TMS Pulleys, TC Kline D/As(550/600), Powerflex RTABs, Brembo 355/345 BBK, 19" RAC Monolite RG4s, 18" RAC RS110s in Gunmetal, AFE CAI, Sharked...
Official M3 Boobies Club: Boob #52
Jump to top JohnnyBravo is offline   Reply With Quote
battery, benefit, cooper, csl, mini, weight
FS: Mini/ CSL Lightweight battery $80-NJ cecilcohen Northeast 14 Thu, Aug-07-2008 03:57:46 AM
O.E Battery or CSL/Mini battery instead? M3 Enthusiast E46 M3 (2001-2006) 10 Fri, Jun-06-2008 08:29:14 PM
Whats the weight diference between the mini cooper battery and stock? Jasoncor E46 M3 (2001-2006) 1 Sat, Dec-01-2007 10:17:59 PM
Mini Cooper EMAXX Off Topic 2 Sat, Aug-04-2007 03:12:43 AM
Mini cooper s Sassicaia:the most rare mini limited version crystalq3 General BMW Discussion 6 Wed, May-25-2005 01:20:17 PM
Discussing CSL M3 = MINI Cooper, battery that is. Weight benefit? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
